Question about Jenn-Air JES9800BA Electric Range
The double ring not working, the smaller ring is still working. How can I fix it?
  • angelasung Jul 14, 2009
    Thank you. My range is electric smooth top, is it remove the same way?
  • 54 Answers
Your burner is going out if it is the pull out one you can pull it out and either go to a appliance store or home depo and get a new one and put it back in and it should work great ...
Posted on Jul 14, 2009
NEED A BELT FOR TECHNICS DISC CHANGER MODEL NUMBER SL-MC400
take the belt to your local ace hardware and look for an o-ring that is slightly smaller than the stretched out belt. this will work just as well.
Mar 01, 2015 | Technics SL-MC400 110-Disc CD Changer
GE Spectra Dual Burner not working.
the burner is faulty
replace just the upper part of the brner
or try to clean it
yourself
Sep 16, 2008 | GE Spectra JBP78 Electric Kitchen Range
Replacement parts
Take the broken belt to ace hardware and find an o-ring that is the same size.
Jan 10, 2015 | Technics SL-MC700 110-Disc CD Changer
Reader for a square format 5.25 IBM formatted disk?
You can purchase an old 5.25 disk drive that will fit into any PC that has an open bay or swap out the smaller one for the 5.25 one.
Almost all computer shops have lots of them still around.
Mar 27, 2014 | Verbatim 30 Datalife Plus Md2-d Ds/dd...
Finding area of a concentric circle
You find the area of the larger circle. Then find the area of the smaller circle. Then to get the area of the ring, you subtract the area of the smaller circle from the larger circle.
So basically:
Area of larger circle - Area of smaller circle = Area of ring
http://www.vitutor.com/geometry/plane/concentric_circles.html
pi. r2 = area 2pi. r=circumference of circle.
Read more: http://wiki.answers.com/Q/What_is_the_Formula_for_concentric_circle#ixzz1Cv8wAOJf
Jan 30, 2011 | Computers & Internet
I have a model No.CCE3401Q electric cooktop and the left rear burner with a double ring only heats up (and lights up) on the outside ring and not the inside. What part do I need and do I need a repair...
ring neds to be replaced or try to first remove it by pulling it out and cleaning the contacts and then replace it if this does not work then replace with new one this is a simple fix .. u can do it yourself just replce with likere type
Dec 03, 2009 | Jenn-Air Cooktops
Oil leak
If it's leaking from the oil filter spacer.( the 2 inch metal ring that attaches to your block, and has two rubber hoses coming out of it, and your oil filter attaches to) There is an o-ring between the spacer and the block. Take off your oil filter, remove the oil filter stud with 1 3/16" socket( or metric equivalent) and the spacer will come off. I found all the auto parts stores around me said that the o-ring was a dealer item. I bought a FRAM PH3387A oil filter and removed the o-ring on that. It fit perfectly, snug down your oil filter stud to specs, then install your oil filter. Double check that the oil filter is not double gasketed, and your are fixed!
Jan 31, 2009 | 1995 Honda Odyssey
Need to change ring on fax to 3 rings. it is an hp office-jet 6110 all in one
  1. Press Menu .
  2. Press the right arrow (>) or the left arrow (<) until Advanced Fax Setup displays.
  3. Press Enter .
  4. Press the right arrow (>) or the left arrow (<) until Answer Ring Pattern displays.
  5. Press Enter
  6. Press the right arrow (>) or the left arrow (<) until the desired ring pattern displays.
    • Single rings – The fax machine answers after a single ring.
    • Double rings – The fax machine answers after a double ring.
    • Triple rings – The fax machine answers after a triple ring.
    • Double and triple – The fax machine answers after a double and triple ring.
    • All rings – The fax machine answers any ring. This is the default when not using Distinctive Ring.
  7. Press Enter .
May 09, 2008 | Office Equipment & Supplies
CS50 headset with lifter not beeping when away
It is the handset lifter that actually picks up the ring tone from the telephone, and not the CS50 itself. The first thing that you want to do is make sure that the ring tone or ring volume didn't change on the phone, because this could throw off how the lifter "hears" it. Also, I'm not sure which lifter your user has.. if it's the larger HL1 (this one has a base that the phone sits on), there is a sensitivity adjustment on the back of the lifter. If is the smaller HL10 which sticks onto the phone (and should be positioned over the speaker grill where the ring tone comes out of the phone), the internal mic may have stopped working and that could be why it doesn't hear the ring anymore. If you have the HL10, you can try using a ring detector cable, this is a little accessory that should have come with your lifter (it looks like a wire with a small speaker on the end of it with double-sided tape). Plug this into the back of the HL10 (there are 2 jacks back there but it will only fit in one, you may need to remove the rubber plug), then stick the little speaker over the speaker grill on the telephone. If this doesn't work, you may need to replace the lifter. Here is a link below with a picture to take a look at the ring detector. Plantronics 46780 01 Ring Detector Cable PLX Headsets Direct
Aug 25, 2017 | Plantronics PL-CS50 Professional Headset
Jenn-Air JES9800BA Electric Range Logo
90 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
