I have a ao smith blower motor brand new with no paper work modle# 13227 how do you wire this for 120 volt
    Problem Solver:
  • 10 Answers
The wiring diagram should be on the side of the motor with nominclature
Posted on Jul 14, 2009
How to covert a 220 motor to a 115vac motor. ao smith rpm3450 3.hp 15 amps
If your label looks like this one and or if your label dose not have 120 as one of the voltages then you can not run the motor on 115 volts.
Apr 16, 2017 | AO Smith Pool & Spa
My new AO Smith motor ran for 15 mins amnd overjeated, Is it wired wrong?
check voltage and see side of motor if wired 220 volt wiring should be good if 120 volt have to move brown and white wires
Jun 08, 2014 | Smith AO Pool Pump Motor
New ao smith pool pump motor keeps tripping out under load
check the breaker might be weak possibly from previous pump motor also if it was hooked up incorrectly at first might have done damage to motor windings
Apr 17, 2014 | AO Smith Pool Pump Motor Hayward Swimming...
Need to change a goulds 1.5hp motor from 120 to 240 volts
should have info on side of motor, some motors cant be switched
Mar 19, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
BLOWER NOT KICKININ ON A NORDYNE FURNACE
Do you have 120 volts applied to the motor? Try spinning the blower wheel by hand, if this getsbthe motor running the capacitor must be replaced. If there is power to the motor and does not start up, the motor will have to be replaced.
Dec 12, 2012 | AO Smith Nordyne Furnace Motor 1/8hp 1050...
AO Smith C48l2pa105 WIRE DIAGRAM
read the wiring lay out on the motor
Jul 13, 2012 | AO Smith C48l2pa105
I need to wire my century pool/ jetted tub motor 1081/1795 where do the wires go? green white black
see side of motor for schematic usually black to L1 white to L2 green to case make sure wiring is changed from 220 to 120 come for 220 volt usually
Jul 02, 2012 | AO Smith A O Smith Motors Century 1hp 115v...
I want to reverse rotation on my A.O. Smith 120/230 volt single phase 1.5 HP motor. Catalog number B762
I believe all you have to do is swap your two hot wires,that works for 3-phase but not sure on single phase
Oct 07, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Am I able to step this motor down to 115 ? Plate specifies 230V.only
it depends on how many motor wires you have available to work with .. IF the name plate says 220 volts , not 120 / 220 volts , then no. If there are only 2 wires for the motor, then NO
thoughts?
Jun 23, 2010 | AO Smith 1.5 hp 3450/1725rpm 56J Frame 115...
Heating & Cooling Logo
231 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
