Question about Samsung DVD-HR735 DVD Recorder/HDD Recorder
Samsung DVD HR735 doesn't recognise DVDs
My Samsung DVD HR735 won't always recognize DVD's. Spits them out, even though they are the right region, have previously been played on the same machine and are playble elsewhere. Sometimes a DVD that has been rejected countless times will suddenly be accepted. It has been sent in for repair twice - didn't help at all. I'm going to throw it out as rubbish and advise against Samsung products unless someone has a solution.
Maria from Denmark
  • 24 Answers
It sounds like the laser in the DVD player is getting weak or has alignment problems. If the DVD that did not play in the samsung but played in others. I would tend to think its not alignment since you mentioned that it's been repaired before. Chances are the laser is weak but still within spec in order to prevent replacement. When My dvd players start to go they will generally stop recognizing burned media and thats your clue to replace it. They are very inexpensive to replace nowadays and have almost become disposable items. Probably not what you wanted to hear but it sounds like's like this player wasnt made very well.
Posted on Jul 13, 2009
    Problem Solver:
  • 4 Answers
The lazer focus is weak you can adjust the lazer voltage so it has more energy going into the lazer ie,voltage,is the pressure that pushes current ie, energy basically the lazer at present is not creating enough energy for the logic data,etc to return through the lazer,into the rest of the circuits to give you an image,sound etc on the screen,the wavelength of energy isnt enougth to reflect off the bottom of the dvd,cd etc,it,s best to let a proffesional to adjust the bias voltage to red lazer,as to much will burn any media disc you load,another way is to adjust the distance between lazer and disc,by adjusting the screws that fix the dvd drive height,little bit at a time,till there is enough data return ,ie load read ,picture etc,then when you get it to load,check whether there is enough lazer power,current,etc by seeing if it formats a disc if it doesnt,adjust a bit more till it does i did all this stuff with a panasonic ez 48 v,samsung 270 m,etc, samsungs tend to have a design fualt ie power regulation to the lazer i wouldn,t want another samsung player,cheers.
Posted on May 11, 2010
My samsung dvd hr753 will not tune to stations? Our region recently switched to digital so we no longer have analogue signals. Could this be the problem?
Yes this is your problem that you no longer receive an Analogue Signal.
This unit doesn't contain a Digital Freeview Tuner so you will need to purchase some sort of External Digital Freeview Box to connect to this unit to enable you to continue recording on it.
Jul 11, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
When i put a dvd in my hitachi htdk185uk it says unknown disc what does this mean
Either a DVD with the wrong region code has been loaded, and your player doesn't recognise it, or you have inserted a disc which is either rewritable (or an incompatible format for your player), a blank DVD or CD, or the disc has not been finalised in a DVD recorder. It depends on the disc(s) you have, whether they are region coded or those using a compatible playback format (finalised DVD-Rs are the best as far as burned copies go).
Examples of incompatible formats for your player may include;
DVD-ROMs
DVD-RAMs (which are the wrong version/speed for your unit)
Mini-DVDs/CDs
CD-RWs
DVDs with a different region code to your player or rewritable discs
* When using shop-bought DVDs, including those purchased online, make sure their region code matches your player.
May 25, 2011 | Hitachi DV-P315U DVD Player
Why can't l play DVD's recorded on this recorder on other player
DVDs come in different versions.
Try using the -R DVDs. Once your DVD recorder finalizes the DVDs they should on any DVD palyer.
Check your manual to find out the finalizing method for your DVD recorder.
I hope this solution is helpful. Let me know.
Feb 11, 2009 | Samsung DVD-HR735 DVD Recorder/HDD...
Samsung HDD SH853M doesn't work
What type of cable are u using to connect the TV and player.
Check those first, and reconnect if in doubt and post back
Rifaa
Nov 17, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Copying to hdd problems
Its not easy to copy a DVD, unless you have the proper software. Even then there is a lot of trial and error that you have to go thru. My suggestion is to findout whats the recording software that are used by both of the recorders and try to get around them by means of a computer.
Or alternatevly do the recording via a computer.
May 19, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Samsung dvd-HR735
Have you set your DVD player to the correct zone. You have to go thru the menu settings and select the correct zone for OZ.
Apr 07, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
My samsung dvd-hr735 now region free wont let me record onto dvd
Could be your using the wrong disc.
type is DVD-R where - is a minus as distinct from DVD+R
Feb 09, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Won't Read blank disc!!
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
Nov 18, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Copying
Likely if you burn the MP3's to a CD or DVD and finalize the disk.- try it.
Jul 31, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Open Questions:
See all Samsung DVD-HR735 DVD Recorder/HDD Recorder Questions
Samsung DVD-HR735 DVD Recorder/HDD Recorder Logo
1,758 people viewed this question
Jerry Greenberg
Jerry Greenberg
