Question about Dell TrueMobile 2300 Wireless Broadband Router (TM23001)
How do i put the static ip information into this specific router. truemobile 2300
    Sniper:
  • 70 Answers
You need to get into the ip address of the router's settings and assign a static ip address to the specific hardware you are trying to connect. Most routers use some combination of 192.168.x.x where the x is a combination of either 1 or 0. Check with the router manufacturer to find the correct ip address. Good Luck
Posted on Jul 29, 2009
NEED HELP TO SETUP MY TRUEMOBILE 2300 ROUTER TO MY DELL LATITUDE D600 LAPTOP. I HAVE BEEN TRYING TO GET WIRELESS CONNECTION. WHAT I DO HAVE , 1300 TRUEMOBILE PC CARD PLUG IN. WHAT I DON'T HAVE IS A...
The Network Key you're probably asking for is on a sticker located, underneath the router. Can you check?
Here's a way to configure your router for your existing network (assuming you already have one) :
If you have an existing network, chances are you have already configured network services on the network. In this case, you would use the router as a pure Access Point to extend the range of your network by allowing more attachment of wireless and wired computers. You MUST also turn off the DHCP server on the router if there is a DHCP server running to avoid IP address conflict.
To configure the router as an Access Point with the DHCP server disabled:
  1. Open your web browser and go to http://my.router, (or the default address http://192.168.2.1.)
  2. Click the Basic Settings tab on the top navigation bar.
  3. Select Access Point Mode.
  4. Click the Next button.
  5. Click OK to dismiss the DHCP disabled message box (The DHCP server will be disabled in Access Point Mode by default).
  6. Click the Advanced Settings tab on the top navigation bar.
  7. Click the Advanced IP Settings tab on the left navigation bar.
  8. Assign an IP address to the Wireless Broadband Router.
    note.gif NOTE: The IP address should be reserved by the DHCP server. The Wireless Broadband Router cannot act as a DHCP client, therefore, it needs a static IP address for its LAN interface.
  9. Click the Submit button.
  10. Click the Save & Restart button.
  11. Note the status bar at the bottom of the screen.
  12. While the Wireless Broadband Router resets, the Power light on the front of the unit blinks.
  13. When your web browser returns to the main page of the Wireless Broadband Route, the device has successfully restarted with the new settings.
    note.gif NOTE: The main page may not return if you have changed IP address of the router in Step 8. To view the main page, type the new IP address of the router in the web browser to access it.
  14. Plug an Ethernet cable from the existing local network into any LAN port on the Wireless Broadband Router.
Jul 01, 2011 | Dell TrueMobile 2300 Wireless Router...
How do I secure my wireless router? dell truemobile 2300
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Apr 21, 2010 | Dell TrueMobile 2300 Wireless Router...
I HAVE AN OLDER TRUEMOBIL 2300 WIRELESS ROUTER WERE ARE THE KEY CODES TO MAKE IT SECURE OR DO I ENTER MY OWN AT RANDOM?
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Thanks for using FixYa.
Dec 22, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Setting up a w.less repeater using an old w.less b.band router
Temporarily plug in wire network cable into Dell and log into Dell.
1. Set wireless up the same as the Belkin. Save these settings.
2. Set WAN to "Static IP Address and give it an address about 25 higher than Belkin. (Belkin 192.169.0.1 - Del 192.168.0.26). Save these settings.
3. Disable DHCP and Save these settings.
Exit web browser and disconnect network cable. Restart your complete system, first the Belkin, then the Dell, then your computers.
This way, the Belkin is running and able to assign IP addresses to all that start after it.
Jun 11, 2009 | Dell TrueMobile 2300 Wireless Broadband...
I need to open my Nat for Xbox live. Please Help!
Configuring Your Dell™ TrueMobile™ 2300 Router for Gaming
Follow below steps to set up the router for gaming:
  1. Select the system or systems to be used as game systems.
  2. Locate the MAC address. For Windows 2000 and XP
    1. Click Start -> Run.
    2. Type cmd, and click OK.
    3. On the command prompt, type ipconfig /all
    4. Write down the MAC (Physical) address of your computer to configure for gaming.
  3. Open the web browser, and type http://my.router (or http://192.168.2.1)
  4. Click the Advanced Settings tab.
  5. Click the DHCP Server Settings tab on the left navigation bar.
  6. Click Add button in IP Address Reservation,
    1. Enter the MAC address of the system you wish to use for gaming in MAC Address field.
    2. Enter an IP address for the system (select a number between 101 and 254)
  7. Click Submit.
  8. Click the Port Forwarding Settings tab on the left navigation bar.
    1. To set a single computer for gaming, check the Enable DMZ Host box.
    2. Enter the IP address of the system at DMZ IP Address field.
    3. Click Submit.
      note.gif NOTE: Only a single computer can be set for DMZ service. To set multiple computers for gaming, please post your query again
  9. Reboot the client system. The client system will use the newly assigned IP and will not have any TCP/IP ports blocked by the firewall feature of the router.
May 18, 2009 | Dell TrueMobile 2300 Router (000001)
Dell Truemobile 2300 - cannot connect to internet
This is usually a router configuration issue. The router has to be configured to match your new broadband settings.
For example, your old DSL may have required some kind of login which was entered into the router. For most broadband cable connections, you set the router to get an IP address automatically.
Re-run the router Setup Wizard. You can download it here:
http://ftp.us.dell.com/network/R74885.EXE
Jan 26, 2009 | Dell TrueMobile 2300 Router (000001)
Network key for truemobile 2300
need more information for your problem.
Oct 16, 2008 | Dell TrueMobile 2300 Wireless Router...
Truemobil 2300 cannot access internet via wireless
Is there a computer or another device connected to this router that can access the internet?
IF yes -- by wire?
IF yes - by wireiess?
The more of the above that is true the less we need to research.
Initially I will assume (until informed otherwise) your router is working both via the wire and wireless to the internet.
IF you have a working wireless computer --
When it was configured did you load an wireless SSID (name)?
Where you required to enter a passpharase, password or network key?
Did you provide any entries to the following fields during configuration for the computer's wireless.
IP Address --------- (like 192.168.1.?)
Subnet Mask -------(often 255.255.255.0)
Default Gateway - (router lan address like 192.168.1.1)
DNS Address ----- (maybe the router lan address or
---------------------------- as supplied by your
-------------------------------- internet service provider)
Being able to answer the above is a requirement for completing the steps outlined below
The generic connection and configuration document
http://www.microsoft.com/windowsxp/using/networking/setup/xbox.mspx
This is a good description of possible router options. These suggest strongly the creation of a static IP address for the XBox to enable all functionality in the online environment, if desired.
http://www.ianarchbold.com/xboxlive/index.html
If you need assistance setting this up in your environment leave a comment on this problem and I will respond.
Dec 25, 2007 | Dell TrueMobile 2300 Wireless Broadband...
Truemobile 2300 router
You may need to enable the wireless signal within the router settings, but you will have to connect to it via an RJ45 lan cable, as you would of when you first set it up. Type in the routers ip address in your internet browser and get into the routers settings that way.
Mar 24, 2007 | Dell TrueMobile 2300 Wireless Broadband...
Dell TrueMobile 2300 Wireless Broadband Router (TM23001) Logo
129 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
