Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
How can I turn sound on with remote
Model#048541294 when you look it says variable speakers off how do I turn them on.
2 Suggested Answers
SOURCE:
  • 41 Answers
SOURCE: RCA 1997 TV - sound not working
check the speaker...for continuity...
Posted on Sep 03, 2008
My new Vizion tv has a vizion sound bar, the sound comes out with an echo, how do I correct?
Your TV speakers should be turned all the way down or off when you use a separate sound system such as a soundbar. Using them with the soundbar may cause echoes and the TV speakers do nothing to improve the sound.
Look at your TV's audio menu. If you can, turn the TV speakers off completely at the menu. Also see if you can set the analog audio output to "variable." This will allow you to control the soundbar's volume with the TV remote.
Jul 08, 2017 | Echo Computers & Internet
How to switch from fixed to variable audio
HI
please push the menu batten from remote & go to sound adjustment menu there is a option available that is speakers sound fix or variable
Mar 10, 2015 | Sony BRAVIA Televison & Video
My Sony Wega KP-57WS520 speakers do not sound and Mute is not on rather the variable sound, what can i do?
test the speakers and make sure connected and in menu make sure they are turned on.
The set if in variable may also mute the speakers in the set as that was mostly for a surround sound use.
Mar 18, 2012 | Sony KP-57WS520 57" Rear Projection...
TV speakers have switched off (i dont know how) how do i switch them back on again have used remote control to access sound options and does not seem to be a feature for on of off sound adjustment
Go into ur tv menu again,go to sound option again check what on the writing highlight on the tv SOUND SETTING now is it said VARIABLE SETTING.Than it is the sound setting problems,go into that highlight word VARIABLE SETTING just press the enter button on the remote to change it back to FIX SETTING.This should and will solved ur tv sound setting problems.If the sound setting already highlight word is said FIX SETTING.Than the tv have bad incomming broadcasting input signal cable or ur tv have bad or dead speakers problems to the tv itself.Not Sound Setting problems.
Apr 13, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Connect Bose System to Panansonic TV
in the tv setup menu there should be an item that will allow you to change the volume from variable to fixed on the output of the tv
Dec 07, 2009 | Panasonic Audio Players & Recorders
Use JBL Creature speakers (pc speakers) through tv
There may be a setting in the TV's menu to set fixed or variable output for the rca's. You want variable. Some have two sets of audio outputs for fixed and variable. Depends on the TV. Check those two things. If no help let me know what the TV is and we'll see what we can do.
Jan 25, 2009 | Onkyo TX-SR605 Receiver
Aug 04, 2008 | RCA HD52W58 52" TV
I cannot get sound out of the TV
Sounds like you have the variable audio out of your tv going to stereo, and variable audio means when you turned the sound down the sound off and then you have no audio. go through tv audio menu, you have fixed out, variable out, also speaker on and off, these need to be set for your application.
Jun 08, 2008 | Sony BRAVIA KDL-40V3000 Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
73 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
