Question about Belkin (F5D6230-3) Wireless Router
Internet wireless connectivity
Can anybody help me? I can't open any page through my laptop using the wireless router. It says I am connected though.
  • 85 Answers
Re: internet wireless connectivity
This is a common and annoying problem. Your router is running and connected, but they are either not using the same encryption keys or else you have some other setting incorrect (encryption type is a common one).
Turn off the laptop's wireless connection and enable its cable (wired) connection. Connect the laptop to the back of the router physically with a network cable. In a browser type (or other similar number - check your router's quick start guide). Log into the router and go to the WIRELESS SETTINGS. Write down everything you see (channel, station ID, encryption type and key, and whether MAC ADDRESS LOCKING is on (if it is turn it off for now)). Take these settings, reverse the process on your laptop and try to connect wirelessly with the new settings. They have to be exactly the same
If it all works, you need to go back into the router and enable MAC ADDRESS LOCKING after giving it your laptop's MAC ADDRESS, enable the highest standard encryption both the router and the laptop support, and turn off station ID broadcasting if possible.
If you still cannot connect wirelessly, connect again through the wire connection, and turn off encryption, turn off MAC ADDRESS LOCKING, and try again.
Good luck...
Posted on Nov 16, 2007
0 characters
3 Points
My laptop recognizes the wireless dlink and works perfect, my wife's laptap, we used for the installation cd for setup and it recognizes the dlink, but the internet doesn,t work. Her laptap has windows...
not very clear but this may help.
1) make everthing is connect physically....make sure modem is connected to your router....then check that your router is connected to your laptop...everthing physically.
2) after you made sure everthing is connected. look underneath the router and look for and something that start with
3) now go to your laptop and open up your web browser and type "Admin" as username and dont type anything for password. then click on "log in"
4) then when you log in. click on "setup"which should be on top of the page....then select "internet" from left side of the page.
5) click on "setup wizard"
6) Click "Launch Internet Connection Setup Wizard"
7) click next
8) setup ur password
9)select your time zone...the click on next
10) then if your internet connection isnt detected you will need to select the company that provides you ur internet...if u dont find it then select "not listed or dont know"
11) also make sure you select "DHCP Connection (Dynamic IP Address" click next
12) click on " clone your pcs mac address"
13) u dont have to type in "host name" next
14) next now the wizrd should b complted and "connect"
15) now u shoudl have internet on any computer that is physically connected to the router with a ethernet cable.....but no wireless internet we are about to set it uo
1) click on "setup" on top of the page
2) click on "wireless settings"
3) click on the box next to "Enale Wireless"
4) type in a name in "wireless network name" for example "gary's wifi"
5) in "802.11 mode" i suggest picking "mixed cause you might have 802.11b in an old laptop and 802.11n in the newer laptops....with mized mode they will all be able to connect no matterif they are b,g, or n
6) den click "save settings" on top of the page...and NOW your wireless device should be able to connect to your wifi...BUT....remember we didnt put a anybody around your house will be able to use it....if thats find with your then your done....if not then select wat type of security you want wep,wpa,wpa....and make a password..hopes this helps....let me know how it went.
Feb 25, 2011 | D-Link DIR-615 Wireless Router
Laptop cant connect to internet
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Apr 06, 2010 | Linksys Wireless-G Broadband Router
Internet signal is fine, works on main computer but not on laptop
download the driver here
Apr 03, 2010 | Linksys Wireless-G WRT54G Router
Connect my office computer to belkin wireless
Feb 06, 2010 | Belkin (F5D7230-4) Router (587009)
I can't connect to internet wirelessly, though my
Jan 16, 2010 | NetGear RangeMax WPN824 Wireless Router...
Says connected but when you open internet explorer it cannot display the webpage
Are you able to access internet when you connect the router with the computer or laptop using a cable if yes then you need to open the setup page of the router in the wired connection with IP and then need to check the wireless settings
Right now you might be connected in the local network means the connection between the router and computer is fine and the issue may be between the internet service provider and the router for that you again need to open the router setup page and do the internet service provide settings on the router
Let me know if this help if you will provide me more info i can help further with the setup
Dec 01, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Help me to resolve a problem with my Router
To access the configuration page of the Dlink router, use a wired computer or directly connect your laptop to the router using an ethernet cable. Then open any internet browser and in the address bar type:
Select Admin from the drop-down arrow and then enter your password. Leave the password blank by default. If it doesn't work, then you will need to reset the router.
At the back of the router there is a reset button, hold it down for 30 seconds.
Then try again to access the router. Reconfigure the router's internet connection, depending on your ISP. Under Setup>Internet page, click the Internet connection Setup Wizard button to automatically configure the router.
Then for the wireless settings, go to Setup>Wireless Settings page, then click on the Wireless Network Setup Wizard to configure the wireless settings.
Nov 11, 2009 | Routers
I installedlinskys wireless g broadband 6 months ago. I tried to get onto the internet and I am getting a message asking for a security code. I used the security code and it is not acceptingit Can anybody...
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Nov 07, 2009 | Linksys Wireless-G Broadband Router
Cant connect my laptop wirelessly...
Try to reconfigure your wireless network on your DI-524.
To access the configuration page of your router by Default type in on the address bar On the login page by default the Username is admin and leave the Password blank.
If inside the the configuration page of the router
>Click Home
> Click on WIRELESS located on the left side and you will have the wireless setting of your network
> Change the wireless network name
> Under security choose either WEP or WPA -PSK for this type of router.
> Type in your new network key (also know as Passphrase of Key1).
For WEP use 0 to 9 Number or A to F character and it should be exactly 10 characters.
For WPA-PSK you can use alpha numeric from 0 to 9 and from A to Z. The minimun character would be 8.
> Click on apply
> Click on continue.
Try accessing your wireless network first using your wireless computer. If you are connected to your wireless network try connecting to the Internet.
Jan 27, 2009 | D-Link AirPlus DI-524 Wireless Router
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Belkin (F5D6230-3) Wireless Router Logo
294 people viewed this question
Top Belkin Routers Experts
 C. Dante
C. Dante
steve morris
steve morris
Are you a Belkin Router Expert? Answer questions, earn points and help others
