Question about Maytag Neptune MDE5500AY Electric Dryer
What wires go to which colors while hooking up the dryer plug
    President:
  • 704 Answers
Normally a 220V-AC dryer plug will have three (3) wires. Two (2) of these are 120 V-AC each while the third one is the ground wire. The dryer cord (plug set) will have three (3) prongs and three (3) wires with either ring or fork terminals on the other end. The ouside wires are the voltage supply, while the center (middle one) is the ground wire. Your manual should also show this in the installation section for your unit.
Connect them using the installation guide for your dryer, which should show the two outside connections for the power, while the center connection should show as the ground, but BE CAREFUL and check to be sure before plugging in the plug/cord set into the wall 220 V-AC receptacle!!
Typically, newer appliances have a green colored nut/screw indicating the ground connection/conductor.
Posted on Jul 13, 2009
Four prong cord three prong outlet
Ok this is how you will wire the three prong to the dryer.
You have 2 wires that are gold/brass in color, those are the hot wires.
You have 1 wire that is crome/silver in color, that is the neutral
On back of fryer where you wire it you put the wires on like this right to left Gold/brass hot, silver/nuetral, then the other hot wire.
On back of dryer you will have screws from right to left this color gold/brass, silver/crome, then gold/brass again.
If you do have a 4 wire cord the extra wire is ground and you screw that to the machine body.
Mar 14, 2010 | Roper RGS7646KQ Gas Dryer
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
I need to change the 3 wire plug on my whirlpool model LE5790XS dryer to a 4 wire plug...old one is not color coded and I dont want to hook it up wrong...whats the correct way to connect this plug?
To install your 4 wire plug ,the white wire goes to the center wiring terminal on the dryer. The green ground wire attaches to the terminal cover screw outside the dryer. The red and black wires go right and left on the dryer terminal.
Nov 12, 2009 | Dryers
Hooking a 4 wire power cord to a dryer that came with 3 prongs
*First ; before starting unplug unit or shut off breaker.
you should be able to match up color for color on your dryer, the fourth wire, green (ground) screws to the chassis, or cabinet. if your wires aren't coded as you say, it is red, white and black, left to right. see picture I've supplied.981ddeb.jpg
hope that helps
good luck
Sep 26, 2009 | Whirlpool LER4634J Electric Dryer
I need to change the 4 wire plug to a three wire plug.
The center wire is usually the ground wireGREEN and the other two don't matter
Jan 16, 2009 | Kenmore 62602 Electric Dryer
Replacing plug
ok on a drier on your terminal block the center wire is neutral the other two are hot on a four prong cord the green or ground wire connects to the body of the drier if the dryer already has a green wire coneccted to the body of the dryer then take it loose and hook it to the neutral terminal of the dryer then hook the green wire or ground of the cord where it was if you need any more help let me know
Mar 30, 2008 | Amana NDE2330AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
208 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
