Question about Garden
Attempting to put the electric 1400 psi back together but hose handle portion inside washer unit will not allow the unit to be closed entirely. Model # 2.55
  • 33 Answers
SOURCE: no pressure to handle
sounds as if pressure relief valve is stuck open. you will have to disassemble relief valve and clean or replace.
Posted on Apr 21, 2009
  • 548 Answers
SOURCE: leaking inside the casing. No pressure from the
sounds like the bladder or seals are shot they make a kit for this
Posted on Aug 22, 2009
  • 174 Answers
SOURCE: I have an electric power washer k3.99M. I just
This sounds like the hose is plugged or the nozzle itself is plugged. If the water cannot get through, the washer senses that the trigger is off and will not turn on the pressure. First just attach the hose without the gun and nozzle. If it pumps water, you know the hose is OK. Then attach the hose and gun ant try it. If it still works then you know it is the nozzle.
Posted on Aug 26, 2009
  • 124 Answers
SOURCE: I have a Craftsmen 1800 PSI Electric Pressure
Without more information than you have provided, I would think that yoour motor has been damaged by over use or by using too small an electric cord or too long a cord. The overload which is most likely a thermal overload is getting too hot.
Posted on Sep 15, 2009
  • 49 Answers
SOURCE: where can I purchase a
Well I don't know where you can get the exact hose but in my area there are company's who specialize in Hose's.
the place I buy mine is called EVCO . House of hose. Try looking them up .
They should be able to get you up and running in now time.
Posted on Feb 22, 2011
Just put in a new drain pump in LG front load washer and now I don't get any hot water. All the hoses are hooked up correctly. Is there something inside the unit when put back together that can bu
the drain pump does not effect the hot water intake that is or has to do with the water inlet valve , the coil may be bad or clogged try switch the hot and cold hoses and see what happens
some pumps do have an electrical connection? be sure to check for loose connection
other wise test with a meter
Feb 08, 2013 | LG WM2487H Front Load Washer
I was unable to get the water through the hose, but it did run freely from the washer with the hose off. I took the wand/handle apart to clean it and I am now unable to generate enough strength to compress...
Hi Bill,
Yea, I've had that same problem. What I have done is to put the spring in a vise to compress it, then tying the coils together with some thin wire, putting it on the "tool", then snipping the wires.
I hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 29, 2011 | Psi Sistema GT11 1400 PSI Pressure Washer
Where can I purchase a pressure hose for a Durabuilt Model DB1303 washer - 1300 psi 1.6 gpm?
Feb 22, 2011 | Coleman Powermate DuraBuilt 1400 PSI...
My karcher has a hole in hose close to unit can i cut it and put back in
if the hole is in the gun hose then no.
it will need to be replaced. try bunnings warehouse.
you may need to purchase the gun & hose together.
Dec 11, 2010 | Karcher PSI Electric Pressure Washer
Can't seem to separate the lance from the gun. Got the unit from an estate and it hasn't been used in 2 years.
hey there...
If the lance and hose have been sitting for an extended period of time, they may have rusted inside, and are likely to cause issues when they are put back in service. Usually best to replace the expendables like hoses and guns if they have gunked up. 1300 psi is not much, but with a restricted lance nipple, you're getting 700psi...
Jan 31, 2010 | Campbell Hausfeld 1,350 Psi Electric...
Where can i get a new hose for a1600 psi jet washer? Hose has a leak in it and we are not having any luck finding a replacement locally. Washer was purchased at either walmart or Canadian Tire.
I have an older Karcher Pressure Washer and I am unable to find the model number. This is the info that I have: 79C2, Volume 1.9, Pressure 1400, Serial # 800983493B, 120 Bar, 60 degree C,
QC506-877. I need the model # to order a replace gun and/or wand. thank you
Jul 14, 2009 | McCulloch FHH18A Electric Pressure Washer
I can't connect the garden hose to the water inlet. I am using a size 5/8'' hose but it wont connect to the unit. Please help!
Karcher electric pressure washers typically are supplied fitted with the male half of a standard Hozelock connector. You need the female half secured to the end of your hose, and then they just click together.
May 16, 2009 | Karcher PSI Electric Pressure Washer
WATER LEAKS FROM INSIDE THE 1400 PRESSURE WASHER
Replacing Compasster, where on the terminal block does the black and white wires go?
Mar 08, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Leak
post your model number for further assistance
Sep 03, 2008 | Haier XQBM22-C Top Load Washer
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
