Question about LG 60PS60 60 in. Plasma HDTV
I have a 60inch lg plasma tv only a couple years old but Im getting a thin green line going vertically down half my screen down and about three quarters of the awy across. It only came on for about 15mins an hour or so after first switching on, then went away and now is on all the time. Tvs never been moved but is very dusty. Does anyone know what it needs to fix it or does inside just need cleaning or something?? Thankyou v v v much anyone who can help me
  • 2 more comments
  • starcia73 Jul 13, 2009
    it started just over a week ago and nothing changed or touched it or anything. Its a thin green line about an inch or two wide that goes down the screen about three quarters of the way across and goes down about half way. I just leave tv on n it goes away but has been on ages today n just flashed red n went away now. This is the longest time. Otherwise the tv is perfect n picture is mint too
    Sorry, but how do I get to the board to clean it please? Do I have to take back off my tv to clean it all?
    Sorry if I sound daft but Im a girl and live by myself so could do with things explained in the clearest way. Thankyou so much for trying to help me
  • helpertoyou
    helpertoyou May 11, 2010
    so is there just green lines. when did it start. what was the last thang u did with it. and when it first did it what did u do to make it stop
  • Daniel Ward
    Daniel Ward Mar 29, 2014
    my Lg 60ps40fd tv just got this green line 1mm or about 2 pixels top to bottom
    President:
  • LG Master
  • 1,779 Answers
A good chance your upper buffer board connectors need cleaning. That board will correspond where the lines are. It's at the top of the set.
Posted on Jul 13, 2009
  • Jim Krause Jul 14, 2009
    It is a delicate operation so you don't damage the display ribbon connector. I highly recommend having a service company do it and hope they will honest with you.
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
42inch LG plasma TV
well if you could please give out the model nuumber thank you
Sep 10, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
60inch lg plasma green line down the middle
Visit this site named 'Electro-help' These type of fault to plasma TVs are described in detail there. Almost all plasma TVs will have same structured circuits. You can find which board to your TV is faulty, by referring details from this site. Check this link, and select the site named above. Pull up older posts there.
Jul 30, 2012 | LG 60PS60 60 in. Plasma HDTV
It is going to be one of two basic issues:
1. There is a poor connection somewhere in the set--either with a plug or cable or on one of the boards.
2. There is a board that is beginning to fail causing this.
Either would require a shop and may or may not be worth the cause.
Having seen hundreds of these sets all are more prone to flaky problems than the older sets and average life span is 3-5 years.
Shop I work for 80% of them are 2 years old or less.
If problem began shortly after set was moved or relocated I would lean towards a bad connection somewhere.
Mar 17, 2012 | LG 50PK550 50 HDTV Plasma TV
Green lines vertical on lg 50 plasma tv started with one thin one week or two later developed another one what can i do to fix the problem
I had the same problem with a Sony tv a couple of years ago. The cable connection was going through the VCR, then to the tv, so we thought we could try making a direct connnection, and the lines went away! I'm not sure if this is your problem, but if so, this should do the trick. If not, call a repairman, and they may be able to help.
May 29, 2011 | LG 50PX1D 50 in. Plasma Television
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Half Screen has colored lines, Half screen is working ok
there is a defected capacitor in the vertical circuit trouble shoot and replace. or if the vertical circuit is separate then replace the whole board.good luck
Jul 11, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG Plasma TV MOdel 50PC5DC
You will definately want to call LG and have them refer you to an auth. service center for warranty repair. This is either a failed scan bd or mayber even a bad plasma panel and there is nothing simple for a problem as you describe.
Apr 08, 2008 | LG 42PC3D 42 in. Plasma Television
50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Feb 11, 2008 | LG 50PX4DR 50 in. Plasma TV
LG 60PS60 60 in. Plasma HDTV Logo
1,925 people viewed this question
Computer Repairing
Computer Repairing
