Question about Dell PowerEdge 2600 Server
Adding a second processor to my 2600 server
Hey guys...I have been asked to add and second processor to our Poweredge 2600 server...two things...how do you open the server top on this model
and are there any particular protocols to follow when adding an additional processor to this box? i.e. other than shutting down and plugging in the CPU?
  • dashrr Nov 16, 2007
    thanks shadow!
    Problem Solver:
  • 7 Answers
I hope that you fixed your problem without troubles by now, but if you still have not, I can help. I added a second xeon processor to my Dell PowerEdge 2600 a couple of years ago.
Lay the server on its left side then loosen the three thumbscrews on the right front side and "slap" the cover off backwards.
You should have by now identified the current processor by running cpuid software that I think comes from Intel's website in order to buy an identical cpu. That was the hardest part, finding an identical one still for sale. If I remember the Poweredge 2600 could only use xeon processors with only up to 512 kb of cache or someother small amount and are not that available still new in the box.
You also have to get two identical voltage regulator modules (vrm). I was not able to get a second one for some reason and just bought two identical ones specifically for the xeon processors that I was using. Be sure to do your homework on this. MATCHING cpu's and MATCHING vrm's.
That's it. Each processor has two cores and you should see all four after you boot.
Another thing to think about would be setting the processor afinity to run your most intensive process to all four cores while only letting most applications to only use the first core.
I hope this helps if you haven't already had any success.
Posted on Jan 21, 2008
    Scholar:
  • 51 Answers
Some of the server cases require a key to open, check for a key lock on the case.
Dual processor systems are supposed to have matched cpu's. You may have to buy 2 cpu's that come as a matched pair. Of course you can try another cpu exactly the same as you have and nothing will be damaged but it may not work, or work well.
Posted on Nov 16, 2007
I m using DELL POWEREDGE 2600 loaded with windows 2000 server. There is a Internal Tap drive but i dont know how to use it. Can any plz help to how to use.
Thanks
a.rahman
Posted on Jul 05, 2008
I'm trying to start Microsoft Windows Server2003 from USB Hard Drive on Dell PowerEdge 2600 Server.
Dell provides lifetime tech support for all PE servers. Call them at 800-945-3355 and give them the service tag or express service code from the server. If it can be done, they will tell you how.
Feb 29, 2012 | Dell PowerEdge 2600 Server
I want to install windos 2003 server on dell poweredge 2600 but the server is very slow i want help
I am not sure what you mean by "slow" so I will anwer in general terms. I would recommend 1st that you make sure the PowerEdge meets the recommended hardware specs for Windows Swerver 2003. (Memory, CPU speed, Hard drive capacity, etc.) 2nd- I would run two Xeon processors instead of one and add as much memory as you can put in your system.
I run MS Server 2003 on one of my servers and here is the configuration that I am using:
2 Xeon 2.8GHz processors
6GB ECC Memory
120GB hard drive for the server operating system (Nothing else is on this drive)
750GB hard drive for all other applications
External NAS storage for files, data, etc. (connected to my netword via Ethernet 5e)
With this setup, my server has been running very well for 6 years now. I do maintanance every week on it to keep it up to par. (Simple dusting, checking cables, etc.)
Good Luck.
C2Solutions
Sep 11, 2011 | Dell PowerEdge 2600 Server
Hi , i have just put 2 new processor in my Dell Poweredge 2600. but now it is showing nothing on the Monitor - Please help
You can check process in System Information....to do this
Go to program>Accessory>system tools>System Information
OR chec in BIOS. It definatley list all h/W devices..Also Check if another monior is working
I can suggest to upgrade firmware..
Feb 16, 2011 | Dell PowerEdge 2600 Server
Can I install Windows home sever 2003 on a dell poweredge 2600
I would say yes so long as your server meets theses requirements
Minimum system requirements The following minimum specs are needed:[24]
Additionally, the following are required for installation of the operating system only:
Apr 16, 2010 | Dell PowerEdge 2600 Server
Dell poweredge 2600 wont load anything from hard-drives what do i do?
Go into CTRL-M, go to Configure>View/Add, accept and save Disk View if prompted, and check the status of each drive. What is your RAID configuration (F3) and the drive statuses? If you are in the States, call Dell support 8008228965 - it is free whether in or out of warranty. It will be much easier to explain what you see.
Mar 14, 2010 | Dell PowerEdge 2600 Server
What type of nic to add
Cannot be PCIe, as they are not supported - PCI or PCI-X. Check the slots, you may only be able to use 3.3/5V cards.
And as a sidenote ... the PowerEdge 2600 does not support x64 Operating Systems and does not support hardware-assisted virtualization (VT on Intel processors), so you will be limited on which VM solutions you can use.
Mar 06, 2010 | Dell PowerEdge 2600 Server
Poweredge 2600/Powervault 770N does not boot
I recommend that you first try replacing the power cord, if that doesn't work try replacing the power supply.
Mar 30, 2017 | Dell PowerEdge 2600 Server
Adding DVD to Poweredge 2600
PE2600 has lots of spare power (unless you are already using all 6 SCSI drive bays) ..
You can fit 3 x SATA drives in the space where the (useless) tape backup unit is sitting [you can even buy a 'proper' enclosure = Icy Dock MB453SPF or I think the SNT-2131 will fit ] .. and you can split the power off the Tape drive (4pin) power socket ..
I've not found a DVD burner (only a combined DVD reader / CD burner = TS-L462C) .. however if you have a spare IDE port you should be able to use an external unit [you will need an e-ide cable & enclosure for the drive]
Dec 11, 2008 | Dell PowerEdge 2600 Server
When the server turn on the monitor couldn't display anything
There could be several issues causing the problem. I am presuming the blinking orange light is on the monitor which usually indicates there is no video signal. So, the first thing I would do is re-seat the video card if it has one. The second thing would check would be the CMOS battery, verify that there is over 3.0v. After that if neither of these two things has fixed the issue more information would be required. What make is the motherboard, what is the processor, etc.
May 10, 2008 | Dell PowerEdge 2600 Server
Poweredge 2300 Configuration Help Appriciated :)
I have a older poweredge 2300 i get the following message run program setup.
Mar 26, 2008 | Dell PowerEdge 2300 Server
Dell PowerEdge 2600 Server Logo
946 people viewed this question
Alun Cox
