Question about Maytag EPIC MFW9700S Front Load Washer
My brand new Maytag 3000 Series frontload washer just stopped in the middle of a load and is flashing "F 30" on the screen. Any help you can offer? I tried to hit the pause button and nothing happens. I would appreciate your help.
  • kharlan Jul 13, 2009
    The model number is MHWE300VF00.
    Thanks!
My washer is only a year old and it is so load and it sounds like there is something in the mashine banging.
Posted on Sep 16, 2011
  • 111 Answers
Complete model# please
Posted on Jul 13, 2009
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Maytag 3000 series
I had the problem recently with my stupid Maytag, and the internet is loaded with complaints about Maytag washers. Unfortunately, it isn't Maytag any more, Whirlpool has purchased Maytag and several good brands and ruined them with 3rd party cheaply made junk components. What used to be metal is plastic now, and cheap plastic at that. I had the repair man out 2 times while still under warranty, and then 2 months after warranty expired again the on/off switch failed. No more Maytag products for me.
What I did was unplug the washer for 1/2 hour, then re-plug it in. Then I held in the start button for about 30 seconds and let it go. After it sat about 10 minutes, it suddenly released the catch. I can't guarantee this will work for you, but worth a shot.
Sep 28, 2013 | Dryers
Maytag 3000 series washer F21
Just cleaned out the drain inside the Maytag 3000 and boy if that don't fix it nothing will. I think something was growing in there. Seems to be working fine now. Thanks for the help
Feb 03, 2013 | Maytag EPIC MFW9700S Front Load Washer
Frontload Maytag HE 3000 sig flashing F-32 door locked
F32 means the pressure switch may be bad. Take the top off the washer by removing the 3 screws along the back. Next, locate the pressure switch, it is the part in the back left of the machine with the small plastic tube attached. Pull the tube off and blow down it in order to clear any lint in the tube. Make sure all the tiny wires are not stripped and are properly connected into the pressure switch. Check to see that the cables running from the switch to the washer are properly connected. Try running an empty load of wash to see if the switch malfunctions again. If you are still having the same problem replace the pressure switch.
Nov 03, 2010 | Maytag Washing Machines
Hi, What does a F20 error mean on a maytag 3000 series?
See this page: http://maytag.custhelp.com/app/answers/detail/a_id/2887/~/display-shows-f20-or-fh---front-load-washer
Your washer water valve inlet screens may be dirty / covered with debris and need cleaned. Some hoses have additional screens installed at the faucett connection depending on who did the install process. Low water pressure will also cause this code.
Thanks for choosing FixYa.
Kelly
Aug 30, 2010 | Maytag Washing Machines
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
is it full of water? if so there is a drain problem and may have to clean out the pump
Aug 23, 2009 | Maytag NFW7200TW Front Load Washer
Maytag Frontloader (Perf series) brand new Agitator off axis
Okay! We just fixed this problem on our washer. First, be safe and be sure that the electrical cord is unplugged. Then you want to take the lid panel off of your washer. Then you'll feel around under the base of the agitator/washer basket. You should notice that its feet sit inside huge springs which are fixed to the base of the machine unit. Determine whether any of your basket feet are disloged from their spring and re-insert. Make sure the fit is good or else you might have the same problem again. After you reassemble, plug in the machine and try a test spin without any clothes. Then try with a smallish load.
Hopefully this helps.
Jan 04, 2009 | Maytag Neptune MAH6700A Front Load Washer
Maytag Neptune Frontload....8 yrs old
hi there,
check the drain pump and the mold is quite common in front loading machines. you can use Affresh tables to remove it.
Sep 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer walking across the floor in spin cylce
This machine uses an auto-adjust for the back portion and they tend to get stuck. Since it sits on a common chassis, insert two standard legs in the back. There are threaded holes that the legs go in. Rebalance the machine. Your problem should stop.
Dec 20, 2007 | Maytag Legacy Series Top Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
2,924 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
