SOURCE: replacing the battery in a 2001 mercedes benz
Battery base has a device that clamps the battery on a step/notch on the side. Use a ratchet with an extension to loosen. Once it is loose you can remove the battery.
SOURCE: Fuel Gauge not working for 2000 Mercedes Benz S500
you need to replace the fule gauge sending unit inside the fuel tank, as far as the waring messages go u need to have the system tested for a fault code that is stored when these lights come on, the requires a trip to the MB dealer.
SOURCE: My 1994 Mercedes Benz SL500 radio display turns on, but no sound?
I had same problem with my 1994 SL600. Also when this happens you will lose your interior door lights when you open the doors. My problem was solved by taking out the, A-white 40 amp 12V Relay and cleaning off the 6-prongs and reinstalling. It is located in the box underhood ahead of the main fuse box. Just need a phillips screwdriver. It is the fartherest relay in back left. I had to pull the one out in front of it to be able to remove the white one. You can hear it click when you push in dooropen switch. When working right you do not hear it. Hope this helps.
SOURCE: i need the mercedes benz 1999 clk 430 radio code
AR82.60-P-7502-01A Coding Radio
(MODEL all with CODE (750) Radio Becker Europa 2000 with CODE (751) Radio Becker Grand Prix 2000 with RDS)
AR82.60-P-7502-01B Coding Radio
(MODEL all with CODE (353) Audio 30 APS with CODE (510a) Radio MB Exquisit with traffic news decoder, with RDS (Becker) with CODE (512a) Radio MB Special with traffic news decoder, with RDS.)
SOURCE: How do I unlock the shifter on a 2000 Mercedes
No you do NOT need a new transmission.
This model Mercedes uses an electronic solenoid in the shift housing, to take the linkage out of park.
There is a small plastic part, activated by a solenoid that pushes a release, allowing the
shifter to come out of park. Most of the parts in the box were metal.
This particular part is plastic and very frail.
It is not an easy job, but any mechanic can do it.
