SOURCE: bouncing rearend
Some leaf springs, when removed causes a bounce in the rear end when you forget to put them all back. You should try adding some leaf springs recommended from the manufractuer, or just look for the same parts from another model just the same as your vehicle. (tip from experience: match the leafs, and where they go.) for example: the small one will go with the other small one. I used the 2nd largest leafs and added them to my rear end, so instead of just one leaf stock there was two. if this solves your problem let me know.
SOURCE: i have a 1999 2 door 2wd blazer when i go over
Check the shock and sway bar bushings. Most likely the shock is loose and if its original needs replaced.
SOURCE: there is a really bad wabble in the front right
My suggestion would be to find out what is loose. First check to see if the lug nuts are tight. If they are then probably a bad tie-rod end or ball joint. Grab a large screwdriver or pry bar and crawl underneath ( It's best to jack up the vehicle and safely put it on jack stands, but you don't have to) Place the screwdriver between the ball joint and front spindle , sometimes kinda wedging it between the ball joint , spindle and back side of backing plate, and pry up and down to see if the ball joint is worn out. If they are good then check the tie- rod ends by getting a large pair of channel lock pliers and trying to compress the tie rod end together to see if it is worn. Other than that it could be a front wheel bearing but usually you would hear a lot of noise and your complaint was a wabble. Good luck and hope this was a little helpful to you
SOURCE: I have a 2007 Silverado
noises are a pig to diagnose from afar but i would get a can of spray silicon and spray one component at a time to find the noise...do it when dry and when you dont hear it guess what?.....
