Question about AEG Washing Machines
Door opening mechanism does not operate - AEG Washing Machines
  • 583 Answers
There is a door latch in the mechanism.the door latch moves back and forth.to open the door and close the door.its a common problem faced by many users.the door latch needs to be replaced.its just fitted on screws internally.you can get new door latch assembly at www.repairclinic.com thanks.
Posted on Jul 13, 2009
  • 6,784 Answers
HI, check the connections that link the door lock switch mechanism to the actual control board(main). if the connections are in good condition and, the harness is not fouled, replace the door lock switch mech. it has failed.
Electrolux dryer eied50liwo door keeps popping open during drying
The latch mechanism is not fulling grabbing and the door pops open. By bending either the door mechanism or the chassis mechanism so parts are tighter you can restore proper operation.
Sep 04, 2015 | Electrolux Dryers
I have a Master Mechanic Garage Door opener that I am trying to use a Genie Master Remote to operate. What steps do I need to take to operate the door with the Genie Remote?
You have to pair the remote with the opener, which will require the opener manual because you have to put the opener in programming mode.
Dec 06, 2014 | Building Materials
My GMC Yukon door not opening
This appears to be a fairly common problem on your vehicle 2 seperate occurences the electronic locks will not operate and also the mechanical latch not operating both resulting in an inoperative back door condition. It seems the only way to open the door is to remove back door panel and manually operate the latch mechanism and then find why it will not operate normally for instance the linkage no longer being attached to latch mechanism or electronic connector not making connection both have been found to be common in gmc yukons
Aug 08, 2014 | GMC Yukon Cars & Trucks
I have a 2003 vw beetle and the passenger door wont open.the mechanism operates from the key fob but the door will not open
i think the wires in the door pilar rubber boot are damaged and this is why teh door will not open as its in the locked position when the wire broke that feeds the solonoid that operates the lock
Apr 30, 2011 | 1998 Volkswagen Beetle
The headlight door or cover only open's on one side. why?
The assembly has been known to jam.
Try this before you replace any parts:
If the operation mechanism is operated by an electric motor (as opposed to a vacuum operated mechanism) and has a rubber cap over the motor, remove the cap and turn the motor by hand and watch the door open. If it hangs up, check the hinges and levers to see if anything looks broken or worn.
Mar 12, 2011 | 1987 Pontiac Firebird
Cannot open drivers door from the inside on 2001 dakota can open from the outside. The lock works for the outside handle. I have taken off the inside door cover
Either:
1. The Metal Rod connecting the inside door handle to the door mechanism is most likely disconected either at:
a. The inside door handle
or
b. The connection on the door mechanism.
2. The Door Mechanism is not operating correctly.
You should be able to see the door mechanism and the connections. I sometimes use a poskeyt mrror and flashlight to see the mechanism.
A. Check the connections and try moving the metal bar back and forth attempting to open the door.
B. If this does not work: then attempt spraying WD40 into the door mechanism and re-attempt.
C If this does not work: then remove the mechanism and check the inside door connection mechanics.
Nov 17, 2009 | 2001 Dodge Dakota
Electrical mechanism will not unlock front passenger door nor can it be unlocked manually at door handle. Inside door handle will not move so door cannot be opened. Consequently, cannot remove inner door...
possibly your linkage from the electric solenoid and door lock to the locking mechanism has either fallen apart inside the door or also possibly it has gotten "over-center" and cannot operate properly from either the automatic electric or manually from the key, can you hear and click from the solenoid when you operate this electrically? and see lock button move a little,this would be a sign it's over-center.
Sep 24, 2009 | Toyota Sienna Cars & Trucks
1972 corvette stingray, driver side door does not open fron either inside or outside.
Sounds like the door latch mechanism is worn out.
The door latch mechanism for your door is operated by rods, from the inside door handle, and the outside door handle.
It is highly unlikely, (Though not impossible), that all those two rods have fallen off. (Spring clips hold the rods in place. Opening Rod Control Clip. In the link below they are shown as Item E)
With the window all the way down, carefully use a long flat tip screwdriver, to push down on the lever for the door latch mechanism, to open the door. Make sure the lever for the door lock, in the door latch mechanism, is in the fully unlock position.
This link may help show you the inner door hardware, I'm referring to above,
http://www.mamotorworks.com/corvette-c3-door-hardware+1968+1982-inner-1-106-9491.html
You can see that when you pull out on the inner door handle, it pulls a rod forward. This rod is attached to a Bellcrank. The Bellcrank in turn pulls down on another rod, which pulls down on a small lever in the door latch mechanism, to release the door latch.
When you push down on the outside door handle, it pushes a small rod that is attached to that same lever as the inner door handle. Looking down through the window opening in the door, it is that lever that you're trying to push down, to open the door.
Viewing down through the window opening, try to operate the outside door latch a little. Watch to see what lever it tries to move. That's the lever you have to move Down, with the flat tip screwdriver.
With the door open, it is a matter to check out,
1.The Inside Door Opening Control, (The inside door handle is attached to it), to see if the locking part of it is functioning correctly. Make sure that it goes to the full Unlocked position.
2.The Door Latch Mechanism. Make sure it is functioning correctly. It, along with the various door hardware parts inside the door, needs to be lubricated at specific intervals. The more it's used, the higher the interval rate goes up. (I find that owners seem to Skip this task a lot! I use Lubriplate White Lithium spray)
To replace the door latch mechanism, I suggest you buy a manual for your car, so you can view all of the door hardware to remove, to remove the door panel. Then view how the spring clips come off of the rods, and the three screws come out of the door latch mechanism.
Jul 12, 2009 | 1972 Chevrolet Corvette
Washing Machines Logo
327 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
