Question about Denon Audio Players & Recorders
Hello, i am braziliam people and my receiver is a avr-1604 when i turn on,the equipament turn off in mor or less 3 seconds. please i need some information or the service manual because this receiver is not brazilian factory. thanks CIANCI
  • 4 Answers
Just checking...you are plugging into the right voltage (110 or 220V), right?
OK, it could be a short in the speaker wires. Try disconnecting the speaker wires at the back of the unit and try again.
Most likely: Others have found a defective 15V voltage regulator. If you know what you're doing, you can check these and other power supply components (rectifiers and filter capacitors, for example).
Another possibility is a short in the amplifier section.
Posted on Jul 13, 2009
How I do to make my DENON AVR 1604 to full function?
Press the surround mode for 7 channel stereo
Sep 10, 2014 | Denon AVR-1604 Receiver
I have a denon AVR-1604. It was working fine but started to hear a relay clicking on and off as it was playing. Now when i try to turn it on from standby i hear the relay click as i turn it on with the...
the noise is the speaker protection switch ( reset relay) disconnect all speakers see if it stops if so then conect speakers 1 by 1 untill you find the crossed speaker could just be a crossed wire best of luck
get me back if you need more help
Dec 31, 2010 | Denon AVR-1604 Receiver
I need manuel for denon 1604
You can download the manual from the manufacturer's web site at
http://usa.denon.com/US/Downloads/Pages/InstructionManual.aspx?FileName=DocumentMaster/US/AVR-1604_684_ownersmanual.pdf
If FixYa screws up the formatting, it's
Jul 12, 2010 | Denon AVR-1604 Receiver
I have an AVR 335 less than 3 years old no sound
Hello
Yes, there is something you can try, to know where to look for the problem if this happens again. If the receiver is still under warranty, just send it back, otherwise, open up the amp and trace the path back from the speaker channel to the capacitors on each channel, this is usually the problem(you should be able to see if it is blown, cheap to repair).
If all the channels went out at the same time, there is something wrong with the central unit, to repair that, if it is not the above problem, cost expensive.
Hope this can help you.
Kind regards
Andrea
Nov 09, 2009 | Harman Kardon AVR 335 Receiver
Denon AVR-1604 too large front speakers blew the avr
Try disconnecting the speakers at the receiver. turn it on radio or any other source and turn up the volume. If the receiver still shuts of, there is an internal capacitor issue and needs serviced. More than likely though, it's a speaker problem. If the speakers were underpowered and at max volume, chances are the damage was to a voice coil in one of the speakers. If the receiver continues to stay on without being connected it's ok. check your speaker wires as well. Frequently loose braids on wires touch each other and create very little resistance until turned up, more volume, more resistance. Then the receiver puts itself into protection mode so no damage will occur. If you need further help, post a comment and I can help you troubleshoot further.
Aug 17, 2009 | Denon AVR-1604 Receiver
Denon AVR -1604 Powers off after 3 seconds
Check in the amp section for a short on the output transistors. It may need a resistor or two also. I doubt that it would be in the power supply.
Jan 31, 2009 | Denon AVR-1604 Receiver
Powers turns on then off
faulty power amp output section occurs this problem.
canyou open the cover and are you technicaly sound to do the repair.
nuwan.
Jan 19, 2009 | Denon AVR-1604 Receiver
Receiver won't turn on
has 2 zener diodes and a 12 volt regultor defective in the regulator circuit on the main board, may also have a cap or 2 near the 12 volt reg. ref# u703
Apr 19, 2007 | NAD T752 Receiver
B Speakers: Rear A Speakers and Sub stay on
First, check you wiring. Have you tried to turn off all speakers then turn on only the "B" set?
Might also be your "surround" settings. Try a "2" channel mode if available.
GL!
Aug 09, 2006 | Denon AVR-1604 Receiver
112 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
