Question about Whirlpool Duet GHW9150P Front Load Washer
I have a torn boot and have purchased the replacement part, but now need to know how to replace it.
    President:
  • 704 Answers
If you open the front door and look at the edge of the bellows gasket, you'll see a wire retainer that secures the outer lip of the bellows gasket to the main body of the washer. Once you remove than with a pair of needle nose pliers, you can pull the bellows gasket off the washer body and look inside to find the 1/4" or 5/16" nut clamp that holds the gasket onto the inner drum.
Be very careful when installing the new bellows gasket to get the water inlet section properly lined up with the fixed water inlet port, since you don't want to tear the new bellows and have the same problem all over again. This is a relatively easy repair and can be done by those with very limited experience, provided you take your time and are careful in handling the bellows gasket to prevent damaging it during the installation phase.
Here's a link showing the bellows gasket and the two (2) clamps that hold it in place. (Please copy and paste, as the link didn't fully load as HTML.) The 2nd link is the full sized view of the parts.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=GHW9150PW0&productCategoryId=0153200&brandId=1198&modelName=RESIDENTIAL-WASHER&diagramPageId=00002&componentDescription=DOOR AND LATCH PARTS&documentId=W0501061&backToLink=Return to Sub Components list
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0501061-00002.png
Posted on Jul 13, 2009
3 Suggested Answers
  • 464 Answers
SOURCE: The boot seal/tub seal is torn and I want to replace this piece
door boot or baffle as it is sometimes called can be replaced. however it is not an easy job as there is a large spring that hold it on.
Posted on Oct 04, 2009
  • 19 Answers
SOURCE: My front loader leaks water
There should be a spring loaded clamp on the outer panel and a screwed together wire clamp on the tub. You may have a water inlet clamp on this model and possibly a drain clamp at the bottom center. Take your time so you do not tear the new one. If you are really a go getter you can remove the top panel of the machine, the control panel, the door lock, the bottom panel and the entire front of the machine to gain easy access to the tub side of the boot. Remove the outer spring loaded clamp first before attempting to remove the front panel.
Posted on Sep 18, 2010
How to replace cv boots on atv
  1. First jack up vehicle.
  2. remove tire/rim
  3. remove cotter pin and castle nut from the end of the axle.
  4. disassemble spindle from upper/lower ball joints'
  5. separate spindle from axle by pulling spindle away from the vehicle.
  6. with two hands grasp axle and pull firmly to remove axle assembly from differential.
  7. remove torn cv boot, clean all old grease from cv joint.
  8. apply new grease and install new boot.
  9. secure clips on cv boot.
  10. Reassembly is reverse of disassembly.
  11. Consider purchasing the service manual for your make /model of atv from amazon. This manual will have step by step instructions and pictures for any repair or maintenance that you will need to perform.
May 15, 2016 | ATVs
On a 2003 hummer h3, if the outer cv boot is damaged, do both inner and outer need to be replaced?
  • Boots only need replaced when they have been negated and are leaking grease. However, the time effort and money to replace just one boot when the other is right there might bite you if the other boot needs replaced in the near future. However, if upon inspection the boot is not torn, worn and the knuckle still performs well you do not need to replace that boot.
  • Hope this helps.
Nov 17, 2011 | Cars & Trucks
My 1993 850 has a pulsation in the sterring while in a turn. The feeling is like the pump is pulsating.
Hi, this is usually caused by a worn out CV joint on one or both axles. Check to see if the boots are torn open. There are 2 boots on each axle. If they are torn, the joint is likely to be worn out or will soon wear out. Replace any axle with a torn boot. Please let me know if you have any questions, and thanks for using FixYa.
Jan 10, 2011 | 1996 Volvo 850
Ford fusion front end noise when doing tight three point turn or manovers
popping noise when turning is usually caused by worn CV joints. Inspect CV boots for tears. Torn boot will allow dust to get in and cause wear. If boot is torn, replace CV joint or entire shaft (usually easier). If boot is not torn, grab shaft next to each CV joint and see how much movement you can cause in the joint. If one CV moves more than the other three, that one is probably bad.
Aug 23, 2010 | 2005 Ford Fusion
Cv boots torn do I need to replace axels
no but it is easier to replace the whole axle, and fairly cost effective considering the amount of work and the special tools to make the job of replacing the boots easier (slidehammer with attachment etc.) and very messy.
If the inside boots are torn take a close look at your motor mounts. they could be bad and cause the inner boots to tear.
Nov 03, 2009 | 1997 Nissan Maxima
Oct 04, 2009 | Kenmore Elite 45986 Front Load Washer
Mechanic says i need new front axles......
Usually once the boot is torn, dirt goes in, and all of the lubricant goes out. If you have been driving it this way, it will damage things faster. Normally you hear a "click" when turning out of a bad cv joint.It is a safer solution to just replace both, but of coarse, not cheaper.
Aug 19, 2009 | 1992 Honda Accord
Half shaft replacement....
There's no need to replace the entire shaft, inspect th CV joint,make sure it's still well greased and replace the torn boot,they make a quick replace boot,they are easy to install and alot cheaper.
http://shop.oreillyauto.com/ProductList.aspx?parttype=741&ptset=A&searchfor=CV+Boot+Kit+-+Quick+Boot+Style
May 25, 2009 | 2004 Ford F150
How often to replace cv boots/cv joints/axle?
If something off the road tore the boot, yes but if it has not been tore long and you don't hear any clicking noises around corners, you can just replace the boot.
Mar 08, 2009 | 1992 Honda Civic
When i turn left i hear a knocking sound from my steering and i also can feel it when im pressing on the brake
What year and how many miles on the Kia? I suspect your axle boot is torn. This is a rubber boot that goes around the axle to protect it from dirt, water, and crud it would be exposed to when driving. As the car ages, the rubber will crack and split, allowing road debris to enter the axle assembly. When this happens it isn't long before the axle must be replaced. If you can look under the car at the center of the front wheel, check the boot for damage, splits, cracks, etc. You may see a lot of grease in that area, another sign the rubber boot has been torn, and axle grease is leaking out and being spread around. Have it checked soon, as the other side is either about to go, of already is beginning to. I just replaced the axles in my 92 Honda w/ rebuilt axles for only $50 each, but there is a lot of labor involved in changing them, so it isn't a cheap fix. Let me know what you find in your inspection, but it does sound like a bad axle due to a torn boot. coountrycurt0
Aug 28, 2008 | Kia Optima Cars & Trucks
Whirlpool Duet GHW9150P Front Load Washer Logo
330 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
