Question about Sewing Machines
Wheel on right side that controls the needle up and down is very tight. Hard to turn.
  • Sewing Machines Master
  • 12,730 Answers
Is your sewing machine mechanical (ie, not computerized)??? CAUTION--if your machine is computerized, do NOT proceed with the following suggestions.
If it is mechanical, have you cleaned and oiled your machine recently? Most mechanical sewing machine failures are because they have not been adequately and routinely oiled, the old oil has solidified and frozen the mechanics. I recommend Bernina oil, liquid Tri-Flow Synthetic Lube (or similar good quality sewing machine oil) for mechanical machines--do NOT use 3-in-1, cooking oil, WD-40, or the sewing machine oil from your grandmother's sewing basket. (I am not associated with any Bernina dealer, other than a customer.)
If it is in fact frozen, pick up a bottle of liquid Tri-Flow Synthetic Oil at the hardware store. Oil one or two drops in every oil hole (see your manual) and also every place where metal rubs on metal. But DO NOT oil any plastic gears, rubber, or belts. It is probably best to avoid oiling the metal cams. If it is still stiff or frozen, direct a hot handheld hair dryer into the top and bottom mechanism of your machine. See if that loosens it up. You may have to repeat.
Once your machine is working again, place a drop or two of good sewing machine oil as directed above. Be sure to use a small brush to clean the lint and dirt out of your machine, especially around the feed dogs and bobbin area. (Caution: Compressed air will sometimes force the dirt and lint into areas that cannot be cleaned.) And continue to use good quality sewing machine oil to keep it running. Recommendation: every time you change a bobbin, after 8 hours of sewing, or every six months if it is not in regular use.
To find a manual:
Search the internet for "Kenmore 158.12511 Manual" You'll probably find a downloadable pdf manual (or at least one similar to your machine). Be very CAREFUL that they are not scam web sites (one wanted me to upgrade Acrobat when I just did it a couple days ago!) Here's one for $5.95-- http://www.sewconsult.com/kenmore/158%20manuals/kenmore_158_source_manuals.htm
or one for $4.99-- http://manualsoncd.com/product/kenmore-model-158-1212-1341-series-sewing-instruction-manual/
Here's one currently on eBay for $8.94--
http://www.ebay.com/itm/Sewing-Machine-Manual-Sears-Kenmore-1251-158-12510-and-158-12511-on-cd-/281847997472?hash=item419f732420:g:czAAAMXQPatTJ4FF
On the other hand, if you can find a manual from Sears, that is probably the most reliable (unless you can find a used manual on eBay, Etsy...) $15 isn't such a bad price if it helps you keep your machine running and reduces your frustration. You might also check Yahoo Groups for a Kenmore Users Group. Frequently, Group members will post those documents in the Group files or someone might have one that they no longer want.
Posted on Nov 01, 2015
  • 1 more comment
  • Donna Jimmerson
    Donna Jimmerson Nov 05, 2015
    Do you know where I can get a manual for my machine? I'm not willing to pay $15-$20 for one. I have a Kenmore 10 Model# 158.12511 Thank you.
  • R.A. Ellis
    R.A. Ellis Jan 05, 2016
    A manual is available for ~$6 here:http://www.kenmoresewingmanuals.com/kenm...
    Sorry, I was not able to find any free manuals for your machine.
    Universal manual that covers your model. Most machines from the same era operate similarly. They usually just have some different options.http://manualsoncd.com/product/kenmore-m...
  • Kaarleiv Vaagslid Apr 22, 2018
    Thank you, R.A.Ellis. Now IT works just fine.
    K.
SOURCE:
My turn wheel, is very tight, doesn't sew good When I try to sew, I have to guide my material, the wheel is so tight
You didn't tell us what machine you have, but if it's an older mechanical machine, it's probably seizing due to old oil that has dried out. Resist the temptation to try to run the machine until the problem is taken care of properly. You could damage the motor.
Wheel on right side that controls the needle up and down is very tight...
Dec 08, 2017 | Sewing Machines
Kenmore sewing machine, Model no. 13550
It needs cleaning and oiling! Do NOT run the motor until you get it taken care of or it can damage the motor.
Nov 22, 2017 | Kenmore Sewing Machines
Sewing Machines Logo
3,321 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
