Question about Panasonic Televison & Video
LOSING DIGITAL CHANNELS AND TIMER SETTINGS
Hello, this is about the Panasonic DMR - EX78. I've noticed I've lost all my timer settings and all of my digital channels. This is a week ago after watching the Michael Jackson memorial. I'm left with analogue channels only and nothing else. I still have an old television which is an analogue not a digital television that doesn't have any audio ins or outs. Instead I'm utilizing a video for the ins and outs which is a very good quality LG player. This is placed on top of the dvd player. I've had no problems till now, it's been great. No problems with reception or antenna issues. What's happening? I have to re-program all my settings again as I've done nothing other than turn it on and notice programmed info missing. Television guide also gone. Things were fine till now. Let me know. Seb
  • 3 more comments
  • sabojams Jul 13, 2009
    Hello, yes I've removed the power point for 30 seconds and checked the antenna connection as well.
    No change at this point in time.
    Antenna plugged in firmly.
    Could it be the remote control?
    I'm still able to record programs from the analogue transmissions to the hard drive and the hard drive works fine, in storing these programs.
    I'm able also to copy or burn specific programs on to dvd.
    Let me know, any other ideas.
    Regards
    Seb
    I'm writing from Australia.
    No added lettering or numbers to the model of DMR-EXS78.
    Other details HD - 1920 X 1080p / 7 - Day EPG.
    Regards
    Seb
    Yes I can do this but will I lose any saved info like tv shows I've stored in the hard drive.
    Regards
    Seb
    Yes, it has worked!!!
    Auto-Set up was in the " to others " component of the Menu.
    Thanks
    Regards
    Seb
    Excellent, the solution was helpful.
    Regards
    Seb
  • 2,200 Answers
Hi
It may well be that the tuner has failed internally on the unit and it will have to go for service repair.
However - first I want you to disconnect all power from the unit - remove the power lead from the back of the unit if it has a plug in connection. Leave the unit disconnected for at least 30 seconds then reconnect and let me know that happens.
Whilst you are doing this you should check that your antenna connection is tight - remove and replace it and check that there is no short in the connector - digital signals are very prone to signal shorts whereas analogue signals can overcome these to a much larger extent.
If this helps please remember to rate my answer - if not post up a comment and I will continue to troubleshoot the issue - Many thanks.
Posted on Jul 13, 2009
  • 1 more comment
  • Radio Code Pro
    Radio Code Pro Jul 13, 2009
    No - this problem is definitel not related to the remote control. Would you mind confirming what country you are using the recorder as there is a model variation which I need to check. Also does the unit have any additional lettering e.g DMR - EX78 EB as this is important in regard to the tuner issue.
    Thanks.
  • Radio Code Pro
    Ok Seb
    I'm still looking at this but in the meantime I want you to do this and let me know if you get a result. This is a simple reset procedure for the unit.
    1) With the unit on press and hold Channel up and Channel down for 5 seconds this should bring you to the autostart menu - perform a full scan - make sure to let it finish right to the end. See if it is now storing channels.
    2) If this fails press and hold the on/off button for more than 10 seconds - this forces a factory default.
    Then perform the autostart procedure again in step 1 and let me know what happens
    Thanks
  • Radio Code Pro
    No - will not effect the hard drive at all. Let me know if you get a result.
My Eurosonic 7 day programmable timer doesn't activate. I've lost the instructions, are they available?
1) Eurosonic appears to analog timer:
http://waterheatertimer.org/How-to-set-timers.html
2) There is new series of digital timers from china, also sold as Eurosonic:
Copy following link for possible manual. Always reset digital timers before programming.
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
3) Add a comment March 2013 and describe timer in detail
Mar 10, 2013 | Hardware & Accessories
CODE Panasonic DMR-EX78
Here is the guide http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/DMR-EX78-_F click on the kid to down load and rate the star and voila
Feb 19, 2011 | Televison & Video
DMREX78EBK No sound on ITV when recording to hard drive and no sound after recording.
Assuming all other channels are working OK, with sound being saved along with pics, it may be easiest to rescan your channels from the setup menu. Certainly this is what I would do as a first step, and has worked for me on various other PVR devices when I've had odd problems like this on.
Note that this does not delete your hard disk recordings, but it will probably lose your timer settings, so make a paper note of any recordings you have scheduled so that you can recreate once the channels have been re-scanned.
Hope this helps!
Dec 04, 2009 | Panasonic DMR-E55 DVD Recorder
DVD recorder will not pick up digital channels from TV
Our DVD recorder DMR-EH57 is recording but not able to show its video
recording to the LCD what is the problem.
Nov 08, 2009 | Panasonic DMR-EH57 HDD Recorder Player
How do you set the time on Panasonic DMR-EX78?
Maybe slightly different on EX78, but on a E55 the time setting is done from the set-up menus.
These are found by pressing the Functions button on the remote control.
There is the option for "automatic" time adjustment. This uses the time data from Teletext if you have the unit connected to a suitable aerial/satelite/cable.
NB. if your unit only has an analogue tuner, i.e. it doesnt have it's own built in Freeview decoder, when the analogue service is withdrawn in the UK auto time update will cease to function.
Hope this helps.
Oct 08, 2009 | Panasonic DMR-E55 DVD Recorder
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
Panasonic dmr-ex78
Hello and thanks guys - I went ahead and set the player up and it is already region free. Cheers
Oct 01, 2008 | Televison & Video
DVD Timer not working
It usually means that if it doesn't record you don't have a blank DVD in the slot. Hope this helps =)
Nov 06, 2006 | Panasonic DMR-E95HS DVD Recorder
Televison & Video Logo
67 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
