Question about Whirlpool WED9200SQ Electric Dryer
My Whrilpool Dryer only makes a click sound when turned on with the door close. Any suggestion?
  • Whirlpool Master
  • 1,606 Answers
Make sure the door actuator is showing (door switch stub) that the door pushes when closing . If it's ok , then replace the thermal fuse ( a small whute piece with 2 wires connected .)
Posted on Jul 19, 2009
Michael Pryor I got a dryer model number.WED7500VW, is not turning on door switch onewire Was burn....
The door switch activates when the dryer door is closed. On most dryers, the door switch makes an audible clicking sound when it activates. To determine if the door switch is working, try starting your dryer and then listen for the "click." If the door switch makes a clicking sound, it is probably not defective. If you don't hear a click, use a multimeter to use the door switch for continuity. If the switch does not have continuity, replace it.
Aug 30, 2016 | Dryers
Lg electric dryer will not turn on
just check if the switch door its in good condition and if it make a click sound when u close the door!!if thats not the problem u'll have to open it and look for a white fuse and test it and see if thas the problem cuz if the white fuse ist working it wont turn on
Aug 26, 2012 | LG DLE2532W Electric Dryer
I was jus using my whrilpool dryer and changed the load pushed the button an it would run.. I can hear the timer clicking but it will not run. How can I check if it is the switch?
Has the door lock mechanism or the pin strike snapped these are located on the door and push into the appliance activating switches. Have a look around the door area .
Mar 18, 2010 | Whirlpool Dryers
Problem with dryer model# MDE6400AZW....light is on in the tumler but cannot turn on the dryer, checked the two thermal fuses and they are ok, any suggestions would be appreciated
this is most likely caused by the door switch. if the door is not closed, the dryer will not turn on, period. check if you can hear the switch clicking when you open and close the door. you may be able to operate the switch with your finger also. no click = bad switch (probably). you can jump over the switch for a quick fix, but will most likely have to replace it.
Nov 03, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I need wiring diagram for whrilpool ler5636kq1. timer
Good luck finding one. I look at the wires. They are marked with the same letters as that of each dryer terminal. I have a plain jane dryer manual from whirlpool but I doubt it will help much.
Oct 22, 2009 | Whirlpool LER5636P Electric Dryer
Whrilpool dryer wont start set selector press start and all lights blink and dryer makes clicking nosie from apprears bottom rear
Sounds like something you will need a repair man for.Unless you are mechanically inclined it sounds like it's electrical.
Oct 20, 2009 | Whirlpool GEW9250 Electric Dryer
Whrilpool le7800 will not start at all
make sure the door switch is ok. Usually you will be able to hear a click if not then the door switch can be broken, Or it could be the fuse stat in the dryer.
Sep 14, 2009 | Whirlpool Dryers
Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Apr 02, 2009 | Whirlpool LGV4634JQ Gas Dryer
Dryer clicks when start button pushed but does not start.
A quarter was lodged on the thermal fuse , located below the lint screen on the blower exhaust housing, on our dryer. Remove the front lower panel , 2 screw, and you'll see 2 fuses. I suspect that our control board is burnt.
Aug 05, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool WED9200SQ Electric Dryer Logo
82 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
