Cartridge installed but says cartridge missing
  • 788 Answers
Sorry to hear about your Printer problems.
Just like everything else, you get what you pay for. !
Sometimes more, sometimes less, !!!
If you are having trouble with the printer not seeing the cartridge, it will be for mostly 1- reason.... Not making connection....
Connection point are in 2- Places... 1- Cartridge Base on Printer... 2- Base of Cartridge.....
Note.... Some cartridges, like HP for example.. have a copper foil or circuit tape which is easily damaged when sitting outside printer or box.
If it was me, I would.......
1. Remove cartridge from printer
2. Place cartridge in a plastic bag and seal the bag..
3. Clean bottom base where cartridge sits, using Q-tips and worm water...
Note.. We are not washing the area, we are trying to remove any clogged points of entry.
4. If the cartridge is New or yon can hear liquid inside when shaking,
Check and make sure the plastic safety tape is completely removed.
Turn cartridge over and look for a Silver Strip.. This is where the ink transfers to, before hitting the paper.
5. With a Damp tissue or cloth, wipe gently across the sliver strip.
6. Now, Hold the cartridge with the strip downward for a few seconds, squeezing the side gently.
7. Flip cartridge over and wipe again with Dampened Tissue or Light Cloth.
Note... If after wiping the silver strip with dampened cloth or tissue you see vertical colored strips appear, its working....
8. If you hear liquid inside the cartridge and after applying worm water to prescribed areas, you still see NO INK, replace cartridge or bring to Walgreens for refill.
Note.... Walgreens will check cartridge completely and if it fails mechanically and or electronically they will let you know.
Also, they will refill most Black cartridges for just over $10.00 USD and $13.00 or so for Color.
I have found this to work for me in many printer applications...
A, Check cartridges for Safety Tape
B, Check cartridge for damages
C. Check printer base for clean thru put.
D. Check cartridge for ink flow.
Hope this information has been of help to you.
John Ray
john@johnrraycomputer.com
Readers, please rate your Technician's
Thank's
Posted on Jul 13, 2009
  • 77 Answers
Insure printer & computer are turned on & connected, remove the printer cartridge, the computer should confirm print cartridge door open & cartridge removed. Put the cartridge back in & close the print cartridge door comp should confirm these actions too. Setup is complete you printer program should tell you that it estimates a full cartridge is installed
Ink cartridges Missing or damaged Officejet Pro 8500
Check with another working or new cartridge, if problem not resolved,fault with iss unit(ink supply station). check ISS cables, PCB..replace ISS unit
Jan 31, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
Catridge error refer to device documentation to troubleshoot
You can go to HP's site and find that you have a problem with one or more of your ink cartridges see:
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
It states: " Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing.
If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might
need to be cleaned.
If there are no ink cartridges missing from the HP All-in-One, and you still receive this message
after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Contact HP
customer support." Go to:
www.hp.com/support
Basics Guide 29
Troubleshooting and support
Apr 01, 2011 | HP Photosmart C5180 All-In-One InkJet...
I have an HP Photosmart C5180.ink appears to be missing or damage
Hi there
Most times it just need a good clean ,take out and clean the brass conextions.
All the best Pineworks
Apr 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
Cartridge Error 50C consult user guide. I
Cartridge Error
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
I am missing a ink cartridge and my hp photosmart C4580 wont let me use my scanner
This is because printer and scanner are connected together.The printer need both cartridges installed to initialized and then initialized the scanner.Just put the missing cartridge and problem will solve.
Oct 29, 2009 | HP Photosmart C4580 All-in-One InkJet...
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
hi!!!!
try to clean the nozzle of your cartridge with the alcohol
or solvent used cotton
or replace the cartridge
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Photosmart C7280 Printer
Can't install lexmark x4530...get spooler subsystem app has encountered a problem,etc.
Print Cartridge(s) Missing
The following print cartridges appear to be missing, not detected, or incorrectly installed:
Cartridge on Right
Cartridge on Left
May 21, 2008 | Office Equipment & Supplies
526 people viewed this question
k24674
