Question about Whirlpool LEW0050P Electric Dryer
Greeting From Alaska. I have a dryer Model # LEW0050PQ S/N# CAR4502402 that will not heat. The first indication that there was a problem was that the dryer would not shut off when you open the door. It keeps spinning and you have to press the power button off to get it to stop spinning. Shortly after that it stopped heating up. All lint traps and the exhaust vents are clean and air is flowing freely. Thanks for any help you can give me. We have no Dryer Tech's in my small town of Seward but can get assistance in installing/replacing parts as needed. Thanks!
  • 2 more comments
  • debburdick Jul 13, 2009
    Thanks so much for your quick reply. I really appreciate it. I have tried all the heat settings before I posted this request. No luck. None of them work. Yes sounds like the door switch is having problems. I did clean the vent tube all the way into the dryer - it is a very short distance and easy to clean. There are no restrictions and a good volume of air is coming out. I was wondering, since the dryer does not turn off when the door is opened maybe that might have caused it to over heat since it did not get the stop signal. So what would be my next best step. To order these parts? Any way to fine tune the problem a bit so I do not have to order more than I need? Or would it be better to just unhook the dryer and drive it to Anchorage? Thanks again.
  • Craig Butler
    Craig Butler May 11, 2010
    Sounds like the door switch is not working either... Thermostat controls heat. There is also a motor centrifulgal switch, in the element circuit, that the motor closes to insure the motor is turning. Try another heat setting. There is more than one thermostat. You may have blown the 'thermal fuse' too, which requires replacement. The elecment has a contact in the 'timer'circuit too. It is possible that your element has failed also. Tripped high limit. Must clean the lint filter and the exhaust vent tube and all the way in to the dryer. Hot air exit is restricted.
    President:
  • Whirlpool Master
  • 1,922 Answers
Either your element is bad,also you could have the neutral wire on the element burned off which will leave you with 240volts across element,you do need the neutral to make elements heat also ckk for 120/240 volts at dryer
Posted on Jul 26, 2009
Whirlpool dryer not getting hot enough model lew0050pq
Could be a heating element or controller issue
Jan 16, 2018 | Whirlpool Dryers
How do I Reset the heat element in my LEW0050PQ electric dryer
you have a venting issue . blown heater fuse. it will do this till you address long ,blocked vent.
Sep 12, 2014 | Dryers
Dryer not powering on
The second frying of the switch indicates a major problem somewhere. Start at the receptacle and work your way back to the inside of the dryer and see that everything is tight. I think you will find that the problem lies at where the wire ends at the block inside of the back of the dryer. This might be ugly. Dryers conduct a lot of heat and electricity and can be safe if wired properly. Your breaker may need to be reset. Turn it off and then back on to get it to start up.
Feb 22, 2013 | Whirlpool LEW0050PQ 3.8 Cu. Ft. Electric...
Re: LEW0050PQ The dryer does not power up. Is it a switch problem?
How new is the dryer? Is the door latching? Check the main electrical breaker for the dryer.
Feb 12, 2011 | Whirlpool LEW0050P Electric Dryer
Everything works except the dryer won't heat up. Pleaqse help. thank you. Pete e-mail esquiro@alaska.com
Here are 2 videos to help you troubleshoot the dryer. One of the videos is for a gas dryer, and the other is for a electric dryer. I didn't see which one you have.
Jan 06, 2011 | Dryers
Whirlpool dryer model LEW0050PQ doesn't heat up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 28, 2010 | Whirlpool LER4634J Electric Dryer
Model # LEW0050PQ - The dryer heats and runs for designated cycle time, however does not spin. Will spin if you manyally "push start" it however will get stuck when cycle spin reverses. HELP!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jun 25, 2010 | Whirlpool LEW0050P Electric Dryer
Whirlpool LEW0050PQ electric dryer makes a noise.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sdfhywt4
May 22, 2010 | Whirlpool LEW0050P Electric Dryer
Whirpool Dryer Heating and timer issue
YOU NEED CHEK:
1-thermal fuse.
2-heater element.
3-hi-limit switch.
4-temp sw.
5- electronic control.
Oct 05, 2009 | Dryers
How to install a belt on a Whirlpool dryer model LEW0050PQ?
The tech I paid to replace the belt opened the case from the top and the back, and pulled the drum back away from the front, keeping the drum attached to the back panel. This exposed the motor and the broken belt, which had been cut by the motor drive wheel, probably because the drum was too heavy. Don't you just love renters?
Mar 26, 2009 | Whirlpool LEW0050P Electric Dryer
Whirlpool LEW0050P Electric Dryer Logo
248 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
