I need freon capasity for 1990 tarus 3.0 r-134
  • 92 Answers
Around 2-3 lbs,charge till you get 30-40 degrees temp split at 2k rpm.
Posted on Jul 14, 2009
Freon capacitiesfor a 1990 Mercedes Benz 2.6 engine
Freon goes in the ac system and is adjusted to an operating system pressure for the gas in use. If you need to add gas then you have a leak so it would be a good idea to visit an accredited ac specialist shop to find and fix the leak and have the correct amount of gas added.
Jul 24, 2014 | 1990 Mercedes-Benz 300 Diesel
Need to replace a timming belt for 1990 ford tarus
1990 Taurus doesn't have a timing belt, just timing chains which never need to be replaced.
May 31, 2012 | Ford Taurus Cars & Trucks
Rr hear bumping noise and squeeking noise what is it. 1990 ford tarus 3.0 makes it sound like it's the rr window but I think maybe strut or strut ring? should I replace hole strut or is it the strut
that is a strut, the rubber is squeeking, but if its making a bumping noise you need to replace the strut and rubbers, that will take care of your problem.
Dec 08, 2010 | 1990 Ford Taurus
How to add freon to a coleman mach model# 8633-876 serial # 089817583 do you suggest r12,or r22 freon type. is this a easy procedure or does it take a ac person? the problem is it not cooling to full...
It's R-22 and you need to be licensed to handle it, if you're not a A/C service technician or fimiliar with charging an A/C system, then it is best to have a Coleman Service Technician to charge it for you.
Aug 29, 2010 | Coleman Mach 15 Air Conditioner
1998 Ford tarus Air Conditioner Problem. AC Pulley intermittedly appears to freeze up.
several things can cause this, insufficient freon, insufficient compressor oil, the switch on the
accumulator could have a loose connection, the switch could be going out. or your compressor
coulld be failing. hope this helps, good luck!
Aug 05, 2010 | 1998 Ford Taurus
Type of freon used in 1990 olds cutlass supreme. new or old?
This car uses r12 freon that is the old stuff but you can have your system converted over to the 134a.
Jun 18, 2009 | 1990 Oldsmobile Cutlass Supreme Conv
Oil capasity of 1990 kawasaki vulcon 750
Have 4lit standing by.Pour inside 2,5lit and start the engine and let it idle for 5 minutes.Then turn off the engine and add as much more as it needs to see the normal level (In the middle of the two lines) covered on the dipstick or the glass window.
Jun 08, 2009 | 1990 kawasaki VN 750 Vulcan
Replace power steering unit 1990 ford tarus
if you cannot find the tensioner pulley,and do not have the tool for releasing it ...stop,and bring it in...it does get tougher of a job,...but fairly easy task for the mechanic..
Dec 10, 2008 | 1990 Ford Taurus
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
