Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Vaccuum Seal Freezer doesn't seem to seal which cuases condensation in freezer.  Also getting message inFridge that vaccuum seal is not engaged.  Suspect it could be faulty gaskets .
  • 833 Answers
Barnes, this sounds right. This may be a pretty big job, though. Some gaskets are not installer friendly. They are also expensive...so you'll not want to ruin them. Also, allow enough time to do a full defrost in the freezer (maybe a day) before restarting your unit. There will be quite a bit of liquid in the drain tray below the unit. Also, clean up the coils below the unit for best efficiency.
Posted on Dec 18, 2007
Electrolux Built in freezer door not closing.
I'm suspecting the door also because of the lack of suction power. you have to check the gasket more. Frost around the door is a great indication of where warm moist air is coming into it.
Aug 14, 2013 | Refrigerators
Kenmore 10654382300 side by side
Hi Vince,
Thanks for the posting in FIXYA.
Please repair the Freezer door as it is not sealing, due to which cooling is affected. If it is under warranty then contact to the manufacturer as soon as possible.
Regards
ELLIN
Sep 15, 2008 | Kenmore 25.1 cu. ft. Side-By-Side...
Door seal not tight on upright freezer
Check the door sits straight and square on the front. You can "adjust" with the heel of your hand to make it sit flat against the frame. Even a poor seal shouldn't make frozen food thaw - check and clean the condenser and fan
May 08, 2012 | Kenmore 16.7 cu. ft. / 473 liter Upright...
We inadvertently left the freezer door slightly open the frrezer ran continuusly for twenty four hours. Would this cause the condenser to frreze up and burn out? The frrezer is still cold and we...
leaving your freezer door open does nothing ,but work the freezer harder,,,it wont cause no of the prolems you stated,,it will cause your electric bill to rise ,,your ok...the condenser is part of the seal system and it exspell the heat usally under the fridge...good luck
Sep 03, 2011 | Kenmore Top Freezer Refrigerator
My tcs off light wont go off.
Try checkin all vaccuum lines for leaks, cracks, holes, and disconnections. How is your acceleration? If vaccuum lines are not sealed right, it could cuase degradation in acceleration, too. If all nies seem to be OK, you could try shooting a bit of carb cleaner down the manifold throat. If none of these above works, I'd find a good independent service shop to pull codes on their TECH II (alternatively, Autozone can do it for free, I hear).
Hope this helps some.
Keep Saabin'!
Jul 19, 2010 | 2001 Saab 9-3
Whirlpool refrigerator not cooling properly.The motor seems to be running. There is the sound of a fan in the freeaer. I cleaned underneath with a vaccuum and my compressor. I was going to take the back...
Either the defrost timer, defrost heater or defrost termination thermostat have failed. The rack and the sheet metal at the back of the inside of the freezer would have to come out to access the evaporator coil.
Need your model # to be able to ascertain what parts you might need.
Mar 03, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My frigidaire refrigerator is sweating on the inside. what should i do? its a one door model with ice maker and freezer on top. i don't remember the model. 5 years old.
High humidly could cause condensation or the magnetic seal could be bad.
A couple of things to try;
The easiest thing to do first is to clean around the rubber seal very good with mild soap and water and the metal which the magnetic rubber seal contacts to seal the door. If you find a crack or a deformation of the seal it will let condensation it the refrigerator.
Does the freezer auto defrost or is a lot of ice bult up around the freezer walls? If so manually defrosted the freezer.
Dripping from the Ice maker water supply?
Jul 15, 2009 | Frigidaire Refrigerators
Condensation problem hotpoint mistral 8596
if the door seals are both ok, check and see if she has any open containers in the fridge juice ect that may be allowing moisture to escape. a model number and serial nuber off the sticker in the fridge would help me with more ideas.
Sep 25, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
101 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
