Describe your Briggs & Stratton Pressure Washer Problem
When I try to use the spray gun the engine dies
4.0 Horsepower
2150 PSI
1.9 GPM
Model No. 580.752011
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
SOURCE: I do like to know if this washer is good enough
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
SOURCE: I have a Craftsman (B & S) pressure washer 7
I worked at a tool rental store while attending college and discovered how to extend the life of tools. Really a simple trick that you practice every day. Although your car can travel at a very high rate of speed, you only use about 30 to 40 percent of its power, if however you traveled at 100 mph everywhere that you needed to go, you would greatly shorten its life. Althouth I do believe that you have received good service from your unit, you may have increased the life by using only 60 to 80 percent of its pressure potential for most general work and increase only for stubborn debris.
Testimonial: "Many thanks for the suggestions. Dave B"
SOURCE: started by Craftsman 2700 PSI
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
