Question about Sirius Starmate ST2 Satellite Radio Receiver
ST2 12V power input problems
I've had my ST2 for two years now and have had no problems until very recently. I got the unit due to its portability, but now I've found that when I try to plug it in, there is no power going to the receiver. It's not the fault of the power cord itself, as I've tried it with both my home and car kits. At times, I can get the power to flicker on, but usually there is no juice at all. Any idea how I can fix this, or does it sound like I need a new receiver?
  • 2 more comments
  • lenfontes Nov 18, 2007
    I've got the same problem , apparently the power port on the ciruit board is a bit sensitive, and after several dozen pulls, tugs, and/or drops.. the power flow is broken and the unit only powers if the unit, ac adapter and the moon are aligned. (JK)
    I've researched replacement units. This model is no longer manufactured. (probably due to this problem) You'll notice that the new model has an in-car dock that supports a more stable and rugged interchange without having to unplug the power and antenna each time.
  • Dead Dog Dec 13, 2007
    I accidently pressed the MEM button (I never use this function) and couldn't get out of the "Store" mode, so I shut the unit off. Now I have a permanent "Sirius Dog" screen. I've pushed and held every button, pulled power cable, etc.
  • kkoepfli Jan 30, 2008
    Have the same problem. Tried to open it but with all the screws out it won't open
  • Anonymous Jun 17, 2008
    power input problem
I have the same problem.  Can anyone tell me how to open up the Starmate without destroying the casing?
Posted on Feb 15, 2008
Same problem...me too
Posted on Feb 12, 2008
I actually just bought a reconditioned unit of the same model from Sirius for under $30. That solved my problem, so hopefully I can get a good couple of years out of this unit too. Maybe I will keep a soldering iron handy, though. Thanks for the input.
Posted on Dec 31, 2007
I have had the same problem, the actual power jack has come unsoldered from the board this has happened to me 3 times all I did was buy a cheap soldering iron and opened up unit and resoldered this should fix the problem
AC trips circuit breaker not long after a recent power outage.
Sounds like your compressor is shorted to ground. If you are able, unhook compressor, wrap wires and restart. If breaker doesn't trip than u know.
Jun 07, 2017 | DeLonghi Heating & Cooling
My Emerson LC320EM1F model tv went out and didnt have power about a year ago so i let it sit until
sounds like you've spent lots of money trying to fix it already. Hope someone here can help.
Sep 18, 2012 | Emerson Lc320em1 TV
I've been running my portable ac unit for the past 3 years and now the unit just blows warm air...
If the compressor is running check the thermostat, check the possibility that the gas is present and has not leaked out.
If so the pumping must be checked of the compressor , the pressure switch also must be checked.
Jun 29, 2011 | Amcor PLM-14000E Portable Air Conditioner
I have a Sirius Starmate ST2 that is stuck in the Acquiring Signal mode. It is not an antenna problem. The radio has failed. Does anyone know of the fix for this? I know it can be fixed since I've...
More than likely the antenna connection has jogged loose somehow, and just needs to be soldered. The person who handles all of our repairs at TSS Radio does this often, and I'm sure could tell you specifics. His email is sales@tss-radio.com
May 28, 2011 | Sirius Starmate ST2 Satellite Radio...
I have the starmate st2 and it does not turn on anymore. I changed the fuse in the power cord. still will not power up. I am considering dropping my service. Help!!
What I did, which was a solution I found on FixYa, is to remove the screws from the back of the unit, pop it open, and resolder the 4 connections attached to the power socket.
Jul 15, 2010 | Sirius Starmate ST2 Satellite Radio...
I have a 1990 jeep wrangler with a 1992 chevy v8 ( 5.7 liter tbi ) . I have combined both wireing harnness and this seem to work four many years (3) . I recently the i.ve had a problem with alternators (8)...
Hi
Replace the alt. unit with a suitable Bosch unit. The regulator bolts to the back of the unit, so adapt your wiring if your regulator is seperate from alt. being used at present.
If the regulator is seperate from the alt. i'm sure that's where your problem is.
Regards
Phillip
Oct 16, 2009 | 1992 Chevrolet K1500
PSP unit: when I press the square key, it turns the unit off
this problem of yours is something happen inside your psp try to go to a mechanic for psp he might fix it
Jan 07, 2009 | Sony PlayStation Portable (PSP) Console
Starmate ST2
Try finding the reset. It's usually a pinhole.
Aug 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Portable DVD Player
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
Mar 17, 2008 | Televison & Video
Sirius Starmate ST2 Satellite Radio Receiver Logo
313 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
