Question about Mintek LCD TV Progressive Scan DVD Player
DVD WILL NOT EJECT FROM BUILT IN DVD PLAYER - Mintek LCD TV Progressive Scan DVD Player
  • dontax1 Jul 13, 2009
    THERE IS NO SMALL HOLE IN THE UNIT TO INSERT A PAPER CLIP
  • Mintek Master
  • 19,396 Answers
Do the following:
Unplug the unit.
Ask to somebody to plug back the power cord, turn unit on immediately and at the same time keep pressing repeatedly the eject button on the DVD player.
You may need to repeat procedure a couple of times.
If that does not work, the built in DVD unit must be taken apart to fix the problem.
If my comment solve your problem, please do not forget to leave feedback afterward.
thanks.
G.
Posted on Jul 13, 2009
  • Mintek Master
  • 13,433 Answers
There should be a small hole you can push a small paper clip or anything else small in, small round hole, will eject the tray.
How do you eject the DVD
I you can't do it with the Remote control, you might be able to do it on the TV itself.
I'm not positive about this, but there should be a button on the back outer-edge of the TV that may control the DVD player.
If not, here is a link to Download the manual. Scroll down & click on 'Guides + Info' and then the download link.
http://www.us-appliance.com/pledv1945a.html
PLEDV1945A Proscan 19 LED 720p HDTV with Built in DVD Player
Good luck.
Andrew
Feb 24, 2015 | Proscan 19 In. 720p LED HDTV/DVD Combo...
How do u eject DVD on proscan pled 2488a? Tv with built in DVD player
tried to unplugged and re plugged the unit and push eject button. if can not get with reset at this time you are going to remove the cover then access the internal part of the dvd player. check for an stuck up in the cd tray mechanical assembly.
Sep 27, 2012 | Televison & Video
Soniq tv with built in dvd player says no signal on dvd mode
DVD unit has gone to dvd heaven. Not cost effective to repair. See if you have inputs so you can use an external player.
Feb 20, 2012 | Televison & Video
We have a brand new LG TV with a built in DVD player. We put in a DVD and the message was "No Signal." DVD will not play. I cannot eject it from the player
Hi:
The only way to diagnose this problem is to take the DVD out and inspect the take up rollers designed to take and eject the disc. If you hear sound when try to eject you may have a bad belt or the take up rollers are oxcided causing slipage during ejecting.
Dec 23, 2010 | LG RU-44SZ61D 44" TV
There is a DVD stuck in the built in DVD player in
try unpluging set while tv is on and plug it back in it should come out
Feb 03, 2010 | LG Televison & Video
DVD's wont eject from built in dvd player on Westinghouse 42"
u need dont need to replace if is still working what only need to do is open the casing look on look on the rubber built if is not connected sometimes this only lost. or sometimes u need only to replace the rotor.If is PC DVd u need only paper click shoot only on the hole of ur dvd many until the it eject.
Jun 20, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Dvd player
SOME dvd players have a small hole in the front... just large enough for an opened up paper clip to fit into. If yours has this, unplug your machine and insert an unfolded paper clip into this hole and gently press the mechanical eject switch. If you don't have this feature, your only hope is to disassemble the bottom of your set and spin the eject motor by hand to remove your disk.
Mar 09, 2008 | Televison & Video
Phillips/Magnavox 26MD255V
manual eject button is on side were you load the disc
Nov 09, 2007 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Dvd Player
probably the eject motor is non-functional.the tv can be opened and the dvd removed manually without affecting the tv section. the problem can be fixed by replacing the motor.
Jul 30, 2007 | Philips Magnavox 27MS343S 27" TV
Mintek LCD TV Progressive Scan DVD Player Logo
109 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
