LG x110 laptop power supply problem: I let my laptop run out of battery and shut itself down. After plugging it in I noticed the battery light, which usualy stays lit, was flashing nervously. I attempted to start the computer but to no avail. I removed the battery and tried again using only plug-in power supply. No luck. Power button flashes once quickly when pressed, but nothing else happens. Without the battery the light stops flashing though. Any ideas? There were no power surges at the time.
  • 358 Answers
To be very sure of what the problem is, try to test the your laptop with a another friend's battery, or through a technician first. If it powers, then try and test the laptop again with another AC Adapter, from someone who uses the same type, or a technician.
Trying out these two things will give you a clearer and better idea of what might have gone wrong.
Hope it helps you out.
Posted on Jul 13, 2009
Any follow up? my lg x110 had the same problem last week, I don't know what to do. Any help is appreciated!
Posted on Jul 20, 2010
RESTART LG COMPUTER
I have the same problem, but no solution. have you tried a new power cord?
Nov 01, 2012 | LG X110 series (610074350750)
Crack bios password on my lg x110 - forgot bios password - can not get factory reset - help please
A password is required for access to the BIOS and I do not know the password. I have had this problem for quite some time now but luckily I've managed to get access to the BIOS now. I used lots of different programs to crack the password but I failed in vain. I removed the little battery that sat on the motherboard but nothing happened, I ran Hirens bootcd 15.1 and it did not help either. Eventually I got hold of a new system BIOS for my LG X110 and then flashed my BIOS. No password is needed now :) Download LG Notebook (X110/XD110) System BIOS here -> http://download.notebook-driver.com/driver/LG/X110/BIOS_Setup_X110.zip and run the program. That should solve your problem, because it did for me :)
Jun 19, 2012 | LG Computers & Internet
No power
Try disconnecting the power supply and start it on battery only.
After you see a screen display of some kind, the power supply can be reconnected.
If this does not work, then remove the battery and start the computer using the power supply only.
After the computer start up sequence is complete, the battery can be re-inserted into the computer.
If the computer continues to misbehave on later restarts, then follow the more rigorous BATTERY RECALIBRATION Procedure below.
1. Now, after the system is up and running with both the battery inside and the power supply connected, after taking note of the current settings so that they can be restored later, set the power plan to High Perfomance, set the computer to Never Sleep on Battery and on Power Supply, disconnect the power supply and allow the computer to run until it shuts itself off due to a low battery condition. This will discharge the battery and performs phase one of battery re-calibration.
2. Next, plug in the power supply, while leaving the battery in place and restart the computer. Allow the battery to fully recharge while leaving the power plan at High Performance and the Sleep to Never. This performs phase two of battery re-calibration.
3. Then, disconnect the power supply and allow the computer to run until it shuts itself off due to a low battery condition, again, now that it has a possibly better, fuller charge than in the previous charge/discharge cycle.
4. Again, restart the computer, connect the power supply and allow it to completely charge the battery.
5. Shut down the computer, disconnect the power supply.
6. Restart the computer and allow the computer to run until it shuts itself off due to a low battery condition again.
7. Now the battery has been recalibrated. Connect the power supply, restart/resume the computer and allow the battery to fully charge again. The Power Plan and Sleep Mode can be set back to their original settings at this time.
8. The above procedure should only need to be performed every six to twelve months to recalibrate the battery.
This condition sometimes happens to my HP Presario when I have left the power supply plugged into the computer with the battery in for several days or weeks at a time, without running on the battery alone for a while to discharge and recharge it a little bit.
HP recommends that when running your computer for more than two weeks from the power supply, the battery should be removed to slow the aging of the battery, which can cause the battery to lose capacity or fail prematurely.
May 23, 2011 | HEWLETT-PACKARD Hewlett Packard HP 15.6"...
HP Pavillion DV6700 is shittung down
This could be numerous things. It could be an over heating problem, a virus, a power supply failing or something wrong in the power adapter on the motherboard where the power plug plugs into the laptop. If you plug in the laptop and see the battery charge light come on then the problem is most likely an overheating problem or a virus. If the battery charge light comes on then I would recommend taking it to a reputable repair facility to have them diagnose the problem.
Jan 01, 2010 | Computers & Internet
HP 530 Notebook will shut off by its self and when you restart it and will show you that windows was not shut down properly. Could it need a new battery?
The problem lies with the power supply system either in the power adopter or inside the laptop. When AC power is plugged in, the system shows that the battery is being charged (Yellow Light Indicator switches ON) but practically niether the battery is usually being charged nor the computer is being run by the AC power. Its a little bit of energy left in the battery that keeps running you computer for some time and as soon as the battery is discharged the note book shuts down by itself.
However, the Taskbar battery indicator gives the correct picture of battery charge and the charging process. Better rely on that.
Its a hardware problem pertaining to power supply and charging system and doesn't have to do any thing with Mother board, RAM, Hard disks or other hardware installed in the PC.
Do tell the above details to a repair workshop man to rectify the problem.... Best of Luch
Aug 18, 2009 | HP 530 Notebook
Cursor frozen, won't respond to touchpad LG X110
Press fn+f9, this is a mode for locking and unlockig touchpad
Jun 04, 2009 | Computers & Internet
Always running on batteries
You can still use your laptop even if you take out the battery and run on ac alone. You can also leave your battery in with the ac plugged in for 4 hours to charge it even if the laptop is off. Hope this helps. Thank you.
Sep 20, 2008 | Toshiba Satellite P35-S611 Notebook
Power on my Fujitsu Seimans Lifebook B-2154
Does the laptop get very warm? It may be overheating.
May 06, 2008 | Fujitsu LifeBook B2154 Notebook
Laptop will not power on at all.
Don't know what you have for a laptop, so will have to give you a generic process, here. Power down. Remove hard drive, remove cd reader and/or floppy drive. Remove memory cards. Replace only 1 memory card in the main slot (probably marked as slot 1). Try to power it back up and let us know what happens.
Thanks!
Ron-
Nov 02, 2007 | Computers & Internet
Computers & Internet Logo
828 people viewed this question
David Payne
David Payne
