Question about Samsung Televison & Video
I have a Samsung Blue Ray Player that has been working fine for 6 months. Yesterday I could not get any sound to come through the speakers. I have not changed any wiring or anything, it just stopped working. My Blue Ray player is connected to a Samsung TV, and a Yamaha receiver. TV and Receiver both are working fine, just can't get any sound from the Blue Ray player either with CD, or DVD. What should I check/do to get this fixed?
    Top Expert:
  • Samsung Master
  • 77,499 Answers
If it does this on all disc's you try to play it is tike for a new player.
Posted on Jul 06, 2017
  • 298 Answers
SOURCE: can't get sound out of the blu ray player
if you cant get sound to your tv speakers see that they
arent turned off.(external/internal) if you cant get sound to the receivers same procedure. check for mutes
Posted on Nov 26, 2007
HDTV GURU
  • 261 Answers
SOURCE: Yamaha - 5650/HTR-5640
Did you try going thru the setup portion of the owners manual? IF you need the manual you can get it online free. I realize sometimes people read the manuals and don't understand the technical jargon. Let me know if you need further assistance thur chat session and i can possibly step you thru it better in real time. Good luck Guru Jay
Posted on Feb 02, 2008
axebro112
  • 56 Answers
SOURCE: Hookup diagram for Yamaha avr-863 receiver
It's the other way around.
Hook up the Cable box to the Amp; and the blu-ray to the amp, then connect amp to LCD.
you want to use the best available options for audio:
HDMI > Digital Optical > Digital Coax > standard RCA
And the similar for video:
HDMI > Component > SVideo > RCA cables
I would connect Blu-Ray via HDMI to Amp, and Cable box via HDMI to Amp. If your cable box does NOT support HDMI, but you have an HD package, ask your cable company for an upgraded box.
Posted on Mar 19, 2009
renx
  • 71 Answers
SOURCE: Wireless speakers not communicating to Receiver
Speakers have a unique RF frequency that needs to pair with the receiver (kind of like a blue tooth headset with a cell phone). At times, the signal may reset, so, you may have to go through the initial pairing sequence. Try this:
1. Unplug rear speakers
2. Make sure the sound signal connector is plugged in to the back of the system properly.
3. Press and hold the ID button for 3 seconds until the blue LED light flickers.
4. Connect the power chord to the rear speakers.
Posted on May 03, 2009
mlapres
  • 757 Answers
SOURCE: connecting TV and DVD for surround sound
HDMI is fantastic in that's the only thing you need to plug in to get what you want.
You'll need two of them however. Plug one end of the HDMI cord into the HDMI "OUT" on the dvd player and the other end of it to the receiver..labeled HDMI 'IN' Then, take the second cord and do that step with the receiver back to your big screen...HDMI OUT to IN.
Surround sound from TV sources only needs a L&R audio cable connected to the receiver input labled TV or MONITOR audio IN. Unless you'd like 5.1 dolby digital or DTS from the television that requires devices that you haven't mentioned owning. In that case you will be able to get Dolby ProLogic and Pro Logic II from stereo broad casted sources on your TV.
Posted on May 09, 2009
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
Dynex blu ray sound and no picture
try a new HDMI or try compusite cables they are five cables green blue red white and black or you could try just rca jacks yellow white and black the only problem with rca jacks is it wont be HD but you will have sound and picture
Dec 09, 2012 | Dynex Blu Ray Player
I bought this recover and so far everything works but for some reason I cant get any surround sound from the recover running hdmi from blue ray player on the display it shows sw, LF, RF that's all I can...
hi,
you reseiver is now in stereo mod that's why there is no surround and center. its some thing related to to the setting in the receiver or in the blue ray.
Settings in blue ray player
First of all check the audio settings in your blue ray players audio setting.
You didn't mentioned the brand of your blue ray player. Anyway go to its setup and set the audio output priority as HDMI. also turn OFF the DRC if its a sony blue ray player. Also check the down mixing setting make it satandard
Settings in receiver.
First of all check the surround settings.
Play a blue ray disk and press the STANDARD button o the receiver's remote and select STANDARD mode.
If you didn't get the surround channels follow the below procedure
Now go to the setup of your receiver.
1. Using the down arrow go to the Advanced play back and press enter.
2. In the Advanced playback menu select auto surround mode and press enter
3. Select it ON using right arrow or left arrow. and press enter
4. Exit the setup and check is every thing working fine.
If dosn't work
Again go to the setup of the receiver
1. Using down arrow select Speaker setup and press enter
2. In the speaker setup menu select speaker configuration and press enter
3. Check the status of all the speaker, if any speaker is in NONE position , make it LARGE or SMALL according to the speaker you are using.
Exit setup and check again.
If you need any more assistance feel free to contact me through fixya.
regards
Ajin
Feb 05, 2011 | Denon AVR-3806 Receiver
How do I connect my DISH, TV and Blu-ray. Right now I have my DISH satelite HD cable connected to the TV, and a HD cable connected from my TV to the Blu-Ray. The problem i'm having is the sorround sound...
hi,
Is there is any optical digital output in your satelite HD. Then connect that optical digital output of satelite HD to the optical digital input of your surround system (blue ray player) using an optical cable.
Then press the function button on the remote of surround sound system (blue ray player) and select D.IN. (D.IN means DIGITAL IN). You will get the audio through the surround sound system. if you need any more assistance fell free to contact me through fixya.
ok
Jan 27, 2011 | Samsung HTC5500 Theater System
When I power up my Samsung BD-P3600 i get static or flashing video on the screen. When I swith it to 24f mode the movie plays fine but I cannot play bonus features or you tube videos without the same...
Samsung BD P-3600 Blu-Ray is 6 months old and won't play bonus features as of a month ago. I hear a few seconds of audio with black screen, then it jumps to player menu and won't do anything else until I turn it off and back on. Update is current.
Mar 06, 2010 | Samsung BD-P3600 Blu-Ray Player
Open Questions:
Televison & Video Logo
120 people viewed this question
Henry  Thomas
Henry Thomas
