Question about Westinghouse SK-19H210S Television
Westinghouse SK-19H210S won't turn on.
This seldom used 18-month old TV for the kitchen has a good picture, although it is 16x10. It has been off for several weeks and will not power up with the side button, the remote, nor inserting an HDMI cable. It was running on NTSC RF from Dish receiver.
To check for a fuse or to test the power supply, how the heck do you "crack" the case? The 4 screws on the back are not enough to release the snap in back. Any help? -Ken
  • 2 more comments
  • Kenneth Klare
    Kenneth Klare Jul 18, 2009
    See solutions in "can't remove cover to check power supply."
    -Ken
  • Kenneth Klare
    Kenneth Klare Aug 20, 2009
    I followed the suggestions in another thread (dicefix May 17, 2009) and replaced the 2200 uF cap with 2 1000 uF caps, 1 up and the other below. I more throughly documented this Jul 18, 2009 in the other thread in response to yoshi_kotani question on Mar 31, 2009 "Can't remove cover to check power supply".
    -Ken
  • Kenneth Klare
    Kenneth Klare Aug 21, 2009
    Asked by me and answered by me on Jul 18, 2009 in the thread yoshi_kotani on Mar 31, 2009 "Can't remove cover to check power supply." The comment is hidden in the "See more" button.
    -Ken
  • Kenneth Klare
    Aug 21, 2009 - Asked by me and answered by me on Jul 18, 2009 in the thread yoshi_kotani on Mar 31, 2009 "Can't remove cover to check power supply." The comment is hidden in the "See more" button. -Ken
Look for capacitors that have a bulging top instead off being flat probably the 2200uf 10v cap
Posted on Aug 20, 2009
  • 2 more comments
  • roy dennie Aug 20, 2009
    To open the case you need to remove the base by pinching the clips in the base together remove the base. remove the hinge cover in back of the panel by popping it off with a flat headed screw driver. remove the 4 screws holding the metal plate. Then remove the 4 screws on the back of tv Now unsnap the part covering the speakers (it slides down. then unsnap the rest of the cover. the metal cover covering the power supply is held with metal tape only remove part of of so you can tip the cover up. you will need to remove some wires plugged into the power supply board first. pull on the connectors not the wires. better write down which ones go where as there are 4 of them the power supply board will be the one on the right.
    A good place to get the replacement capacitors is called Digi-Key you can order them and they cost about 90 cents and a couple of dollars for shipping, they send them out the same day when ordered only takes a few days to get it by us mail. IT WOULD BE A GOOD IDEA NOT TO ORDER THEM FROM OP AMP ELECTRONICS. THEY TOOK MY MONEY AND GOT NO CAPACITORS. THEY HAVE NO TELEPHONE NUMBER AND DON'T REPLY TO E-MAILS.
  • howman25 Oct 24, 2010
    aren't these capacitors attaced to the board? how do you remove and replace?
  • arives1
    arives1 May 27, 2012
    Thumbs up! I replaced the (bulging) 2200 10v with 2200 16v and worked great. Thanks for the info
    President:
  • Westinghouse Master
  • 1,779 Answers
Since it's a westinghouse, I would assume it's the power supply.
Posted on Jul 13, 2009
There is is a plastic cover that comes off of the base. In there are two srews that release the outside frame. I also need to test power supply if you find out how let me know.
Posted on Jul 21, 2009
Posted on May 27, 2012
Westinghouse 19inch model 19h210s has picture no sound
Fix Your Westinghouse SK-19H210S Television - Instructables
www.instructables.com/.../Fix-Your-Westinghouse-SK-19H...
InstructablesI called Westinghouse and they said that I was out of luck because it was no ... on an the screen lights up an then off ?have sound but no picture after start up .
Westinghouse SK-19H210S has picture no sound - Fixya
www.fixya.com/.../t11272945-westinghouse_sk_19h210s_picture_no_s...
Jan 13, 2012 - Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board.
Oct 16, 2015 | Westinghouse Televison & Video
The local cable company has gone digital and now my westinghouse lcd tv sk-19h210s only gets 24 channels. How do I do a channel scan?
Hi, You need a analog and digital tuner in the TV, which it sounds like you don't have, or a digital cable box.
Jun 15, 2011 | Westinghouse SK-19H210S Television
Tv not turning on
I have this same problem and I just fixed it today. I'm not sure where the problem really is but when i took everything apart and disconnected everything and put it back together it turned on and is now working! I still have one problem now, when i turn it off, the screen goes a bright white but it says that's it's off. If you ever find a solution to that please e-mail me at bmebme26!yahoo,com
Jun 08, 2010 | Westinghouse SK-19H210S Television
Went Dead After 18 Months! Westinghous Model SK-19H210S
your tv has a bad electrolytic cap rather easy to replace it only has 2 legs to unsolder.
location number CE105 its a round can thats swollen at the top.value is 2200 MF at 10 volt replace it with 2200 MF at 16 volt
Sep 19, 2009 | Westinghouse SK-19H210S Television
Tv will not turn on. power cord is good.
I have a Westinghouse Mod. SK-19H210s that is 16 months old. It would not turn on. Upon investigationg the problem I discovered bad capacitors on the power board. (2200uf and 1000uf). I replaced the components and the TV works great, you can purchase a new power board.
Jul 13, 2009 | Westinghouse SK-19H210S Television
Sk-19h210s turn on off
replaced the 2200uf 10v capacitor on the power supply board. cost 90 cents from Digi-Key on the internet and a couple of bucks for shipping. NOW MINE WORKS FINE
Jul 07, 2009 | Westinghouse SK-19H210S Television
No Power on Set
I would be calling on them if I where you! These things should not die at 18 months hardly used! So yeah! If you rember when you purchased it and the little guy or gal said would you like a extended warrentee on that? Well yes would have been a good choice!
Jun 13, 2009 | Westinghouse SK-19H210S Television
HDMI Port not WORKING.
Try unplugging the TV for about a minute and then plugging back in.
Mar 21, 2009 | Westinghouse SK-19H210S Television
Remote control code for westinghouse sk-19h210s television
I just tried a Sony code for my Westinghouse tv after reading other sites, and it worked. The code that worked for me was 10000
Oct 21, 2007 | Televison & Video
Televison & Video Logo
2,653 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
