As I have mentioned in another post you may have accidentally put the battery in backwards look at the top off the battery you will see 3 copper connections now look into the camera
you will see there are 3 connections in there.. line them up and drop
it in until it clicks if you still cant power up you may have to charge
it first.
plug the camera into its charger and leave it to
charge for 20-30 min remove it from charger and try to get it to boot
if it boots great you can put it back on the charger and let it finish
if it still wont boot you should take the camera, battery and charger to the store you purchased from they will most likely try a new battery in it if it still wont boot it needs to be returned. I hope this helps
Put the batteries in backwards. Sounds weird but it worked for me.
SOURCE: looking for manual for Kodak EasyShare C913 digital camera
Hey
theres a online user manual available here
http://www.kodak.com/global/en/service/publications/urg00898toc.jhtml?pq-path=13177
or heres a extended user manual with more content
http://www.kodak.com/global/en/service/publications/urg00897toc.jhtml?pq-path=13176/13178
SOURCE: I got a new Apple Imac computer a couple of months
Sounds like your software is faulty.
Please delete your current ESS software and reinstall.
Please follow the link in order to download the latest ESS version:
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=13176/13179&product=EKN035311
SOURCE: I just put new batteries in my kodak easyshare
Make sure you are using rechargable batteries. Normal batteries are not
strong enough. Try using either rechargable Lithium Ion batteries, or
rechargable Nickel Metal Hydride (NiMH) batteries. These are much
stronger and should give you a good battery life.
Let me know if this helps :)
SOURCE: Trying to install by Kodak easyshare c913 on to my
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
SOURCE: Kodak Easyshare Z1285 won't power all the way on.
you have a capacitor that will not hold a complete charge to power your camera. Capacitors are made to hold a certain amount of voltage to operate functions fully. If one of these capacitors gets a hairline crack they will lose their power causing a problem such as you have here.
Each function has it's own capacior so that is why the other functions are working still especially when it shuts off automaticly after you turn it on. Upon turning it on the camera is if set to take pictures the mode is set for the display. Simnce the display circuit is not functioning the camera will shut down itself. The cost to repair outweighs the cost of a new camera these days sorry to say
