Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Chain will not turn when engine on 18' wild thing is running .
  • 4 Answers
MAKE SURE CHAIN BRAKE IS NOT ON PULL BLACK HANDLE BACK
Posted on Jul 16, 2009
Poulan chain saw wild thing will not start
simple things first
right fuel /oil ratio in tank ?
aircleaner not blocked off with sawdust?
stop switch set to correct "run" position , switch not broken damaged ? chain brake set ?
choke set correct to start ?
primer bulb working correctly , fuel is visible inside bulb
Apr 30, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro Wild Thing will only run with choke out. Carb has been fully rebuilt and new lines added. As soon as throttle is pulled and choke pops off, engine dies. Any recommendations/suggestions? Thanks,...
If not already done replace the fuel filter in the tank, it is obviously fuel starvation, if no better increase the the fuel mixture on the H and L screws ( turn anti clockwise 1/4 turn on each to start with)
Feb 27, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Describe your 18" Wild Thing
Check your chain tensioner. It is a little metal tab on a screw inside of the cover. If it is missing the tab that sticks out, you need a new one.
You can't really just put any chain on it with more teeth. You have to make sure you have a matching bar to go with it. The good news is, most of the big box hardware stores have "easy match" bars and chains. This will be sure you don't screw up and get the wrong chain for the wrong bar. Be warned though, running anything longer than the factory chain will likely decrease performance. The saws aren't really meant for heavy logging.
Aug 26, 2011 | Poulan 18" Wild Thing Chainsaw
I have a brand new wild thing chain saw and was using it today in the yard and it threw the chain,I put the chain back on the correct way and now the chain will not turn,The hand break is not on,can...
First get a pair of gloves and try and turn the chain by hand with the motor not running, does it turn easily and if not I would check the chain tensioning and also for debris in the clutch area that caused the chain to come off. remove the side cover and make sure nothing causing it to hang up. Then put saw back together and retension and the way to do this is to hold up on the nose of the bar and tighten the screw until you can only lift the chain and barely see the drive teeth in the middle of the bar exposed, snug down the locking nut and again rotate the chain by hand, Also while checking everything out check the bar to make sure it didn't get damaged. Let me know if you need more assistance.
Mar 13, 2011 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Poulan Wild Thing 18" Gas chain saw starts no problem but it runs for maybe 30 sec. then stops each time. I changed the core same thing.
Do a tune up. It is easy. Just take out the carb and clean with any commercial carb cleaner nad change the spark plug.
Oct 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Oil mixture wild thing
The oil mixture is 50-1 or 2.8 ounces per gallon of gas...
heatman101
Sep 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin: I own a Wild Thing 18". I don't believe the auto o...
Remove the bar and chain. Start the engine and observe the side of the engine where the bar fits to it. The oil port there should ooze oil out when the engine runs fairly fast. If nothing, then investigate the filter within the oil tank for plugging, the oil line from the tank to the pump for any damage or decay, and the oil pump itself. The pump should discharge directly to the port that the bar receives. If oil did ooze out of the port on the first test, then clean the oil passages in the bar end--two small channels that run from each large hole out to the chain groove on each side. Clean the entire chain groove. Check the sprocket on the other end for fairly free turning--oil it's bearing. Examine the chain carefully--if it got so hot that it turned the teeth blue--replace the chain, it has lost it's tempering. Assemble bar and chain--adjust the chain so that the lower side doesn't droop from the bar, and you can turn the chain by hand. The teeth cut toward you on the bottom run. If the old chain is being reused, sharpen the chain carefully so that it cuts quickly without undue effort on your or the engine's part. Hope this helps!
May 17, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
No problem i want to know how big the motor is in cc's
40 CC's or 2.5 Cubic inches
Poulan, Wild Thing, 2375, 18" Gas Chain Saw, 2.5 CUIN, 40CC, 2 Cycle Engine, Vertical Cylinder Design, Dual Counterweight Crankshaft, Primer Bulb, Inertia Chain Brake, SuperClean Air Filtration System, Gear-Driven Automatic Chain Oiler, Full-Wrap Handle
Mar 10, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan wild thing chain saw rope came off
by the time it would take to tellyou ,you would be better to take it to any small engine work shop. it is not difficult but it is to explain
Jul 20, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
