La Crosse Technology WT 8005U W Atomic Clock with Temperature Logo
H
Harriet Sklar Posted on Nov 01, 2015
After I changed batteries and pushed WWVB button the day, time, temp and minutes came back but not the hour. It is 10 oclock and the clock says 19. What should I do
5 Related Answers
Anonymous
  • Posted on Feb 17, 2008
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Anonymous
  • Posted on Dec 02, 2010
SOURCE: My Lacrosse radio controlled clock (IECLR6) has
Mine does the same thing. I contacted the manufacturer and they told me there's nothing I can do to fix it. They suggested I return it if it's under warranty (which it isn't). With no warranty they said there is no way to repair it.
cadillac02
William Dehn
  • 318 Answers
  • Posted on Jan 12, 2011
SOURCE: My WWVB radio controlled quartz
these really aren't atomic clocks and are set at the factory. It receives, it's LF signal out of Colorado and should correct itself. If not contact the manufacturer.
Anonymous
  • 8546 Answers
  • Posted on Jan 19, 2011
SOURCE: We have an Atomic Lacrosse
Directions:
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
For warranty work, technical support, or information contact:
La Crosse Technology, Ltd
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
e-mail:
[email protected] (warranty work)
[email protected] (information on other products)
web: www.lacrossetechnology.com
Anonymous
  • 8546 Answers
  • Posted on Mar 18, 2011
SOURCE: I need to reset my
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Many downloads here, find yours.
There are two ways to find the user manual for your Timex watch.
1. Find your watch on the list below and click on the language link for your manual.
2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table at the bottom of the page.
1helpful
Set alarm on Centrios for 4 am
There are many models of Centrios brand alarms.
Here is some advice found on the web
1:
All buttons are on the back of the clock. To set the time zone, push "menu"; then push "Set" until the correct time zone is displayed (EA = Eastern, PA = Pacific, etc); then push "Menu" again - DONE. To adjust time, date, year & day, push & hold "Set" until the hour begins to flash; then push "Adjust" until the correct hour is reached; then push "Set"; repeat this sequence as the clock moves on to the next flashing segment (e.g. minute, seconds, month, date, & year); the clock will automatically set the Day based upon the Month, Day & Year you select - DONE.
2:
Press theSETkey to enter the mode"Manual Time Setting".
Manual Time Setting
In case the Skyscan Atomic Clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock.
Note:
In 12 hours mode the time will be displayed with an additional"PM"for the time from 12:00 noon until 11:59.
1. The hour digits will start flashing on LCD1. Set the desired hours by pressing the+key followed by pressing theSETkey.
2. Now the minute digits will start flashing. Set the desired minutes by pressing the+key . If the + key is held, the units will increase by 5.
3. Press theSETkey to move to the"Year Setting".
Have lost instructions for lidl radio controlled clock and it has not reset hour back
Hello
You haven't given any details about your clock, ie, its Model number, brand name etc. Yet I posts this solution, as these are the genteral proceedings to reset a radio clontrolled clock.
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time. OK.
1helpful
Hot to set tide clock
Hello
3helpful
2answers
After replacing the batteries in both the clock and the outside unit, everything is perfect except I cannot get the clock to allow me to change to Central Standard Time. Have followed instructions...
Hello
After replacing the batteries do the following to set the time.
OK.
1helpful
Clock will not stop rotating for outside temperature
Hello
Just set your clock once more and see whether it helps you. To set it, do the following:-
OK.
1helpful
My La Crosse Radio controled atomic clock is spinning for the last two days, How can this be corrected? I have a secound Clock same modle it is working fine. Modle# wt-3102
Hello
Ok.
8helpful
The clock stopped, I replaced the battery but it does nor reset itself it keeps going
Hello
This is the setting proceedings for you Atomic clock. Follow this.
OK.
2helpful
Second hand has stopped working. Stopped on # 11. Have tried new battery and resetting clock by reinserting battery. Sometimes second hand will work for a limited time. Clock keeps good time with hour and...
Hello
Just setup the clock once again by replacing the battery and check. If this also does not help you, the the press fitting of the second is loose. you have to open it to make it pressed firm.
OK.
We have had no problems in the 3-4 years we owned the clock, however recently it stopped, I replaced the battery now it continues to revolve and does not reset itself. I have pushed the reset button and ET...
Hello
After replacing the bettery you have to setup your clock. I'll give details how to stup it.
OK.
1helpful
S10Scan atomic clock model 87310 time is 4;pm should be 10:am
Hi
Time zone setting
Language Setting
The weekdays can be displayed in LCD1 with the pre-set languages: US English, French and Spanish.
1. Set the desired language for the weekday display in LCD 2 by use of the + key.
2. Press the SET key to enter the mode “Manual Time Setting”.
Manual Time Setting
Note:
In 12 hours mode the time will be displayed with an additional “PM” for the time from 12:00 noon until 11:59.
1. The hour digits will start flashing on LCD1. Set the desired hours by pressing the +key followed by pressing the SET key.
2. Now the minute digits will start flashing. Set the desired minutes by pressing the +key . If the + key is held, the units will increase by 5.
3. Press the SET key to move to the “Year Setting”.
Note:
The unit will still try and receive the signal every day despite it being manually set. When it does receive the signal, it will change the manually set time into the received time. During reception attempts the WWVB tower icon will flash. If reception has been unsuccessful, then the WWVB tower icon will not appear but reception will still be attempted the following hour.
WWVB time reception takes place from 12:00 am through 6:00 am each day (attempts WWVB reception every full hour within this time frame). When the time signal is received for example at 1:00 am, the Skyscan Atomic Clock will not attempt to receive the WWVB signal for the remaining hours until 6:00 am. Therefore, the next signal attempt will take place between 12:00 am and 6:00 am the next day. The other times WWVB reception takes place, are upon setup and after manual time set exiting mode. Reception is generally not possible during daylight hours due to the interference of the sun.
for more details see user manual...
Thank you
Top La Crosse Measuring Tools & Sensors Experts
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
