Question about Thetford Norcold RV Cooler/Freezer
Norcold DE 540: Works OK on 12 volts; on 110 volts, compressor runs all the time -- off/on switch always ON and thermostat doesn't work. What is wrong? Cools OK, but runs all the time and gets very cold on 110. Thanks, Dave
  • Dave Sanger Jul 13, 2009
    AS I mentioned, the refrig works OK on 12 volts; thermostat works OK and on/off switch works OK.
    Only on 110 vac input, does it run all the time and the thermstat and on/off switch does not function.
    So, we need another solution, please.
    Thanks
    Dave
  • 3,037 Answers
The difference is one is running on DC voltage while the other is running on AC voltage. If the thermostat doesn't work at 110 but still works at 12, leave it, sounds like an inverter is misoperating.
Benjamin
Posted on Jul 14, 2009
  • 3,230 Answers
I assume there is no manual control for setting temp. so the thermal sensor or control circuit has failed and it is just staying at its maximum.
Now you need to change the thermal sensor.
Good Luck!!
Thanks
Posted on Jul 13, 2009
Norcold DE0061 fridge
make sure the 12 volt side fuse is not blown
Nov 29, 2013 | Thetford Norcold® Model DE0061
Carrier 48NMX042 IFM wont stop, condenser fan motor and compressor wont run
Ok first thing is it sounds like a wiring problem. So first step is to make sure the thermostat is properly connected. Which... the main thing here is there needs to be 24v dc power coming from your control board (transformer) going to the thermostat..generally that is the red wire. All the thermostat does is connect that "red" wire (power) to one of the other wires to complete a circuit. So make sure you have 24 volts... (generally about .5amps) . if you have power than switch thermostat to fan only should energize the green wire only. then switch to ac and move temp low enough that the ac should turn on and that should energize the yellow wire. for sure one of those wires is incorrect now or the fan wouldn't be on OR THE THERMOSTAT IS NOT CONNECTING THEM AND IT IS BAD. Now about the compressor and fan.... those same wires run out to the compressor unit... ok the yellow for ac.. greeen does not go to compressor unit that is for fan only (vent).. red carries the same 24 volts... one difference here is that most carrier units only have the one transformer....so you run the red wire is the +pos 24 volt..and then a "common " wire is needed which is the Ground or neg... that wire on a carrier is brown usually but could be different depending installer. The orange wire goes to the pump reversing valve it is always energized when on ac mode...when heater is on in the winter it is heat pump and is not energized so just connect the orange and yellow together... tell me more specifics if this doesn't help and i'm sure I can help you... thanks Chuck
Jun 22, 2012 | Carrier Heating & Cooling
Norcold DE 828 on my boat. Haven't been able to replace door seals as no one makes them anymore. Compressor was always loud and always coming on. Recently, no compressor noise only a buzzing or...
Hi Macias
Norcold still should have door seal parts available for this, the parts manual available at this link
http://www.thetford.com/HOME/PARTS/NorcoldIncRefrigerators/DE828EV828Series/tabid/499/Default.aspx
If the compressor is working then the condenser at the back should feel warm while the compressor is running, some of these have a single compressor and some two compressors, the units are fitted with independant power supplies so I would check these first. If you need any further info please come back to me
Regards
Gordon
May 05, 2011 | Refrigerators
It runs the battery down
Does your frig have 110, Gas and 12 volt setting? ... or is it auto select?
This is the way they should work ... if there is 110 Volts, it should run on 110 volts. The device is still controlled by 12 volts but the heat source is electric. If there is no 110 volts, it should switch to gas as a heat source. Same deal with the control, runs on 12 volts. If there is no electric and no gas, it should select 12 volts for a heat source ... same deal with the control. Problem with 12 volt source for heat is it GOBBLES up the power in your battery.
How is your battery? Do a volt test on the battery and the charger. Charger should run about 14 volts. Battery should provide at least 11 volts. If it is such that you can measure the acid, a good reading is 1200. Your charger can provide only about 15 amps charging power. Your battery should be able to provide up to 110 amp/hours.
