Question about Sport & Outdoor - Others
Setting up a 1978 bonaire tent trailer with no manual
I am tring to set up my 1978 bonaire tent trailer and am unsure how to secure the door and also how to fully extend the tent roof above the sleeping area
4 Suggested Answers
  • 68 Answers
SOURCE: how to repair tent trailer roof
Go to an auto parts store and buy a fiberglass kit. Resin, hardener and cloth. Clean and rough the area. apply a coating of mixed resin, then a layer of cloth. Let it dry and repeat a couple of times. After you are satisfied with that get a gallon of Elastomeric, you will find it at Lowes/Home depot. Clean the entire top and apply 2 coats with a brush or roller about 24 hours apart. No rain or moisture for a couple of days. Project complete, water proof roof.
Posted on Mar 25, 2009
  • 10 Answers
SOURCE: I have stripped the thread in an extendable tent pole.
if you go to any good tool store or engineering store you can get what is known as helecoil insert.just tell them the inside diam of the pole.they will probably put it in for you if yuo take the pole along.hope this will help.regards barry.
Posted on Sep 29, 2009
SOURCE: i have a Centurion power
the converter might not be working and is letting in too many volts and over powering it to the point of not working var fctb_tool=null; function FCTB_Init_18d1597bc4e042ef83fc9da550d91841(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_18d1597bc4e042ef83fc9da550d91841(document['FCTB_Init_2f479b557e0942269c917ba4c26f8cca']); delete document['FCTB_Init_2f479b557e0942269c917ba4c26f8cca'] var fctb_tool=null; function FCTB_Init_6055a1a4f8f0424782d2160b7b182f51(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_6055a1a4f8f0424782d2160b7b182f51(document['FCTB_Init_ad434a04dea2406ca738d57fb96fd227']); delete document['FCTB_Init_ad434a04dea2406ca738d57fb96fd227']
Posted on May 05, 2011
I have a Bonair 600 tent trailer furnace will not start with new battery but will work if pluged in
Check fuse, check 12 volt wiring, may have to replace board. Look close connections may be corroded.
Aug 25, 2014 | Heating & Cooling
Tent trailer
First of all clean the jacks very thoroughly. If they are really dirty, tap gently with a hammer to release sand and dirt, hose thoroughly, repeat. Lubricate every part of the jack with lots of wd40. Check that the part of the jack that extends down has been fully released and pushed up into the upper portion of the jack. Then grasp the jack with both hands and tug it down. While the jack is pulled down, swing it up under the trailer until it clicks into place.
Aug 19, 2014 | Hoisting
Hillary ten person family tent
Step 1 Choose a spot to set up your tent. Look for level ground that's free of large rocks or other debris. Make sure you're safely away from your campfire. If it's possible, pitch your tent away from your kitchen area as not to bring animals too close should they be attracted by the smell of food. Once you've chosen a spot, clear the ground of small rocks and sticks to give you a comfortable floor to sleep on. Step 2 Unroll your tent. Put the rainfly and poles aside. Open the tent body so it lays flat on the site you chose. Orient the door so it faces in an accessible direction. Step 3 Take out the tent poles. A basic Hillary tent will use two long poles for the tent body and one short pole of the rainfly. Assemble the two long poles and thread them through the pole guides on the tent body, attaching them to the holes in each tent corner to raise the tent. Step 4 Open the rainfly. Assemble the shorter pole and guide it through the top of the rainfly. Place the rainfly on top of the tent and secure it to the bottom of the tent body with the attached hooks. Step 5 Stake down your tent. You don't want to be surprised by a storm in the middle of the night or while you're away from camp. Stake your tent even if the weather is clear when your arrive. Use a stake at least in each corner of the tent. Find a rock to hammer them firmly into the ground.
Jul 24, 2012 | Sport & Outdoor - Others
How to set up the annex on a 18ft GIC camper trailer
What would you like to know exactly?
Apr 15, 2012 | Cars & Trucks
Bent tent trailer rails for pop out beds, how do we fix
Try bending rails back into shape or make new (stronger) ones. I have shared your experience. Set up trailer in rain, jumped into bed, and supports fell out! Also set up tent in the dark in the rain after one quick lesson and no instructions.
Nov 18, 2011 | Sport & Outdoor - Others
I have a Centurion power converter 30 amp for a bonair tent trailer.I have power to my plug outlets when i am plugged into household power but no dome lights which i assume are 12 volt.Would this mean the...
May 05, 2011 | Sport & Outdoor - Others
Manual for 1982 Coleman Niagara Tent trailer
One is available for download from http://www.popupportal.com/manuals/Coleman/Coleman_1982.pdf
Jul 02, 2009 | Coleman Sport & Outdoor - Others
We have a 1978 Coleman tent Trailer and we need to find instructions how to replace the cable that lifts up the roof to have the beds come out, Can you PLEASE help
if the cable is broken on the bottom of the trailer jest cable splice cable if it is broke in side the suport i have 3 of them
May 02, 2008 | Coleman Propane Forced Air Heater...
Sport & Outdoor - Others Logo
531 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
