Question about Kenmore 24032\24036 Top Load Washer
After the drum fills with water, i can here the motor working but the drum doesnt spin
    Problem Solver:
  • 12 Answers
You broke a belt or it just came off . pull it out and look in the back at the bottom you mite have take the back off, u will save money. by doing it yourself try that
Posted on Jul 13, 2009
Front loader goes up real slow and on down pressure
not eneough information need maker and model
doesnt sound like a control panel fault
if a filling up problem
faulty water intake solenoids
or if not pumping out ... the water pump
if its a spinning and washing fault
the motor worn out .drum shaft support bearings
Apr 30, 2016 | Washing Machines
Buttons all work but drum will not spin and it shows code f01
You dont mention make! Does it start program then shut off or does it fill then not turn? First part of any program is to pump out any water left from it previous program .if something is blocking pump (bra wire/coins/hair bobble etc) it will shut down and putup a code.if its the brushes in the motor or belt broken it will start then pump then fill then may carry through whole program as it doesnt know its drum isnt spinning.or it will detect and show fault code.replacing brushes in motor is for somebody who knows what theyre doing.but its straight forward and brushes are cheap. Pumps blocking again common but most people can clear a blockage via a door at bottom of machine.water will ome out so take drain tube and hold in a bucket at ground level first
Jan 18, 2016 | Amana Dryers
Drum doesnt turn
hi is the belt on if so 1st thing to check are the motor brushes good chance thats the proplem
Dec 27, 2013 | Hotpoint Aquarius WMA42 Front Load Washer
Machine is filling with water but the drum wont turn or spin
MOST LIKELY THE MOTOR IS SHOT OR THE BELT AROUND THE DRUM CAME OFF THE DRUM
Feb 06, 2013 | Washing Machines
Machine will not agatate when clothes are in the machine
does the machine fill up with water? if you were to put the machine in drain/spin, does it drain/spin? if water comes in and it doesnt drain/spin, then your lid switch is bad. if the machine fills with water, drains but doesnt spin, the your motor coupling is worn.
Feb 03, 2011 | Washing Machines
WFD 2460 will not start wash cycle after it has filled with water
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
Dec 07, 2008 | Bosch Logixx WFT 2806 Front Load...
Makes a humming noise but then nothing
the motor is bad. it will need to be replaced or purchase a new unit ( depending on cost of repair ). Joe
Nov 18, 2008 | Hotpoint Washing Machines
Washer fills with water and thats it
Possible a bad motor control board. Depending on the age of the washer, you may need to replace the motor control board and the motor as a kit. Also be sure to test that the motor control board is getting power, I've seen cases of the motor/ motor control failing and taking out the main control also. The tech sheet is in the console and should walk you through the steps.
Jul 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
My washer wont spin
on the motor there are what you call carbon brushes.. these wear out over time, this then the motor stop spining check and get back to me . cheers doc
Nov 20, 2007 | Zanussi FS1455W Front Load Washer
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
47 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