If you do have electric and gas, it may not be your frig that is killing the battery ...
Thanks for your quesiton @ FixYa.com
Mar 21, 2011 | Dometic RM2852 Refrigerator
Norcold model n611rp works on gas but not 12 volts is there a relay in curcuit board have14.2 volts going in but hear a click and five seconds later it clicks again thanks tom
Sounds like the unit may not have enough DC power. See the manual.
http://www.thetford.com/HOME/PARTS/NorcoldIncRefrigerators/GasElectricRefrigerators/322323Series/tabid/472/Default.aspx
Nov 15, 2010 | Thetford Norcold N323 1.7-cu ft 3-way...
I know this is a vague question. (trying to help out hubby) I am currently at work, however, our norcold elect/gas fridge/freezer in our mallard camper stopped working properly. the lp gas light is lit,...
Don't be despirate.
You need a little more knowledge ... I'm here to give it.
Your RV refrigerator requires 12 volts to operate; on gas or on electric ... it needs 12 volts - period.
Now then, your frig will get 12 volts from your 'power converter' AND/OR your battery. You do have a battery in your unit, correct? If not - why not? Get one. (Your power converter cannot provide all the 12 volts you potentially require in all circumstances. It is there to charge the battery, which CAN supply all the 12 volts you require. The converter can probably put out 15 amps - your battery can put out 100 amps or more (@ 12 volts DC). Relying only on the converter for your 12 volts will cause over heating and will eventually destroy the converter. Batteries are about $100.00 - converters are about $300.00.
As you know, your frig will run on gas if you are plugged in or on generator ... that allows your frig to get the 12 volts required to run the controls.
What about electric operation? If you are plugged in or on generator, you can run on electric because your Norcold has 12 volts from the converter and/or battery.
Whats going on? Your absorbtion type refrigerator requires a heat source to boil the ammonia mixture to create "heat removing" (you can't really cool anything ... only remove the heat from it!) You can heat the ammonia with a flame or with a electric CALROD. However, the control panel that drives the whole operation runs of 12 volts.
You have a battery and generator and are plugged in and it still doesn't work? You will find a fuse on the control panel in the compartment accessible from the outside of your unit. Check/replace the faulty fuse and you will be back in business.
I hope this helps you and hubby with your Norcold Frig. Thanks for your interest in FixYa.com. If you found this solution to be helpful, please vote. Thanks
Aug 02, 2010 | Refrigerators
I have a Norcold n300 3 way it works on 110 but
try blowing through the gas orifice with compressed air only.
Jul 08, 2010 | Thetford Norcold DE0051 Refrigerator
My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Norcold Fridge will not work on LP gas while traveling.
One of two problems. The auto switch is bad or the lower circuit board is not doing its job. You can call norcold technical or take the board to a service center and have it checked with the tester they should have. The lower board retails for 176.00. I looked at my tech file and it is a little vague on your particular situation. If I were repairing your fridge I would take the smart route and call technical. Hope you get your problem solved. If you need more help please feel free.
Regards
Mar 24, 2009 | Dometic NDR 1292 Refrigerator
12 VOLT NORCOLD
Firstly you only had their word that it was cold when you bought it. A fridge with a compressor should be kept upright when it is moved and if it isn't it should be allowed to settle for a few hours before switching on. Once switched on it can take several minutes for refrigeration to begin and that would only be known by somebody holding a hand against the evaporator. It could take significantly longer for the interior to cool significantly considering the low wattage of the motor.
I am wondering how long they tested it before declaring it was ok and saleable...
Getting the right polarity when connecting equipment to a direct current is paramount and rarely is there a second chance if you get it wrong - trial and error is not an option, especially if the unit contains electronics. It is possible you got it wrong.
I suggest you take a look through a magnifier at the circuit board tracks. If you find one cracked or burned you might be able to make a repair and be very lucky, otherwise you probably should take the unit to a specialist for repair or perhaps return it to the junkyard as faulty...
Apr 24, 2017 | Thetford Norcold Compact Refrigerator 1.7...
Thetford Norcold RV Cooler/Freezer Logo
173 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
