Question about Sony VAIO VGC-RA830G (27242667815) PC Desktop
My VGC RA830G will work for about 20 mins then will shut off and try to immeidately reboot. Sometimes it reboots, and other times it just freezes on the VIAO screen. If I turn off and wait a while, it will reboot.
  • 43 Answers
This could be a memory problem.
Try this, download memtest x86+:
http://www.memtest.org/download/2.11/memtest86+-2.11.iso.zip
Unzip it and burn the iso to a CD using the burn image to disc option.
Place the CD in the tray of the computer and the program will start up itself. (If it does not then you will need set your computer to boot from your CD ROM Drive in the BIOS. At the VAIO screen it should say press F2 to enter setup. (Maybe it is something other than F2 but I think it is F2 on a Sony). In the bios there should be a menu that says boot or boot order and there you will see your CD Drive. Make sure it is higher than your hard drive on the list. Normally it is by default so you shouldn't really need to do this bit.
If there are errors when the program starts running the checks then it is a memory problem. If you are capable then you should remove each of your RAM modules individually (If you have more than one, If not then contact Sony if you still have warranty and order a replacement). Then start the machine and run the CD again. If you have one RAM stick that fails and another that doesn't then you have found the broken RAM. You can contact Sony and ask for a replacement if you are still within warranty.
I hope this helps you out,
Adam.
Posted on Jul 13, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Dust covering critical components will prevent the normal cooling that is necessary to prevent overheating.
Places where dust collects and actually sticks on are exterior air vents, cooling fan blades and cooling vents.
Carefully, unplugging the PC, removing outer chasis, cover, etc.
With a regular vacuum cleaner and an old toothbrush, or old paintbrush, you can free the area(s) that are dust covered, and vacuum the dust out.
Replace the parts you removed.
Plug in the PC, and reboot.
This solution has worked more than once for me and my friends.
HOW DO I UNDER FREZZER MY KINDLE
Hold the power switch for 20 seconds. Slide the power switch and hold it in place for 20 to 30 seconds before releasing it.
  • You need to physically hold the power switch in its off position for this long. Doing so tells your device to "reboot," in essence, instead of merely shutting down.
  • The reboot screen should appear as soon as you release the power switch.
Give the Kindle time to reboot. The Kindle will reboot within a minute or two. Be patient and give your device ample time to finish its reset.
  • There is some possibility that the Kindle will freeze as it reboots. This may be the case if your Kindle stays frozen on the reboot screen for more than ten minutes.
Charge the Kindle. If the device freezes during the reboot or does not respond to the reset at all, plug the charger in and allow your Kindle to charge for 30 minutes or more.
  • Make sure that your Kindle has enough time to complete a full charge.
Hold the power switch down again. After you finish charging the Kindle, slide the power switch and hold it down for another 20 seconds.
  • The reboot screen should appear again. Give the device a minute or two to reboot before checking it again. This should complete the reset.
Jan 01, 2015 | Amazon Kindle 3G
VGC-RA830G No Boot/Post/Video/No Solution HELP!
Hi elmaflow
Have you installed an operating system onto the hard drive? If not then you will need to. Hope this helps.
Feb 15, 2013 | Sony VAIO VGC-RA830G (27242667815) PC...
How do i make a recovery disk for the vaio vgc-ra830g pc?
Hello again,
Sony sells the recovery media if you require it.
https://servicesales.sel.sony.com/ecom/accessories/web/categorySearch.do?operation=subCategorySearch&subCategory=109&category=3&subCategoryName=Recovery%20CD&categoryName=Computer
if the link doesn't work copy it completely to your addressbar and press enter.
If your machine works and you can use it, and you have the original stuff from sony still installed then you can most likely find the vaio recovery from your start menu.
1. close all extra programs that you don't need.
2. disconnect your internet
3. disconnect printers and other extra devices
4. From the Vaio Recovery wizard appliaction, in the vaio recovery window, under media nad recovery options, click to select Create recovery media kit.
5. click the next button
6. You have two choises for recovery media either one recordable CD and two recordable DVD's
OR
10 recordable CD's.
Dec 23, 2009 | Sony VAIO VGC-RA830G (27242667815) PC...
My Sony VAIO VGC-RB43 PC cannot reboot there is a green light blinking in the back and i want to know how to reboot my computer.
if able u can reboot by accessing start button and clicking turnoff and choosing restart. some pc's have restart button under power button. if not you can shut it down by holding pwr button for 10 seconds. some computers will not reboot if your hardware abstraction layer (HAL) was corrupt. if so you have to reinstall it. u can just follow help options in your pc help by pressing F1 and seraching for HAL.
Nov 27, 2009 | Sony VAIO VGC-RB43 PC Desktop
Emachines w2828 keeps shutting down reboot/Screen Freeze
I dont thing this is a virus problem but a heat problem. if you dont mind getting inside the box see how clean it is and put your hand on the power box case .. then unplug all the hardware except the mother board then turn the unit on, if it goes on then plug 1 hardware at a time.
Sep 04, 2009 | E-Machines eMachines Desktop PC
Electronic touch panel unresponsive. Clock blinks, but no other commands produce any activity. Model#:JMW8330DAS Serial #:13679516JN Jenn-Air oven. About 2 years old.
Unplug and let sit for 5 min. Replug and set clock time first. Then see if the other buttons work. Electronics sometime need to reboot if it freezes like your computer does sometimes.
Apr 29, 2009 | Jenn-Air JMW8330DAS Stainless Steel...
Toshiba Satellite L300 kept turning off
Sounds like a device driver conflick before you try to restore reboot the laptop and at startup press F8 at the menu click onsafe with networking so that if you need to download drivers yo can " Right click on my computer clik on manage look in event viewer and see when errors started to happen if the was a software update at the time of the error uninstall it and reboot the computer. if not you may have to restore the system to and earlyier date and loose data Good luck
Mar 25, 2009 | Computers & Internet
Xbox 360
buy a can of air and see if you can clean it out. It may be a cooling issue. I believe there was a recall for this by microsoft you may want to investigate.
Apr 07, 2008 | Microsoft Xbox 360 Console
Sony VAIO VGC-RA830G (27242667815) PC Desktop Logo
148 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
