Question about 2wire 2700HG-B Router (2700HGB)
My 2wire 2701hg-b has a flashing red light and will not connect to internet.
I had the same problem. The cause was a faulty power cable. Supposedly the 2wire cables have a notoriously high fail rate. I replaced the cable and everything now works fine.
Posted on Oct 12, 2009
  • 130 Answers
Now I am not from USA so excuse my lack of knowing AT&T.
Is that your Modem letting you go directly to the internet?
Or is it your Wireless Router?
If it is your wireless router, the simply turn both of the Modem and Router off at the wall and then wait 1 minute and turn then back on... If it is not that contact customer support.
best of luck!
-Tom.
Posted on Jul 14, 2009
4 Suggested Answers
  • 17 Answers
SOURCE: Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Posted on Feb 28, 2009
  • 8 Answers
SOURCE: 2wire 2701HG-S Embarq to AT&T
that is typically a bad username in the modem, you will have to put there temp user name in for registration for the DSL. and after that you can put the username into the modem that you created during the registration process. Should be taken care of.
Posted on Aug 09, 2009
marked
  • 6487 Answers
SOURCE: AT&T 2WIRE 2701HG-B connection problems
This is a problem with the firmware of your device so the first thing that you can do here is to do a firmware update on it to correct the problem, you can get the firmware from your ISP of the manufacturer of the device...
Posted on Sep 10, 2009
Testimonial: "Thx, so whats the firmware, and can i get it from AT&T?"
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 02, 2013 | Gateway 2wire 2701hg Wireless Dsl Modem
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
2Wire gateway is on and the DSL light keeps flashing. All eqpt is showing that it is connected to 2wire, but not internet connection. I keep getting athe message that broadband is currently...
the problem is with century link.. There server could be down because of some maintenance.. Wait for a while and it will start working as soon as the server is up..
Engr Aamir
Jul 02, 2011 | 2wire (2701HG-B) Wireless Router
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
I cannot stay connected to internet, my model 2701HG-B 2wire at&t dsl will start flashing red then disconnect me from the internet or my game site, how can i get this to stay fluently connected please!
You might want to try disconnecting everything EXCEPT the power cord. If you still get the red power light (it should stay there forever) then bring the gateway to Radio Shack or somewhere they have a 5 volt DC @ 2 amp power supply and plug it in for 5 to 10 minutes and see if the power light then stays green. If it stays green then all you need is a new power supply! If not, then the gateway is fried. Mine keeps going from a solid green power light to a flashing green power light and I can hear a relay click every 2 minutes at which time a pop-up say "ethernet line disconnected". I tried new power supply etc. to no avail! It is fried after 1.5 years! No more 2wire for me!
Sep 28, 2010 | 2wire 2700HG-B Router (2700HGB)
I have a 2Wire 2701HG-B Gateway. The power light stays red and the internet light is green. I have had no problems with this machine in the past and there was no warning for the problem. I have heard it...
1. your power adapter is possible faulty
and the port for the internet is still getting connection signal or the RJ45 is connected and this green light is saying it is connected.
check the AC plug to see of it is properly connected.
Apr 21, 2010 | 2wire (2701HG-B) Wireless Router
Sep 10, 2009 | Computers & Internet
2WIRE 2701HG-B with flickering DSL light.
The DSL is out in your area or the phone line has been disconnected.
I would contact ATT&T to find out if thire is a service issue in your area
Aug 15, 2009 | 2wire Computers & Internet
May 15, 2009 | 2wire Computers & Internet
2wire 2700HG-B Router (2700HGB) Logo
1,424 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
