Cars & Trucks Logo
Star Storm Posted on Nov 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need valve lash specs for 1980 suzuki dr400
Valve lash specs 1980 suzuki dr400
Claude Kayser
Level 3:
Top Expert:
  • Suzuki Master 9,098 Answers
  • Posted on Nov 01, 2015
Claude Kayser
Suzuki Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067391
Points
28436
Suzuki DR400S - Motorcycle Specs
www.motorcyclespecs.co.za/model/suzu/suzuki_dr400s%2080.ht
1980. Engine. Air cooled, four stroke, single cylinder, SOHC, 2 valves per cylinder ....Valve adjustment can be done without a feeler gauge and the CDI has ..
Dr400 valve adjustment 1 - YouTube
? 2:08
www.youtube.com/watch?v=BH-KFrpwo3w
Nov 19, 2010 - Uploaded by obtrailriders
Dr400 valve adjustment 1. ... Suzuki DRZ 400 Valves clearance check \ sprawdzanie luzu zaworowego PART 2 ...
What is the rod bearing torque on a 4bg1 Isuzu diesel? Also, I need the head torque specs and valve lash settings.
http://www.calvinlashes.com/customized-packaging-mink-lashes/customized packaging mink lashes Customized Packaging Mink Lashes-Calvin Lashes Wholesale hot sales for hot fashionable best customized packaging mink lashes.Our best soft style customized packaging mink lashes is natural,soft with fast delivery. Our best soft style customized packaging mink lashes Price cheap and Directly sell from Our manufacturer,Big discount and Free sample Available.
Need help adjusting the valve lash on a 93 suzuki sidekick 1.6 liter 16 valve engine. What is the procedure . i need to adjust is the exhaust lash i didnt mess with the intake lash with camshaft out.
its a 60,000 mile service point with new cam belt.
it has rockers, both the G16a and G16b both have rockers
SOHC both.
8v or 16valve engines.
yours is 16v, G16b
here it is
http://www.fixkick.com/t-belt/LASH/Lash16v.html
data
When cold - Coolant 59-77 degrees F.:
Intake: .005 to .007
Exhaust: (same as intake above)
When hot - Coolant 140-154 degrees F.:
Intake: , .007 to .008)
Valve clearance on suzuki vitara 1999 1.6
G16b engine is real name
correct.
6 thou is correct,cold
there is a hot spec.
all this is in the service manual, its not a big secret
4ways to do it
factory book way 1 is 2 stop way. (faster)
2answers
What a firing order in suzuki f5b. how to install the distributor in suzuki f5b? valve adjusment in suzuki f5b
want the whole shop manual posted here>?
no county stated
no year, 1988 to 1989?
no car, used in 5 different cars, not one sold here in usa.
then want answers, our books only list in that order.
547 cc
the other poster, thinks its a 4 cylinder it NOT its just 3.
so, failure.
to install a distrib, you need to know only 4 facts.
1: firing order.
2: and rotor spin direction, (crank it to see that)
3: where is #1 TDC firing. that is when both intake valves are closed. on #1.
4: where is #1, its on the crank pulley/belt end of engine
then the steps.... ill not post them.
seeing as how I DONT know if the distributor is slot drive or gear driven.
never seen a 547cc ever, (cept my motor cycles)
the common G10 engine is 1,3,2 order, not saying yours is.
here to scare posters that cant read. F5B
26204312-2xvgszsjpazazqqrkjtmkd5m-2-0.jpg the f5a is gear drive... may be yours too.
26204312-2xvgszsjpazazqqrkjtmkd5m-2-1.jpg why not go to your countries suzuki dealer and buy the book.
on this engine, that we dont have here.
to set lash first find the spec., on lash, sorry not here in USA.
but you can see those last adjusting screws above.
right?
then walking then engine 1,3,2 order set each rocker lash to
spec, at TDC firing,, 1 then 3, then 2, in that order
turning crank Clock wise. facing pulley.
done. all engines can be lash set at each cylinders TDC point.
firing.
all can but new cars with electric valves, and is not on topic.
last is your question, answered in generic forum
we dont know what cap post is #1, sorry, no car here. or books.
but if youd had marked it , at the beginning of all this.
we'd not have this post, would we.
but you need to find that out.
then make the cap and base for #1 terminal
put engine at TDC mark #1 firing
and insert drop the distributor so that the rotor lands on #1
it has a gear so you must repeat this, the gear is spiral cut.
so back the rotor up., to get that right.
you must get the base of distrb, to land so the slot adjuster is centered, and rotor at #1 term
lock down the distrb clamp.
next insert wire 1 to spark 1 and cap 1
then wire 3 to spark3 and cap 3 in proper rotor direction (#2 list)
wire 2 is obvious.
start engine.
1helpful
2answers
How I adjust valve on 96 Geo Metro 3 cylinders?
You need to replace the valve came bearing for that valve if it's a Suzuki 1.0 engine. Easy to do.
92 suzuki swift valve specs
old post, (doing suz now)
Samurai or swift , which one????????????????????????
ur posting in Samurai forum.
what spec you want?
which of the 4 engines is it and even diesel.
what spec.
lash?
valve stem diameter , or guides. or clearances on same??
lift spec, of cam or duration??
its really a Cultus?
http://en.wikipedia.org/wiki/Suzuki_Cultus
is it a GTI?
my wild guess you are in New Zealand?
99.99% of all posters never id country nor engine.
making help near impossible (cept generic answers)
so here is the gen2 list
1.0 L G10 (LP2) I3
1.0 L G10T (LS3) turbo I3
1.3 L G13A/BA (L72) 8V I4
1.3 L G13B/G13K 16V DOHC I4
1.5 L G15A 16V I4
1.6 L G16 16V I4
which engine?
never post anywhere with out engine option stated.
Need valve Lash specs on 2002 Nissan Altima 2.5 engine
There is no valve lash setting. If you remove the cams, make sure the valves and the lifter cups stay in the same position.
2helpful
2answers
Valve adjustment
tiburon uses hydrolic lash adjusters there are no valve lash adjusting If you hearing a pecking sound on the top of the mtr try some oil additive or replace the hydrolic lash adjusters
1helpful
Need valve lash specs for 95 escort 1.9l
Valve stem-to-valve rocker arm clearance should be within specification with the valve tappet completely collapsed.
The collapsed valve tappet gap, when the cylinder head is on base circle, should be as follows:
    • Minimum: 0mm (0.000 inch)
    • Nominal: 2.2mm (0.087 inch)
    • Maximum: 4.5mm (0.177 inch)
  • 1helpful
    Valve lash
    • INTAKE VALVES: 0.003-0.005 in. (0.08-0.12mm)
    • EXHAUST VALVES: 0.006-0.008 in. (0.16-0.20mm)
    • PLEASE NOTE:
    • THESE SPECS ARE FOR A 4 CYLINDER, THE V6 HAS HYDRAULIC VALVE FOLLOWERS DOES NOT REQUIRE ADJUSTMENT
    • ALL ADJUSTMENTS ARE ON A COLD ENGINE
    Top Suzuki Experts
    ZJ Limited
    ZJ Limited
    Thomas Perkins
    Thomas Perkins
    john h
    Are you a Suzuki Expert? Answer questions, earn points and help others
