Question about HTC G1 Smartphone
I need the passcode for the g1
I need a passcode for use when using bluetooth
  • 390 Answers
Hi
if you are connecting to another phone and need a pass code that is what u set which could be from 1 digit to 4 digits
if you are registering a bluetooth headset then generally the passcode is 0000
cheers
pls rate if this was any help
Posted on Jul 13, 2009
Bluetooth paired but not coneected
How to pair and then connect to a Bluetooth device on your T-Mobile G1 Google smartphone.
1. First, ensure Bluetooth is enabled.
2. From the Home screen, press Menu.
3. Select Settings.
4. Select Wireless controls.
5. Select Bluetooth settings.
6. The G1 starts searching for Bluetooth devices in range. Select the device when it appears.
7. Type the PIN for the device.
8. The device should then pair with the G1. You can then select the device name to connect.
Bluetooth only supports ad2p profiles for headsets, music, and sharing of contacts and pictures. This is limited by VZ. Until the phone is rooted, there is absolutely no way around this. You cannot send files other than contacts and pictures via bluetooth.
It sucks... I know. I am in the same boat. I am [im]patiently waiting for the droid to be rooted so I can use bluetooth to share files between two droids.
Feb 24, 2012 | T-Mobile G1 Android HTC Google Smartphone...
Bluetooth passcode
To find a bluetooth passcode click tis link bp
to change passcode click tis cp
to reset rp
  • Step 1 Look on the back of your headset or speakerphone for the Bluetooth passcode for the device. Typically the pairing code for headsets is printed on a sticker that is then placed on the underside of the accessory.
  • Step 2 Go into the Bluetooth menu on your cell phone to find the passcode for your cellphone. The Bluetooth menu for your phone is typically located under the "Settings" menu. In the Settings menu there should be an option to "Get code" or something comparable, which would allow you to find the code for your phone.
  • Step 3 Go into the Settings menu for your computer to find its Bluetooth passcode. Some laptops will randomly generate a new Bluetooth passcode for you each time you want to pair them with a new device. In that case the menu setting you're looking for is something like "Generate new pairing code."
  • Step 4 Look in the instruction book for your Bluetooth accessory if you cannot find the passcode attached to the device or in its menu. Many manufacturers will print the passcode for devices in their instruction book. If you still can't find the passcode, try using all zeros.
  • Read more: How to Find a Bluetooth Passcode | eHow.com http://www.ehow.com/how_5169210_bluetooth-passcode.html#ixzz0vcmCZd00
    Aug 04, 2010 | Apple iPhone Smartphone
    Lost my book need passcode my phone is asking for passcode to install
    Well you can use 0000 it's the default passcode of your bluetooth headset. Most of the bluetooth headset use 0000 as default passcode.
    Good Luck!!
    Thanks for using FixYa!!
    Jun 19, 2010 | Anycom CC3103 PAROS-10 MINI BT 2.0 HEADSET...
    Bluetooth passcode
    Usually we use one 1 as a passcode. It is should be set from your cellphone then if the receiving unit ask for it enter 1 as passcode. But if security is also priority enter more digit to it.
    Apr 13, 2009 | LG Vu CU920 Cellular Phone
    Passcode
    wats the passcode for a 9xx plantronics bluethoot
    Feb 02, 2009 | Plantronics - Bluetooth Headset Plus Base...
    I've had and used my Motorola T305 with my BB Pearl 8100. I
    Passcode is usually 0000. I use it whenever I change phones and it always works. Don't know how to change it, nor do I even know why you would want to.
    Jan 09, 2009 | Motorola Mobility Bluetooth Hands-Free...
    Bluetooth not accepting anything
    Hi
    I was trying to transfer some ringtones from old phone to G1 and facing the same problem.
    And now somewhere from net I found the solution to my problem.
    Although it could not be done by bluetooth, but my problem is solved now.
    You can also try it. It may help you out.
    > Transfer ringtones/music/photos from your phone to Desktop
    > Connect G1 to Desktop by USB cable
    > On the top of G1 screen it will show the icon of USB (connected)
    > Scroll down from the icon and select 'copy files from computer'
    > Select 'Mount'
    > On desktop a massage will appear, click 'open folder & show files'.
    > Copy & Paste files from computer to G1. Now your files are in G1
    > If you want to set any song as ringtone press & hold that song, a menu will appear and you can select 'set as ringtone'
    Dec 01, 2008 | HTC G1
    Forgot my passcode for my bluetooth
    base on my experience on using the bluetooth on any mobile phone.. there is no permanent passcode in it.. you can set any passcode everytime you make a connection to another phone.. if someone you know sent you a file thru bluetooth the connection will ask a passcode from then you type any passcode then make sure you tell the sender what password you set on your bluetooth to make the connection..
    Sep 23, 2008 | Motorola Cell Phones
    HTC G1 Smartphone Logo
    269 people viewed this question
    Top HTC Cell Phones Experts
    Ashutosh Khandelwal
    Level 1 Expert
    Charles Blake
    Charles Blake
    Level 1 Expert
    D. E. Hev
    Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
