Question about Dell Computers & Internet
The light went out on my montitor.Can still see screen no light
I have a Dell Inspirion laptop and the light went out on the monitor. I can still see the sceen words but the light is out.
  • 721 Answers
You need a new lcd screen & while you're at it replace the inverter. There's no other option. Check ebay for the parts.
Posted on Jul 14, 2009
HP S230 monitor won't connect to my Dell Inspirion 15 laptop via DP to HDMI cable
Hi Msdco1, 1st try fixing your laptop..... The link below is a YouTube video showing 3 ways on how to fix your laptop, Also there's videos down the right side of the link that may help as well, I hope this helped....CHEERS..
ALL LAPTOPS DISPLAY NOT COMING ON BLACK or BLANK SCREEN DIM DISPLAY
May 10, 2016 | Dell Inspirion 15
Forgot password for my dell inspirion 1440 laptop
Hi.. Did u create administrator passwd? Did u try running on safe mode?
here the link the tutorial..
Start your computer in safe mode Microsoft Windows Help
Jan 19, 2014 | Dell Inspiron Computers & Internet
My computer had not been used in a couple of weeks and when I turned it back on it started beeping and the monitor will come on but cannot see screen
The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Sep 02, 2012 | Dell Inspiron 530 Desktop Computer
I have a Dell Inspirion 3000. Was working fine, but when I went to start it up, The Dell sign would pop up for about a half second, then the screen went black. You can barley see the scrren, not enough to...
most likely its a GPU issue since your external monitor is affected as well, since GPU for laptop is connected to the board you may need replacement for it. if you are still in warranty with dell they will send out a technician to replace the whole motherboard. if not they may charge you for it.
Mar 24, 2011 | Dell Computers & Internet
Only half of my screen on my dell inspirion 9200
you can try to connect an external monitor to your system then toggle FN+f8 if you see the screen good in external monitor it means the graphic card is ok then you have to replace the LCD panel.
Jul 22, 2010 | Dell Inspiron 9200 Notebook
Have an Dell inspiron e1405 laptop. Screen is not
Try new memory (RAM) or if the device has two memory module install turn the deviice off take one module out turn on
If it does not work then
Turn the device off take the second module out replace with the first module
Turn the device on
Jan 06, 2010 | Dell Inspiron E1405 Notebook
Inspirion laptop 1521. monitor stopped working.
The problem is the inverter, possibly a bad connection or a dry solder joint.
To check this remove the screen bezel (plastic screen surround). At the bottom of the screen you will see an elongated piece of circuit board with wires coming from either end covered by frosted plastic.
That is the inverter, check the connections on the inverter (both sides) and power the laptop up to check the display, to remove it gently pull the plugs from each end and remove the screw from the middle and pull the board away.
Look on the back of the inverter itself for a copper coil, if you re-solder the solder points around the coil you may find it works again as components that suffer from extreme heat the solder joints dry causing bad connections, re-floating the solder solves the problem in 90% of cases.
Good luck.
Sep 15, 2009 | Dell Inspiron 1521 Laptop
The montitor goes black and/or the system shuts down after only minutes of use. a detailed test of the system did not reveal any problems.
Dear rdg5980,
Try to replace the battery (if it is a Laptop PC) or try to check the hinge or rainbow-cable that connect your Power to Monitor screen, it might be the socket little bit loosen.
GoodLuck!
Aug 12, 2009 | Dell Inspiron E1505, Intel Core 2 Duo...
Laptop inspirion 6000 screen went black, can only see shadows of windows but, it works. Please help. Thanks London
London the only option is to replace the display or the back light itself. If money is tight you then can use an external display but that does limit your mobility. I had a D610 go out on me but it would work if hooked up to an external monitor. Once I replaced the display it was fine.
Mar 18, 2009 | Dell Inspiron 6000 Notebook
MY DELL INSPIRION 2200
it might be due to problem with ram or your display adapter in the both the cases you have to open the case,
May 19, 2008 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
64 people viewed this question
Alun Cox
