Question about Neff B1641 Single circotherm super Electric Oven
Symbols on the control panel illuminate but the oven or grill is not heating up.
  • teresa_mcfar Jul 13, 2009
    when power is turned back on 444 is shown on the display, tried oven and grill but still not working.
    NEFF Model number B1641
    President:
  • 1,714 Answers
Turn breaker off for 30 seconds and allow system reset. Then try again making sure to use controls correctly .
Posted on Jul 13, 2009
  • 2 more comments
  • Craig Butler
    Craig Butler Jul 13, 2009
    Get the make and model number for me for further asistance
  • Craig Butler
    Go here for manual:
    http://www.managemyhome.com/mmh/owner_ma...
  • Craig Butler
    I can not find a manual but recommend you visit this web site for further assistance:
    http://www.neffcustomerservice.com/
  • Craig Butler
    There are not any manuals and I tried to help the best I could and spent 15 minutes looking for manuals. I gave you the company web site for help too.Thanks for the thumbs down, I won't be helping any more...
Oven won't heat
"heating and broil elements check ok?"...by using ohmmeter I assume? next step: unplug oven or remove power source; remove back cover of oven and ohm the thermocouple (unplugged) while heating/cooling it. Resistance readings should change quite a bit. If this checks out, your control board inside the panel is fried.A new one will cost $200-$300. If oven is more than 10 years old, I doubt if you'll find one.
Mar 05, 2014 | Whirlpool RBS305PD Electric Single Oven
Tip
Omega europa oven control settings
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
on Aug 30, 2010 | Ovens
Indesit cooker
I would contact indesit on there tech help line .Its on line on there site
Apr 21, 2017 | Ovens
My AEG oven does not heat up, nor does the grill work. The oven light and fan comes on when selected but the light located with the temperature control dial does not illuminate. This light normally...
DearDavidgale730,
I am supposing this oven/grille is electric, and is plugged in to a power source.
From your description, I'd say you have a serious problem and should no longer consider turning on the oven or the grille.
Having made that decision, take an electric meter and test the socket or wires that connect the stove/oven to the wall.
See if the current is flowing in both legs of the plug.
(Remember, two are "Hot", one or two are grounded.)
If not, correct the problem with the fuses or circuit breakers that are feeling the appliance.
If so, open the appliance up and test all circuits with that electric meter to determine the problem.
Often the problem may be a bad socket for the oven heater element, a bad element itself, or a burnt wire going to the element socket.
God bless your efforts.
Jul 04, 2017 | AEG B8139-4-M Electric Single Oven
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
How do i work the grill?
Nov 21, 2010 | Stoves 720EF Electric Double Oven
Because I haven't got a manual, and the oven is slightly worn, I would like to know what the symbol at the eleven o'clock position on the top oven control knob means. There are 2 symbols that appear to be...
There are two controls for the top oven and grill.
The far left one is purely for the oven and oven lights. The middle control of the three on the panel is for the grill. The grill will only work when the front is down, there is a micro switch that controls this.
The grill control is a dual action control. Turn it one way and it is the full grill, turn it the other and it is only the inner element. Left is the small grill, right is the larger, full grill. Oven lights do not come on with the grill control, you have to turn the lights on with the oven control.
The oven has a small element so takes a long time to heat up.
If you need a copy of the handbook, supply an email address and you can have access to my BT digital vault where a copy is stored.
Dec 10, 2009 | Stoves 720EF Electric Double Oven
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Omega Europa 20-1 oven. What do the symbols mean?
Oct 03, 2009 | Ovens
Neff B1641 Single circotherm super Electric Oven Logo
103 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
