Question about NetGear RangeMax Premium Wireless-N Gigabit Router
Experiencing disconnections experiencing periodics disconnections using this router with laptop's in home enviroment
    Scholar:
  • 62 Answers
There could be other devices that run the same wireless frequency as your wireless network. You may want to change the channel on your wireless router or if you have an option to change other wireless devices at home such as cordless phone then you may do so. You may want to place the router away from those devices and put it in the middle of your wilreless computers to get better signal.
Posted on Jul 13, 2009
Hi, I have an acer aspire 5535 and I am experiencing problems connecting to my TP-LINK router. After resetting the router and my laptop I can occasionally connect to the internet, however after a period...
Had similar problem with a kindle and BT home hub - had to manually change the wireless channel on the router but couldn't get a channel that worked when the microwave oven kicked in.
I had two kindles and 2 home hubs and came to the conclusion that some devices must be slightly our of calibration and will struggle to connect on certain channels especially if there are near by routers.
In the end I changed my BT router for a Linksys and its been fine since.
Feb 25, 2013 | Acer Aspire 5535-5050 Notebook
The wifi connection is really bad since a few days, i can navigate however I have "cuts" (the connection is never lost) like if i had lost the connection, also i can't see any video on...
Your Wifi connection may have nothing to do with the 'performance' problem you are experiencing:
You can try to isolate the issue by plugging your Laptop/PC directly via a cable to your router and re-run the youtube video to compare it against when you are connected via Wifi.
I suspect that like most of use using ADSL that your 'effective' connection speed may be 'variable' (especially during heavy off-peak/free quota periods) and the guilty party.
To investigate the issue, run a performance test such as:
www.speedtest.net
The results might reveal performance issues (compare your results on good periods and bad periods as well as 'typical' for your ISP).
Rebooting to 'recycle' your modem/router might also help.
Hope it helps and good luck.
Sep 24, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Can't get the laptop to connect to our home wireless router, getting an error message the some of the computers hardware is disconnected, we do have a wireless card plugged in the side for internet use.
first turn off router power off wait 10-15 sec then turn on you laptop and router on. then go to your control panel open it and go to connections select home base and the icon wireless should be green hope that helps you
Dec 29, 2010 | Compaq Evo N610C Notebook
It gets disconnect after a certain period.
You can fix this and many other router related problems using Router Comamander software. Router Commander prevents router from time out and disconnects, try it out for free.
Aug 27, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
No lights on D-link DI 524
try to use it with other electric socket .if lights stil doesnt appear ,then iit could be problem with the adapter on dlink router..otherwise your router has gone bad ..if it is in warranty period go for the free replacement..
May 29, 2010 | D-Link DI 514 Wireless Router (DI-514)
I have a WRT54G2 Wireless router. Works okay with
yes mke sure wep is correct code. make sure you home security level is the same as your laptop. have tried hooking up your laptop to the home with a cat 5 cable. we had to do this with 2 dell vista laptops. then disconnect lan and we hooked up wirless just fine. something in vista firewall settings.
Dec 31, 2009 | Linksys WRT54G2 Wireless Router
Having problems hooking my printer up on a home network using a wireless router. I have a desktop computer that has a printer hooked up to it through a USB cable as a local printer. My desktop accesses the...
You are using the wrong cable. Connect the printer to your router with an ETHERNET cable - not USB. Then then printer will have an IP address. Then it should be able to connect without the intermittent off and on that you have been experiencing.
Jan 04, 2009 | HP Photosmart C6280 Printer
P660HW-D1 Router not working wireless
Problem with the Zyxel P-660?   I experienced:
1. laptop would see the wireless 660HW briefly and then it would disappear.   2. laptop would not see wireless at all. 3.  same issue with desktop when using USB wireless 11g dongle 4. no problem on wired connection (ethernet)
EASY solution!   if Zyxel is set to scan for a channel it will want to work on channel 13 nearly every time in a busy environment.
HP laptops and many receivers cannot recieve on 13 -  highest channel is 12.
Pick on setting for the Zyxel which matches an available channel on your receiver.  Problem solved.
Nov 20, 2008 | Zyxel P660HW-D1 Router
Router works with wire not wireless
there are lots of thing ht can be done like enviroment chek
wep key config ,firewall setting, go one by one minimize the firewall then try to ping it
to to network connection set it up again
this time with proper wep key and in enviroment make sure ur router is not near a carpet or microwave or any plant
May 22, 2008 | Linksys Wireless-G Broadband Router
Unable to connect via LAN with wireless router NETGEAR WPN824
I recently experienced this on laptop and desktop, using a lynksys wireless. I was able to go into each system to network connections, and tell it to connect. I haven't had a problem since........hope this helps you!
Dec 24, 2007 | Computers & Internet
NetGear RangeMax Premium Wireless-N Gigabit Router Logo
83 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
