Question about Samsung SC-D23 Mini DV Digital Camcorder
Picture problem camera powers on but no picture is on screen you can record but still get no picture screen stays black in record mode and standby mode any suggestions thanks
Re: picture problem - Samsung SC-D23 Mini DV Digital Camcorder Video Cameras
The CCDs that they sent out are bad
Posted on Dec 29, 2007
Re: picture problem
I contacted samsung today after finding out this was a frequent problem with this model camera and they told me they area ware of the problem and offered to fix it for free or send me a refurbished one for free. I opted to have them fix mine.. They said they are sending me a shipping label that I should receive by Monday. It will take them 7-14 business days to fix and they will send it back. It might be worth a try caling them. (I bought my camera in 2003 and I guess the camera's made close to that date had a malfunction that they will fix even though the warranty is expired.
Posted on Dec 06, 2007
  • 64 Answers
Re: picture problem
If you can still see the menu and functions on screen and the lens moves in and out when you zoom the it could be a mainboard problem or a flex has come loose somewere.
Posted on Nov 19, 2007
0 characters
3 Points
Goes from record mode to standby automatically
Wow my friend do you need Ghost Busters? er no this is mostly a case of the main switch being on lock, or the main IC going down on the panel in the cameras brain area, check the locks first, if it is the chip you will need to call your Sony repair man (He will love you) with summer coming he will be able to go on longer holiday, because that wont be a cheap mend sadly.
Number for help then is 01256 828828, now what you will do for cash for your holiday I simply do not know.
Take care, hope it gets sorted out okay?
Jun 04, 2010 | Sony Handycam CCD-TRV57 Camcorder
When I turn on the camera, nothing happens and the screen/view finder is blank. i checked the standby switch its off. when i press record it will record but on the tape it is just a black screen? any ideas...
i know exactly whats wrong! the same thing happend to me.
1. turn off the gl1 2.look at the record button with the lock and standby switch 3.flip the switch all the way to standby because it might be stuck in the middle 4. turn on your camera
Dec 03, 2009 | Canon GL1 Mini DV Digital Camcorder
LCD Screen Stays Black
Had the same problem. It nearly drove me mad, however, the fix seems quite simple. The screen in playback mode seemed to be fine but if I swithed to record or photo mode I just got a black screen. I could see some pixel movement so I figured the screen was okay and that the iris was the problem.
Anyway, to fix it I simply gave a few sharp taps on the camera body near the lens. This unstuck the iris and I was greeted with a clear image in the LCD viewfinder. The camera now works fine.
By the way, this seems to be a fairly common problem with a lot of the different models and not just limited to this one.
Hope this helps.
Nov 25, 2008 | Sanyo Xacti C6 Camcorder
Sony camcorder DCR 265E
i think you are in picture mode when the screen mode is changed then it will appear black and recording cannot be done beeing in that mode you have to change the screen mode into recording mode and then continue
May 25, 2008 | E.Digital Sony DCR-TRV265E camcorder Pal
Sony dcr-hc20e problem on screen in standby mode
my computer is unstalling all files and now my cd software to my sony dcr-hc20e digital video camera recorder was lost.pls help to find a free cd software to my sony dcr_hc20e digital video camera recorder
Mar 13, 2008 | Sony Digital Mini DV Pal Camcoder...
Black screen/record/playback.
lcd ribbon is bad have to send in for repair
Dec 26, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
No picture in LCD or viewfinder
Flexwire in electronic viewfinder (EVF) is broken, you need pro fix.
May 19, 2007 | Canon GL2 Mini DV Digital Camcorder
Sony TRV-19 Camcorder - Black screen in camera mode
Fixed it, at least temporarily I had the side off my trv250 examining it, especially the CCD connection. I had read the post about soldering a capacitor to pins 1 and 3 (from the left) on the bottom row. I didn't have the specific capacitor on hand, but I started touching some of the small ones I did have to those pins. I found that after I touched a 100uF, 10V cap to pins 1 and 3 the picture suddenly came back to life and stayed that way after removing the cap. I have no idea how long this will last, and I've set up the cam on a tripod in the livingroom with the LCD display facing me so I can monitor it. If you, like me, figure you have nothing else to lose, you might want to give this a try. Note: my camera was suffering from the green smeary horizontal lines problem, and wasn't completely black. I'm not sure if this makes a difference or not.
Sep 14, 2005 | Sony DXC-190 Camcorder
Black bars in the picture
For Models: CC4352, CC4362, CC4393. Your camcorder has a wide format recording mode that lets you make recordings compatible with the 16x9 format. When 16x9 is activated, the camcorder records black bars at the top and bottom of the picture to produce the wide-screen (movie) effect. This is also known as "letterbox" recording. Do not use this mode unless you have a compatible 16x9 TV. When played on a regular TV, black bars appear on the screen. If the 16x9 feature is activated on your camcorder and you want to turn it off, press REC/PAUSE to pause recording, and repeatedly press DIGITAL EFFECTS until no digital effects display appears.
Sep 06, 2005 | RCA CC-432 Camcorder
Samsung SC-D23 Mini DV Digital Camcorder Logo
168 people viewed this question
Top Samsung Video Cameras Experts
Pieter Vleeshouwers
Chris Hunt
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
