Question about Canon LaserCLASS Fax 710 Printer
Fax won't go through. Says the Line is busy/no signal? I have all the plugs in the correct spot. Do I have reset something?
  • 56 Answers
If you press the Hook button you should hear a line tone and if you dont please check you have the volume at max. Also check to see if the cord is on the LINE socket and not the TEL socket, the cord could be of another make and not all cord are the same.
Posted on Oct 09, 2009
Canon 8350 trying to fax, it comes back as Busy / no signal
Posted on Nov 08, 2012
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
Fax problem
But can you receive a fax from that line also?
Aug 04, 2008 | HP Officejet 5610 All-In-One InkJet...
My Brother MFC7340 Fax Machine will not send faxes it has a busy signal always and a busy signal when someone tries to fax me.
You need to reset the memory, since previously you have dialed some number, which is not able to connect. So restart the printer. Unplug the printer for 10 minutes and plug back the power to the printer.
Hope this helps.
Shane
Apr 04, 2011 | Brother MFC-7340 All-In-One Laser Printer
Can not get a dial tone. Phone appears to be off the hook. How do I trouble shoot it?
Unplug the phone line from the fax machine. Wait at least 1 minute then call the phone number that goes to the fax machine from another line such as a cell phone. Make sure you get a ring and not a busy signal. If you get a ring then hang up the phone. Plug in the fax machine again and call the fax number again. If you get a busy signal then either your phone if off the hook, the switch that is actuated when the phone is placed in the cradle is bad or your modem in the fax machine itself has gone bad. Another thing to try is unplug the fax machines power cord for 30 seconds then plug it back in. I have seen the modems get "locked up" and keep the phone line open. Unplugging will sometimes reset this and get it working again.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
Fax line is busy
check the hand set is correctly seated on its cradle.
Check the Hook button on the front of the machine.
Disconnect the fax machine from both the phone and power lines for several minutes, reconnect and try again.
UserGuide.pdf">http://static.compusa.com/pdf/canon-FAXPHONE_L80-UserGuide.pdf
I have included a copy of the users manual in case you are missing yours.
Hope this helps
Ed
May 19, 2009 | Canon FAXPHONE L80 Laser
Difficulty sending a fax
Hello. Please make sure your telephone line is plugged into the correct outlet.
Most fax machines typically allow you to plug the line (the cord that goes from the fax machine to the wall jack) and and a telephone (the telephone connects to the fax machine).
In order to fax correctly, you must plug the line into the jack with a block (looks like a 'T') marked on it. Do not plug the line into the jack marked with a phone hand set marked on it.
http://gdlp01.c-wss.com/gds/0900002546/PIXMA_MP780_750_Easy_Setup_Instructions_EN.pdf
This shoulds in detail how to connect the line properly. For this printer the line cord must be plugged into the jack labelled "L"
http://gdlp01.c-wss.com/gds/0900002542/PIXMA_MP750_780_Quick_Start_Guide_EN.pdf
This will show you how to actually send the fax. On your PDF View select page 42.
Feb 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
The machine will not send faxs nor receive them. it will make copies and the time and date works.
Betty, make sure that you can hear the on line signal when you lift the handset. If you can, try sending a fax using the manual method. If you can't hear a signal, unplug the machine from the telephone line and plug another telephone in it's place. If you still can't hear the line, there is a problem that needs the telephone line repaired. If you can hear the line, then either the line cord is not plugged into the correct jack on the machine, or there is something wrong with the machine itself or the line cord even.
Aug 18, 2008 | HP Office Equipment & Supplies
Gets busy signal
You may simply have a bad phone line from the machine to the wall jack. If the connection is getting flakey it will cause it not to connect.
You could have a sticking relay on the fax modem circuit board.
Also you could just need to reset the machine via the manufacturers directions on how to clear the memory or reset the machine to defaults.
Another question is , do you have any other pieces of equipment on the phone line with the fax? Such as a credit card machine or other device that may be causing the problem. If you have more than one item on the phone line, try plugging only the fax machine into that line and see if that works.
Is there an extension phone built into the machine also? Make sure its not causing a problem either.
That problem has a multitude of issues.
You could also have a phone line problem. If your line voltage is low, line current low or you have alot of DB loss, it can cause that issue.
Sorry I can't narrow it down to one specific issue, but that one has lots of possibilities.
Nov 19, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Fax line stays busy continously...
Still a problem? Can you be more specific?
Jan 29, 2007 | Canon FAXPHONE L80 Laser
Canon LaserCLASS Fax 710 Printer Logo
1,873 people viewed this question
old marine
old marine
