Question about SmartParts SP-DPF56E Digital Picture Frame
I put pictures on a san disk sdhc memory card unformatted & formatted the card is 4gb won't play on my kodak sp-dpf56e picture frame why?
    Scholar:
  • 119 Answers
I couldn't find very specific information about your picture frame. I did find out it is from a company called Smart Parts and it is not a Kodak frame.
If I had to guess, I would say that the frame is not SDHC compatible. What this means is that it only will work with cards up to 2gb (SD).
I saw a review site (http://www.reviewcentre.com/reviews115912.html) that had a lot of reviews about how the frame does not like to read jpgs from the SD cards so this could be the issue if the one above is not.
My recommendation would be to try to use a 2gb card. If that does not work, try loading the pictures onto the frame directly from the computer.
Posted on Jul 13, 2009
Kodak EX 1011 does not recongnize memory card
On the contrary. The EX1011 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and the frame will not recognize it as a memory card. You need to use SD cards, 2GB and smaller.
Jan 31, 2012 | Kodak EasyShare EX1011 Digital Picture...
I have a san disk 2gb memory card for my nokia phone, i took my memory card out for the first time as i wanted to put the pictures from it onto my computer, everything worked fine, however when i put my...
you can not format your card without loosing data on it. The solution is to copy all the data to your computer, format the card (in your computer, still) and then copy the data back.
Hope this helps,
Lucas
Jul 10, 2011 | SanDisk 2GB microSD Memory Card
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
Kodak easyshare M1093 refuses to format disk
The recommended card for your camera are those SDHC type or 2GB-16 GB SDHC card, try to use at least 2 SDHC card if this failed it means the memory card reader of your camera is already defective. Just in case this will happen try to contact Kodak at 1 800 235 6325 ext 12.
Feb 09, 2010 | Kodak EasyShare M1093 IS Digital Camera
Just put in new san disk 4gb memory card and receiving error message - memory card error. I unlocked memory on card itself (that little gray sliver that goes up and down) What gives
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 21, 2009 | Canon PowerShot A610 Digital Camera
I have a D5000 Nikon and a Panasonic SD/HC 4GB card. I have formatted the card and taken a number of pictures. I have loaded the necessary soft ware supplied with new camera but cannot download any...
If you are using a card reader of some sort (other than using the camera to download the images), it may not be SDHC compliant. Have you tried using the camera to download the images via the supplied cable? If you've taken the images in RAW format, that could also be the problem. Try using a 2gb or smaller card in the camera to take some images and then download them using your usual method. If it works with the 2gb card but not with the 4gb, it's likely your reader isn't SDHC compliant.
Sep 27, 2009 | Nikon COOLPIX L3 Digital Camera
Memory card
I have looked at the specs for your camera and you should be ok, if you are using SD or SDHC memory cards. As far as the computer you are using to read the cards, not enough info. to comment on that. One possible way to see your pictures on the 4gb or 8gb cards on your computer would be to leave them in your camera. Use the USB cable and connect your camera to the computer. With your camera on it should recognize your card in the camera as a storage device at the least. Click on it and you should be able to manage them on your computer. Hope this helps.
Jul 07, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Lexar SDHC Card from Kodak Easy Share, disk not recoginized
Honestly, it is most likely a defective memory card or not compatible with your camera. Sorry.
Mar 23, 2009 | Lexar Professional High-Speed 1GB Secure...
SmartParts SP-DPF56E Digital Picture Frame Logo
540 people viewed this question
Top SmartParts Photography Experts
Joseph Hoffmann
Tony
Are you a SmartParts Photography Expert? Answer questions, earn points and help others
