FixYa.com
Tags:
NEC 10GB NOTEBOOK HARD DRIVE KIT FOR VERSA 6000 SERIES
ID Mainboard and BIOS Upgrade on PB Platinum 4001 -...
By Chandler - usenet poster
Can someone help me identify the mainboard on a PB Platinum 4001 (PIII
500). It says it has an AMI BIOSA6119p2 vers 1.83 but the AMIBIOS util
says its an NEC BIOS.
The system had a 10GB Quantum CX drive in it which has been replaced by
the user with a 40GB Maxtor. The BIOS does not recognize this unless
jumpered to limit cylinders - which gives only 32MB. I would like to
upgrade the BIOS so it sees larger drives like these.
David Longley
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 09, 2005
FixYa! (100)
Bomber
Bomber - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi David,
You should be able to just re-flash using your original ROM file. Did you back up your original ROM file before doing any of the flashes? If not then just use either version 1.83 or 1.90 from the PB site I gave you before
Rob
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Helpful (85)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
is there any way to recover from a bad flash BIOS?
In article <qso4JCAQhKN8E @longley.demon.co.uk>, David Longley
<D @longley.demon.co.uk> writes
David Longley
Solution #3
Not Rated (0)
Peter1
Peter1 - usenet poster
Rating: 0%, 0 votes
In article <a12gug$sf @news6.svr.pol.co.uk>, Unununium
<M @arms4.fsnet.co.uk> writes
Well, it went a bit worse than that. Some of the notes on the MSI site
are a little hard to follow when alternating between AMI and AWARD
loaders - I'm pretty sure the .txt file which accompanies the AWARD
files is wrong here.
Anyway, my problem was solved by just clearing CMOS by the board jumper.
However, there is a waqy of recovering from corrupt BIOS:
Boot Recovery Feature
For AMI BIOS:
Rename the desired AMI BIOS file to AMIBOOT.ROM and save it on a floppy
disk. e.g. Rename A569MS23.ROM to AMIBOOT.ROM
Insert this floppy disk in the floppy drive. Turn On the system and
press and hold Ctrl-Home to force update. It will read the AMIBOOT.ROM
file and recover the BIOS from the A drive.
When 4 beeps are heard you may remove the floppy disk and restart the
computer.
For Award BIOS:
Make a bootable floopy disk
Copy the Award flash utility & BIOS file to the said floppy disk
Create an autoexec.bat with "awdfl535 biosfilename" in the content e.g.
awdfl535 a619mj21.bin
Boot up system with the said floppy (it will take less than 2 minutes
before screen comes out)
Re-flash the BIOS & reboot.
There's an FAQ on the MSI board about what to do with the 6119 board and
40GB maxtor drives.... use AWARD 2.8 it says. Alas, that doesn't seem to
work with the PB board. Like all the rest of the AWARD bios images and
my board (at least), I get the red warning that the hardware is not
standard or something. It may just be that the user had a more
fundamental problem when his drive blew (the ASIC on the controller
board of the drive is literally blown. It may have been a short down the
cable from the motherboard I guess, and maybe there's something odd
about the mainboard now. Anyway - looks like I have tried all the
options available so unless someone knows of a BIOS that works with 40GB
drives like the Maxtor without these red warnings, I'll leave it here.
David Longley
Solution #4
Not Rated (0)
Charlie
Charlie - usenet poster
Rating: 0%, 0 votes
Hi David,
Have you tried posting at alt.comp.periphs.mainboard.msi­-microstar. You never know.
I also found this
Rob
Solution #5
Not Rated (0)
LiZzIe
LiZzIe - usenet poster
Rating: 0%, 0 votes
Hi David,
Its a Microstar 6119 V2 motherboard, a.k.a "Tacoma" board by PB. It uses AMI (American Megatrends) BIOS.
Go here for specs on the board http://www.uktsupport.co.uk/pb /mb/tacoma.htm
Go here for BIOS upgrades (PB Site) I've included both 1.83 and 1.90 versions. Just choose which one you think is best.
http://support.packardbell-eur ope.com/support/download/itemn r/REFBIOS...
If OE truncates any of the provided links just cut and paste the whole thing into your browser.
If you'd prefer to use MSI's BIOS's then go here
http://www.msi.com.tw/support/ bios/bios.php?model=MS-6119
As you can see there are also AWARD BIOS available, and IMO they give more options over the AMI BIOS's, especially the ability to upgrade to larger HDD's. By the looks of it anyway all the AMI BIOS's look dated so if you specifically wanted the AMI BIOS then I would use the ones from the PB site above. However, If you decide to change to the AWARD BIOS then follow the instructions on this page http://www.msi.com.tw/support/ bios/note.htm Look right at the bottom of that page for the specific instructions on changing from AMI to AWARD. There you will also find the utility for flashing the BIOS.
If you need anymore help post back here.
Rob
Solution #6
Not Rated (0)
Rachel007
Rachel007 - usenet poster
Rating: 0%, 0 votes
Many thanks,
Before reading your note I downloaded the AMI utility which purports to
identify your motherboard - it came back saying it was an NEC BIOS. Odd
that as it clearly announces itself as AMI A6119P2. I'll go and have a
look at the upgrades, but I'm still puzzled as to why the AMI utility
reports it as NEC....
In article <a11rqi$eo @news8.svr.pol.co.uk>, Unununium
David Longley
Solution #7
Not Rated (0)
Melissa
Melissa - usenet poster
Rating: 0%, 0 votes
Thanks - that explains that.
I have, since last posting, downloaded the latest AMI and AWARD BIOS
images and tried both.
The 1.90 AMIBIOS makes no difference re recognition of the 40GB drive
without it being jumpered to limit the cylinders.
The two latest AWARD BIOS images load OK, even see the larger drive as
its full capacity *BUT* there's a series of bleeps accompanied by red
warning that there is a hardware problem. It continues to boot OK, and
seems to run OK, but the message doesn't go away regardless of what you
do  in SETUP.
Looks like one is stuck with 1.90 and rejumpering the drive to less than
the full capacity. Anyone made any more progress?
In article <a121tj$i5 @news8.svr.pol.co.uk>, Unununium
David Longley
Solution #8
Not Rated (0)
kioner
kioner - usenet poster
Rating: 0%, 0 votes
Hi David,
NEC / PB same people
Rob
Can you Help with these Hard Drives problems?
Hard Drives
USB Plug and Play stopped...
My Beyond Micro 250GB Mobile... Answer This...
Hard Drives
necesito driver de sonido
sony vaio instal? windows vista... Answer This...
Hard Drives
PROGRAMS TO DOWN LOAD MY FS10...
i want to find a good program... Answer This...
Hard Drives
drive not detected in Mac
I had used the Maxtor OneTouch... Answer This...
Hard Drives
My external hard Drive DIGITAL...
My computer doesn,t noticed it... Answer This...
Repair Service
Find Hard Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
