Question about Rancilio Silvia Espresso Machine
The water isn't heated
The heater doesn't seem to work any more. I have cared for my dear Silvia as well as I know how to, so I can not think of any reason for anything suddenly being broken. Can it be a fuse or something?
  • christine988 Jul 14, 2009
    Thank you very much for your advice! I read about the reset button after posting my problem, but it didn't seem to help (I did get a shock though, after forgetting to unplug the machine...). Will try the brew thermostat test though. Again, thank you :)
  • 1,089 Answers
Hi
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also an other problem that you might have. If the brew thermostat is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
Posted on Jul 14, 2009
Heater fires up but won't keep heating water
Sounds like the sensor is not working shutting down too early
Jan 06, 2018 | RTO Atwood Water Heater - 6 Gal LP
Hotpoint fdw60 4th & 6th lights flashing
These two lights indicate a fault in the heating circuit.
You would require to have access to and be able to use a multimeter to test the heater if the machine isn't actually heating the water.
If it is heating the water then obviously we know the fault isn't with the heater.
Check the heater first.
Take the door apart and check the wiring in the door isn't broken.
If everything checks ok, take the pcb out, look for burned or dry joints around the relays.
Nov 05, 2012 | Washing Machines
I have a 2001 Alero, rear defrost isn't working at all, frost inside my car, won't defrost and heat isn't working! :( HELP any idea's... I thought it was the heater core but there isn't any leakage un
You definatly have water inside the car. Pull the carpet back in the front and rear checking for water leaks. The only way frost can develope inside a vehicle is the presents of moisture.
The other possibility is your HVAC drain is plugged and water has built up inside the heater motor area. Have the drain checked and cleaned.
Nov 21, 2011 | 2001 Oldsmobile Alero
Heater will not blow out hot air in my 1988 ford F250. Thermostat and hoses are all good. Is there a sensor that may be causing the problem and where is it located?
Hello! There isn't a sensor that would disallow heated water to circulate through the heater core...If the temperature gauge rises to normal...And the upper radiator hose is hot along with the lower hose ...I can conclude water is circulating through the block...Question then becomes; Is it circulating through the heater core? And the answer to that is, I don't think so...With the heater control turned on high feel the outlet heater core hose (facing engine it's the one on the left) if it feels cold or not as hot as the inlet then one of two items are at fault...#1...The Plenum assembly, which the heater core sets in has an open vacuum line...#2...The heat control valve cable or the valve itself is not opening...See picture of valve below...It is on the firewall...Let me know if heat is passing through the heater core...If hot water isn't passing through the core and the valve is opening than the core itself is blocked...send a comment...Guru...Saailer
saailer_214.jpgMOTORCRAFT Part # YG229...$20
Oct 09, 2011 | 1988 Ford F 250
I have a 2000 chevy impala my heat doesn't work,
first it to verify the coolant flow. I suspect the heater core isn't flowing, you may need to take a garden hose and take both heater hoses off, and flush in both directions to clean the heater core. flush in both directions until you get clean water flow. I am assuming the coolant level is OK, and the water pump is pumping and the engine is getting warm enough.
Sep 15, 2011 | 2000 Chevrolet Impala
Temperature guage goes to high, but it doesn't appear that the van is overheating (no steam/fluid leaking) Radiator & thermostat were recently replaced. Guage will jump to high when idle, but...
FLUSH RADIATOR, HEATER CORE AND ENGINE BLOCK.ADD 50 / 50 ANTIFREEZE AND WATER ALSO REPLACE RADIATOR PRESSURE CAP.IF TEMPERATURE GAUGE STILL STAY HIGH THE ENGINE COOLANT TEMPERATURE SENSOR COULD BE FAULTY.
Aug 21, 2011 | 1996 Ford Econoline
I over heated my van it shut it self off antifreeze every where changed the waterpump the two tubes from the pump and the thermosstart it dont over heat any more but the over flow bucket is always empty...
I'd watch to make sure water isn't getting into your oil.
If it overheated, a head gasket or warped head could allow water into the oil pan.
Water would seem to mysteriously go away.
Just make sure after adding lots of water that oil on the dipstick doesn't look like a chocolate malt.
Otherwise, a leak is somewhere else.
Heater cores, water pumps, and radiators need to be looked over for hairline leaks.
As more and more water has to be added to keep levels correct...problem will show itself soon.
Hope this helps...
Jul 30, 2011 | Ford Windstar Cars & Trucks
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia leaks around group head. Gasket seems fine.
HI
You need to change the group head gasket. They only last about 1 year and then should be changed. Get 2 because they usually fail on Friday and you have a party on Saturday.
The gaskets get hard from the heat and don't form to the filter any more so they leak.
When you get the new gasket.
Empty everything out of the machine (water tank, drip tray, etc.) Turn the machine upside down on a towel. This way you can see what your are doing.
Remove the filter screen and diffuser from the brew head. The black O-ring is your gasket. Carefully pry it out. Clean the opening good before you install the new gasket. Insert the gasket with the beveled side down (on the inside edge of the O-ring is the bevel). Once you have the gasket in place, use the portafilter to finish seating the gasket.
Oct 23, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
253 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
