Question about Dryers
My Hot Point Dryer keeps shutting off while the clothes are still wet. When I go to restart it will not start until it cools off. We took the dryer apart cleaned it all out and we always make sure the lent trap is clear. Not sure what the problem is.
    President:
  • 1,723 Answers
Thermostat controls heat. There is also a
motor centrifugal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The element has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Posted on Jul 13, 2009
How can I diagnose, isolate and repair my Amana, NED7200TW dryer it runs but will not heat?
Since you say it happened gradually seems like it's not the heating element. If that's functioning properly you should see the orange glow inside the dryer when running. If your dryer does not have a glass door you can keep the dryer running by holding the button in. Look on the door, at some point you should see something that makes contact and pushes a switch on the frame. You can trick it by manually closing the switch. Be careful. I would suspect the trouble is a clogged lint exhaust. Over time this will fill with lint preventing the moist air to escape. This is how the dryer works. The hot wet air in the drum needs to vent outside to dry the clothes. When this becomes clogged you have nowhere for the moisture to go. So it stays in the drum and runs and runs without drying clothes. Also make sure you clean out the lint trap after each use. Clean the entire vent path. Also make sure you are venting outside. If not, you are just recirculating wet moist air back into the dryer. When working properly, you should feel a good flow of warm wet air at the outside vent. If not there is still a clog. Good luck.
Sep 05, 2014 | Amana Dryers
Dryer will only spin with small load
You need to replace the belt that will solve all your problems.
Oct 17, 2012 | Dryers
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
My dryer will run for a couple of minutes then shut off we already replaced the heating element
If your dryer has electronic sensors like this:
They might have a coating builtup on them preventing them from feeling the wet clothes.As the wet clothes tumble in the dryer they rub up against these sensor strips. As long a wetness is there the capacitor is dicharged on the controls upstairs and it continues to dry them wet clothes. If junk gets on them sensors no wetness will e felt by them sensors. It is a simple as that. The dryer thinks the clothes is dry because no dampness is being detected so is shuts down thinking all is propah. Get some windex and scrub them sensors good so dampness can be sensed by the two sensors once more and party on!
Jul 23, 2011 | Dryers
Dryer shuts off before cloths are dry,then then you have to wait about 10 mim before you can restrat dryer..cleaned vent duck to out side2 times to besure it was clean..cleaned venting back of...
Check motor for lint build up around motor. Will cause motor to overheat and shutdown on motor
overheat switch and will restart after cooling down.
Feb 11, 2011 | Dryers
Gas dryer get hot but than goes cold
This sounds like a problem with your fan motor. The dryer is getting too hot and the gas is shutting off until it cools down. That fan keeps the dryer cool by moving the heat to the clothes in the drum.
You can easily check this by feeling for air flow in front of the exhaust vent outside. No air movement = fan problem = heat shut off in 10 minutes. Good luck
Dec 05, 2009 | Dryers
Clothes dryer is overheating and then shuts off
Your vent pipe is probably clogged with lint. Clean out, and blow out, if possible, If the vent is clogged, the air cannot properly escape and all that heat stays in the dryer, which probably sets off some kind of themal protection switch, preventing the dryer from running until it cools down.
Oct 10, 2009 | Kenmore 73932 Gas Dryer
Once we put a load of wet clothes in the dryer after about 3 minutes the dryer shuts off. The top of the dryer becomes extremely hot. We open the dryer door and let it cool down and then the dryer starts...
Wet clothing doesn't allow proper ventilation while tumbling clothes. This in turn causes electrical shorts: steam in chamber and reduces airflow. Reduced airflow will will cause the drier to shut off on an over temperature condition. Moral of story, spin clothes as dry as you can and when tumbling, make sure you have good ventilation to get best results.
Sep 26, 2009 | Dryers
Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Jul 27, 2009 | Dryers
Dryer will not turn off
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 20, 2009 | Dryers
Dryers Logo
149 people viewed this question
Top Dryers Experts
