Question about Nintendo Wii Console
Nintendo Wii keeps on turning itself off? I thought it was the fuse on the plug but it isn't. It overheats and cuts out after an hour and half.
  • 37 Answers
Should you play a game for more than 90 minutes i mean its a prety new system and still fixing ''klinks'' and stuff so respect that you can even play it.
Posted on Jul 14, 2009
What's your problem? the wii wont turn on
    • 1 Disconnect any accessories, such as GameCube controllers or SD cards.
    • 2 Unplug your Nintendo Wii AC adapter from the wall outlet and from the back of your Nintendo Wii. Leave the adapter disconnected for two minutes. Reconnect the adapter to the console and plug the outlet end straight into a wall outlet, not a surge protector.
    • 3 Remove the AC adapter from the wall outlet again. If the Wii has yet to turn on, the problem may lie within your electrical outlet. Plug a lamp, nightlight or something electrical into the outlet the AC adapter was connected to. If the outlet appears to work, then you'll have to test the AC adapter itself.
    • 4 Run your fingers along the AC adapter cable and visually look for any damage, such as frayed wires or a cracked piece of cable. Also look for the model number "RVL-002" and "Wii" on the adapter. If you don't see the "RVL-002" model number and "Wii" on the adapter, then you are using an unlicensed adapter, which can cause instability and power failure. If the adapter has incurred any damage, you will likely have to buy a new adapter.
    • 5 Spray air to clean out the vents on the back of the Nintendo Wii. If your Wii has been sitting for a long time, then dust and dirt may have built up around the vents, preventing the console from cooling itself. If the console cannot cool itself, it overheats and shuts down.
    • 6 Click "Start," "Internet Explorer" and visit the Nintendo repair page (see Resources) to open a repair claim. If you tried the above steps and your Wii has yet to power on, your system probably needs professional repair.
Oct 05, 2011 | Nintendo Wii Console
MY WII WAS WORKING FINE LAST NIGHT BUT NOW IT WON'T COME ON
you should check the tempereature ever half an hour after 1-2 hours of play because it can overheat easily without you noticing. i wouldnt recommend taking it apart but if you do you should check to see if their are any burn marks/etc.
Nov 14, 2009 | Nintendo Wii Console
Wii turned on, but no video output
Just spoke to Nintendo Technical support. Seems the rub is in the AC adapter itself.
Need to power down at both ends of the AC adapter--unplug AC adapter from wall output AS WELL AS from back of Wii.
Wait at least two minutes to allow any charge in the adapter itself to dissapate. Plug adapter into wall first, then back into the Wii, making sure your peripherals (eg AV receiver, TV, projector if using) are already on.
Tech support says sometimes you get a partially tripped "fuse" within the AC adapter itself.
This seems to have worked for now--will let the forum know if further problems
Aug 18, 2009 | Nintendo Wii Console
Just stopped mid hoovering and now won't switch on!
It is probably a thermal cut-off which is caused by a blockage. The machine will turn itself off before it overheats if it is a thermal cut-off. Once it has cooled down, you will be able to turn it back on again (usually 30 mins - 1 hour).
If the machine doesn't turn on at all anymore, you may need to replace the power switch. Call the Dyson helpline, they will do a blockage troubleshoot and if it's not that, they will tell you where you can find an authorized Dyson repair dealer in your area.
Jul 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Wii will not power on
The light on our Wii would not turn ON, and would not power up. No red, no yellow, nothing.
To fix, we unplug the Wii console. We turn the WIi console so that the back-side fan area is pointing towards the ceiling and then vacuum the fan area. Then we place it back into the Wii stand, plug it in, and the red light comes on. It powers up and works perfectly again. Obviously this won't solve everyone's issues (i.e. electronic component failures), but it has worked several times for us. Definitely worth a shot before shipping your unit off for repair.
I think the fan gets clogged and WIi protects itself from overheating, but do not really know why this works... but it does!
Dec 29, 2008 | Nintendo Wii Console
Nintendo wii
u either have dust in the usb slot or micraphone cord has a cut in it.
Dec 25, 2008 | Nintendo Wii Console
Wii power supply
To reset the AC adapter you need to unplug it from the wall outlet and the Wii console and wait at least two minutes. Plug it back in and it should come on. If you have it plugged in a surge protector with other appliances, the other appliances may be interrupting the adapter, causing the power to go off.
Apr 04, 2008 | Nintendo Wii Console
My Wii Keeps showing "An Error Has Occured".
10 hours!? wow, hard gamer.
This amount of playing nonstop is dangerous, and causes it to overheat. Leave it unplugged for 24 hours, maybe put it under a fan.
Then try, if your still getting an error, it may be fryed.
Dec 30, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
206 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
