Question about ADIC FastStor2 LTO (90024202)
LTO 3 Error Code 90 follow by A0
LTO 3 Error Code 90 followed by A0. Reset doesn't seem to work.
Our dell powervault 122t shows error code A0
Error Code A0 - Error occurred during carousel movement (Position Not Found). Could be caused by a missing or misaligned cartridge carrier, or an obstruction, or unexpected cartridge in either the carousel path or Import/Export slot.
Remove the power cable and SCSI cables then try open the top cover. Check and see if there are any tape blocking or obstructing the movement. Sometimes it works sometimes it doesnt. I have 5 of these devices, few of them were replaced as its not working anymore due to these codes and as they are pretty obsolete, its not worth to repair them anymore.
Feb 03, 2011 | Dell PowerVault 122T LTO (pv122tlto)...
HP StorageWorks 1/8 Tape Autoloader SDLT 320 - tape library - Super DLT - SCSI Displayed Error! Code: A0 When you try to import or export are displayed error code 90
The library picker arm cannot move to the home position. There could be something blocking it. Try the Reset option from the Configuration menu. This is detailed in the library user guide.
Jan 11, 2011 | Quantum ValueLoader SDLT 320 Super DLT...
Error code=620
Hello sir; Follow the following steps to reset;
1, press these three keys in order and keep hold them down,"stop/reset", "start", "left copy density key".
2, press "stop/reset" key again.
3, enter 163, then press start key,
4, after they running, press "stop/reset" key.
5, press 001 to exit.
Mar 15, 2009 | Copystar CS-1505 Copier
Error code 90
NO PC stated, it has a HP name, like DV6-12345,
no OS stated, XP , w7 , w8 or w10. we can not guess OS, ever.
start a post by telling the helper what is in your hands.
we cant look for you, you must tell it.
tapes, sounds , RELIC for sure...
May 08, 2017 | HP Computers & Internet
Error Codes
I've had a friend to stay who had this problem. I downloaded the user manual from the internet and the error code is not mentioned. I followed the procedure to reset the radio and this solved the problem.
Take the cover off the stereo and locate the small hole (towards the centre) which houses the reset switch. Insert something like a paper clip into the hole and hold for a few seconds. Then replace the cover and all should work. You'll loose all the radio presets.
Jan 09, 2009 | JVC KD-G322 CD Player
Tandberg LTO HH (LTO-3)
The error is because the driver isn't loaded for the device. Look up how to add the device in symantec help. If windows recognizes it already then usually you can go to devices and add teh device from within symantec.
Jun 03, 2008 | Tandberg Data 200/400GB 420LTO LTO2...
Ultrium LTO 3 Tape Autoloader Error
what software are you using? try not backing up the system state to see if that changes anything?
Feb 07, 2008 | HP StorageWorks ESL712e Ultrium (AA934B)...
ADIC FastStor2 LTO (90024202) Logo
507 people viewed this question
Top ADIC Computers & Internet Experts
David Payne
David Payne
Are you an ADIC Computer and Internet Expert? Answer questions, earn points and help others
